Question about Bissell 6594 PowerForce Bagless Upright Vacuum
No suction in the hose
Hi-
Im attempting to "try" to vacuum the couch and im using the hose but it doesnt seem to working properly. The hose wont pick anything up, there seems theres no suction, and its not taking it to the canister.
Any suggestions?
Take the Hose out bcack run the water hose thru it full blast to unclog it then leave it hanging to dirty all the water left inside out.
Posted on Aug 25, 2008
  • Anonymous Aug 25, 2008
    **To dry all the (possibly) dirty water out or else mold maybe could form. Probally Also it could ruin you motor if too much moisture in the mechanism.
    Okay that is my first post, sorry if it wasn't very good. I hope your vaccum works.
SOURCE:
My eureka boss 5856 has suction through the hose, but the cyclone isn't spinning and it will not pick up anything. I have tried using it normally and with just the hose and it will not pick up.
Is the suction strong or weak?
Have you cleaned or replaced the filter?
A plugged filter will restrict air flow and cause vacuums to lose the ability to work properly.
Mar 10, 2017 | Eureka Vacuums
VACUUM BEATER BAR WONT TURN AND NO SUCTION ON FLOOR. LOTS OF SUCTION FROM HOSE.
If the belt is stretched it will not pick up properly. Try replacing the belt first. Belts should be replaced at least twice per year.
Feb 24, 2015 | Bissell PowerGlide Deluxe Pet...
No suction when using the hose
Hi Pam...
Sounds like you have a blockage in your hose, remove it and try to see if there is debris in the hose...remove the debris and it should work fine.
Please take time to rate me
Bud
Mar 23, 2013 | Dyson Vacuums
My dyson dc24 hose works fine however the head of the vacuume does not pick up anything (no suction) the brush is still working and i have cheacked for blockages and found nothing,the cylinder seems to...
I'm sorry to hear you're having difficulties with your DC24. From your description of the issue, it does sound as if the cleaner may be blocked. You may find it helpful to run through the checks shown in our troubleshooting guide, just to make sure you haven't missed anything:
http://www.dyson.co.uk/support/help.asp?article=1492&product=DC24-ALLFLOORS
This should enable you to resolve your issue without further assistance. However, if you feel you need some guidance, it's probably best if you get in touch with us directly, so we can help you resolve this as quickly as possible. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Sep 26, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
I cleaned out the hose and removed brush to clean and checked belt. Everything seems to work but will not pick up or suction on carpet. The hose is totally clear from clogs. I can see the floor from one...
Hi troupdavid,
I see that your Vacuum is having issues with it suction, you mentioned that you took it a part to clean it, see steps below.
  • Check if everything is inserted properly and is in place.
  • make sure the the Vacuum airflow does not have anywhere else to come out from, cause if there is, the vacuum suction will really not be really getting enough suction to be able to get dirt Off the floor.
  • Make sure the bag is correctly placed in the Vacuum and is tucked in properly for proper suction.
  • The hose should be twisted to be locked into Place, either clock wise or counter clockwise which ever makes it lock to the hose socket.
  • Also check the agitator shield beneath making sure that the Belt is not pinched in or squished by the Agitator and the Agitator shield, this can also cause lack of suction for the Vacuum.
I hope that this will be of help regarding your query.
Have a nice day,
mvincentc
May 01, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Dirt is picking up but not going in to the dirt cup
Hi there SmartAlec from NelsonVacuums.com.au here. Sounds like an obstruction to me (ie a blockage somewhere). Start by taking off the hose and testing to see if you have suction where the hose attatches. If you do have suction put the hose back on and feel it as if you are going to vacuum the couch, if you have lost suction you must have an obstruction in the hose which has to be removed. The other likely place to look is under the machine behind the brush.
Hope this helps - Happy Vacuuming ! :)
If not send me a message and ill try and help you further!.
Aug 26, 2009 | Bissell Vacuums
Suction/Brush not working
There are a couple of common reasons that your electrolux vacuum cleaner would appear to have lost it's suction. The first and most common is that it has actually broken a belt. If the belt is broken the brushes won't spin and it will not pick up dirt. It is easy to test simply turn the vacuum on, release the handle (as if you were about to vacuum carpet) and lift up the head and see if the brushes are spinning. If not i can supply you with a new belt.
If the brushes are spinning then your next most likely cause is that there is a blockage in the vacuum somewhere. Test this by turning machine on and checking the suction at the hose (as if your were going to vacuum the couch) if it is poor then remove hose and fish out blockage. If it is ok you may have a blockage between hose and the brush of the vacuum.
If it is neither of these problems i can trouble shoot over the phone if you live in Australia 0269215200 or by email [email protected]
Happy Vacuuming.. :)
Aug 25, 2009 | Electrolux EL5010A Bagged Upright Vacuum
Main powerhead useless
Make sure that the vacuum hole in the head unit, or the wand, or the hose is not blocked. You may also want to check the bag to make sure that the inlet hole is not blocked. The only reason for spitting things back out is that the suction is not working properly...
Nov 26, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Dyson DC07 hose has no suction
Just resolved the same problem...couldn't find a blockage anywhere, but pulled handle out of hose and extended hose as far as possible upward. Aha! There was blockage in the hose at the very bottom where the flexible hose meets the rigid part.. There is a lever which releases the entry to the bottom of the hose. A pencil, lots of coins, a crumpled receipt and general dirt were stuck. Easy to clean and now it works like new again.
Nov 08, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
140 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
