Question about Video Game Consoles & Games
When i turn it on one red ring pops up on the bottom right side and it dosent work
I had the same problem and phoned xbox support who took it away free of charge to fix
Posted on Aug 20, 2008
HOW TO FIX LE ERROR CODE ON SAMSUNG DISHWASHER DMR78AHS
An LE error code on your dishwasher stands for "LEaking."
There is, what I call, a drip pan on the bottom that the water is dripping into. Remove your dishwasher and take off the lower the side panels to get a look inside the drip pan. If you have water in there, try to find out where it's coming from.
If there are no signs of water, tip the dishwasher over on its side and remove the plastic panel on the bottom of the dishwasher. Once removed, you can disconnect the connector to the leak sensor (it's mounted upside-down, with 4 wires coming out of it. If I remember right, the wires are blue and red).
Flip the dishwasher back upright and plug it in and see if your LE error code pops back on. If it pops back on, then you have a bad board. If it doesn't, then you either have a leak, or the "fangs" on the leak detector are shorting out, somehow.
Oct 29, 2014 | Samsung Dishwashers
How to use
Put popcorn in bottom up to where the ring in bottom levels off for a maker full or less if you don't want a maker full. Cover with popcorn oil, I use the butter flavor oil. Put some butter inside of lid compartment and put lid back on butter compartment. Now just put lid onto popper and plug in. The light on side will come on and popper will start to heat. You will then hear it start to pop. Popping is finished when light on side goes out. Carefully lift the whole popper and shake right side up and then turn upside down and shake. Remove bottom, add some popcorn salt if you like and enjoy it right out of the lid. Delisious!!
Aug 13, 2012 | Hamilton Beach Butter-up Corn Popper Self...
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
The red rings will pop up then they will go away
the three red lights mean the cpu has come loose from the board because of the way they bake it on. the cpu heats and cooks it off the board and the board sometimes flexes with excessive heat once turned off it cools down and connects wth the board again
May 01, 2009 | Microsoft Xbox 360 Console
My i phone dosent ring
Do you have the switch on the left side of the phone off?
In off position it will be red.
If it's off the phone wont ring.. Also make sure you have the volume up.
Dave
Apr 18, 2009 | Apple iPhone Smartphone
One red ring
IF U TURN IT ON AND IT STAYS LIKE THAT THAT MEANS U NEED TO CALL MICROSOFT AND TELL THEM U HAVE RED RINGS
Apr 10, 2009 | Microsoft Xbox 360 Console
Freezer door pops open
i know what you mean...... ok, the bottom of the door is not leveled right. you can adjust this by respringing the hinge. put something large like a screwdriver handel in the door and close it slowly. do it just enough to respring the hinge. dont do it to far or it my make it worst. some door have a screw ajustment on them but this dosent work all the time. there is a number of resons why the door does this. i have found that this works 9 out of 10 times. but do it slowly and check it after each time you do it. hope this helps you...............thanks eddy
Jul 24, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Duet door popped open
there is a door unlock ring on the bottom of the door lock switch
to get access to it remove the bottom panel and look up from the bottom to the door lock switch on the right side of the washer
you will see on the bottom of the door latch switch a ring that kinda looks like a bubble blower ring that kids use to blow soap bubles
pull down on the ring and it should reset the door latch switch
if this does not work then the latch switch will have to be replaced
Jun 08, 2008 | Washing Machines
When i turn it on
i am having the same problem, i just tirn it off, then on, then off untill a screen saying "system erer call supprot" or somthing like that, then it has E 74 at the bottom, then i turn it off, then on, and it works...wait a few seconds before turning on and off tho ;)
May 31, 2008 | Microsoft Xbox 360 Console
Disc dosent spin
I just solved this problem, very simple actually. Possibly can happen when the drive WILL close, but then loud noise as it tries to spin the disc up. Open the drive up (4 little screws on the bottom) and lift the lid up. If you look on the top white magnet spinner, the bottom side of the magnet system broke off of the disc motor. It will look like a little metal ring stuck to the white spinner thing whatever it's called. I popped that off and examined it, then used some krazy glue to stick it back on the motor spindle and it's away and going now. The reason the drive will not close, is because when the little magnet first breaks off it can get misaligned then when it tries to shut it gets in the way. The MAY be the cause to the problem. I fixed this issue today with mine, hitachi drive.
Jan 11, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
22 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
