SOURCE: Battery replacement?
Kris, are you sure that the radio es working properly with other batteries, I mean if you use with 4 AAA batteries does the radio turn on? If the radio turn on, is your battery lasting as ussual? check if the battery contacts are ok, may be one of them could be damaged or rusted. I hope this can help Neto
SOURCE: midland radio battery pack constant vibrate
Hello pjbracht, I just responed to a duplicate of your problem. If they are new, return the battiers and confirm they are "by the book" replacements. If so ask for replacemrnts with a higher mAhr. It is not correct for vibration from a battery pack, lead, NiCad, Ni-MH, period.
SOURCE: Midland GXT800 radio, opened, reassembled, won't charge now...Help!
hi ive got a midland 3001 and i carnt find any one to speek to ?
SOURCE: I bought 6 sets of
The batteries have likely been damaged from being on the chargers too long. Try trading a known good battery into the non-working radios and see if it/they will work with a good battery. If so, replace your batteries, and then only put the radios on the charge when they need a charge, such as after the radios have been used 8-10 hours. Longterm charging can quickly age batteries. Life expectancy of a battery is 18-24 months with good care.
Best regards.
