Question about Brother HL 5140 Laser Printer
Will not Print online Coupos
My Brother HL-5140 will not print online coupons from the web. I can print these coupons on the same PC with my HP, Canon, and Lexmark printers. The Brother will not allow me to uncheck the "Keep printed documents" section i nthe advanced properties. I have unselected and applied this option, restarted the PC and every time it reselects to Keep printed documents. With this setting stuck on the coupon software will not allow me to print. Any ideas?
  • 3 more comments
  • calsranch Sep 08, 2008
    I have the same problem with the Brother HL-1440.
  • Anonymous Jan 04, 2009
    I have the same problem as well. "Keep printed documents" won't stay unchecked so I can't print coupons.
  • junkbait Feb 09, 2009
    Same problem with an HL-1440 as well
  • Anonymous Feb 10, 2009
    I can't print coupons because printer won't change setting of "Keep printed documents."
  • Anonymous Mar 01, 2009
    Same problem with my Brother MFC-5440C
Just fixed my Brother HL-5140. Hope this helps :) I have struggled for years and finally figured this out from the Brother website.
If you are unable to print coupons from the Internet the print processor
setting in the driver needs to be changed. To change the setting,
1. Open Printers and Faxes.
2. Right mouse click on the Brother printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Try printing the coupons again.
Posted on Mar 09, 2009
A huge Thankyou! I fixed it!
Posted on Dec 05, 2009
I have a Brother HL-5140 Laser Printer and the Orange light comes on and when I go to the print queue to print something, it states the printer is offline, how can I get it back online?
Try installing the software package that comes with the printer. The software usually loads a helper app that pings the printer and keeps it online.
Apr 13, 2015 | Brother HL 5140 Laser Printer
How do you get a page count from an HL 5140/
On the HL-5140, you can print out a config page which will show the page count on it by pressing down the Go button (the blue button). Hold it for a few seconds, until the config page starts to print out.
To find configuration page instructions and page count tips for other printers, copiers, and fax machines, check out How to Print Configuration Pages.
Aug 22, 2011 | Brother HL 5140 Laser Printer
I cannot get my brother HL-5140 laser printer to print anything!!!!!! I have tried all troubleshooting suggestions.light on status is red
There is some paper jam inside the printer .Please remove the cartridge and look inside the printer for paper jam. If paper jam is there , remove the paper . I hope it will help to solve the printer problem.
Jan 25, 2010 | Brother HL 5140 Laser Printer
Our Brother HL-5140 is not printing. It doesn't
Replace the paper pcik-up rolly assembly. MAKE SURE TO get a good look at how the existing one is installed before removing it. It needs a little tweeking to get the new one in and everything lined up correctly.
Also replace the separation page on the paper tray itself.
Look for part number PF-1 Kit or OEM PART #: LJ7920001
The only diagrams I could find on-line of the inside of the printer I found by searching for "brother pl-prn067". Look at pages 8-9.
Dec 09, 2009 | Brother HL 5140 Laser Printer
My HL5140 will not print even the test page
check out the connections between pc and printer.remove and refit that connection and check out.
Mar 23, 2009 | Brother HL 5140 Laser Printer
MY brother HL-5140 quits printing,and also has a black vertical line down the page before it quits. After a while, say 30 to 45 minutes, it will start printing again. But there are black smudges on the...
Sounds like a fusing error ... If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit) If toner is sticking to paper but the print quality is poor , replace the drum unit  (PCU)  good luck
Feb 21, 2009 | Brother HL 5140 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Won't print from usb or parrallel cable
check the usb sucket on the printer board and see if the legs are firm if ok check the board
Jul 19, 2008 | Brother HL 5140 Laser Printer
Keep Printed Documents
Deletes and reinstall print drivers, does'nt sound like a printer problem, more software issue, driver reinstall is my best bet
What are you printing from? ie program is?, and can you print windows test page OK?
Dec 19, 2007 | Brother HL 5140 Laser Printer
Brother HL 5140 Laser Printer Logo
911 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
