Question about Hotpoint TDC32 Electric Dryer
Start button needs to be held in to work on TDC30p
The tumble dryer is acutally a hotpoint tdc30p. It will work with the start button held in. I replaced the start switch, but it is the same problem - works for a short time then stops. Please help!
  • Anonymous Feb 01, 2009
    I have the same problem. mine works fine fo 5min or so and then it cuts out and cant be used enless you hold the start button in.
    Mart
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
CALL BACK YOUR SERVICE GUYS AND TELL THEM IT DID NOT WORK. THEY SHOULD NOT RECHARGE YOU FOR LABOR BUT CREDIT THE LABOR TO THE NEXT CALL SINCE THEY DID NOT FIX IT!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
Replacing the drive belt on a hotpoint tdc30p and need a diagram of how the belt goes round the drive and pulley system
wrap the belt around the drum first then the slack at the bottom wraps around the motor shaft. Then it has to go either left or right side of the tensioner wheel, but the flat side must touch the tensioner wheel(not the ribbed side of the belt). You know you got it right when when there is tension on the belt when it is correctly installed. I dont have diagram so this is the most simplistic way of describing how to install it.
Feb 26, 2014 | Dryers
Drum not turning
Hotpoint tumble dryer not turning? How to replace a hotpoint tumble dryer belt
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Nov 12, 2013 | Hotpoint TVF770 Tumble Dryer
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Need to find the front thermastate on my hotpoint tdc30p tumble dryer
i think you need to take the front panel of for this one here is a video on the back ones. We have a full video library on appliance repair video’s
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Jan 02, 2010 | Hotpoint Dryers
Hotpoint ctd40 t dryer. wont start just ticking.
do you hear anything running?,might have broken the belt or idler wheel,motor runs but no tumble,need to look inside,warning !! unplug ,high voltage.be carefull
Sep 22, 2009 | Dryers
Hotpoint condenser tumble dryer model tdc30p belt replacement
You will have to unplug the dryer and remove the front panel with the door, mark and remove the wires to the door switch, then there should be two screws on the inside which you will need to remove then tilt the panel out and lift to disengage the tabs connecting it to the main cabinet. Then you should be able to remove the old belt, carefully lift the drum and slide the new belt under it. Then this is where you will need to be a contortionist and take care as there are many sharp edges under there. Locate the motor and tensioner pulley, place the belt around the tensioner and while pushing back against the spring on the tensioner hook the belt to the motor pulley, then move belt on drum so it is aligned with lower pulleys. Turn the drum by hand a couple of times to make sure everything works.
Apr 04, 2009 | Hotpoint Dryers
Have a hotpoint tdc30p dryer that will not heat
Check to see if the new parts fitted are o/k,
If they are, then your problem is probably a faulty control unit or possibly bad connection in the wiring.
If the new parts are faulty, then something else is causing them to fail.
Make sure all filters are clean and that all air vents are clear
Dec 12, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC30P runs for about 5 mins then cuts out. Have replaced thermoststs to no effect.
hi its the relay behind the plastic facia normally brown with the word shrack on it with 6 wires on it this normally is the fault please leave feedback
Jul 31, 2008 | Dryers
No heat
hi there
your problem is either the t-stats have blown which is very common or your heater is blown..
im guessin your t-stats beacuse they are the most common on hotpoint dryers to blow. There always blowing
They located at the back of the dryer behind the protuding panel so there for you dont need to open it all up just that panel.
To check if their blown check for continuity,, no continuity no good merry christmas cheers
Dec 23, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
189 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
