Question about Daewoo Microwave Ovens
MICROWAVE NOT WORKING PROPERLY
TURN TABLE DOSE NOT TURN AND LIGHT DOSE NOT COME ON WHILE COOKING AND THEN IT JUST TURNS OFF LIKE I UNPLUGED IT. THEN IT WILL COME ON BY ITS SELF. MICROWAVE WILL HEAT BUT DOSE NOT SOUND RIGHT. UNDER MICROWAVE LIGHT DOSE NOT WORK BUT THE FAN DOSE.
KELLY
  • Daewoo Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Otherwise, it sounds like a bad door switch or door switch mount.
Posted on Aug 21, 2008
My microwave is working but the turn table is not turning
next time send the brand name and model number,when you go to work on a micro wave unplug it,even if you change a bulb on it,i've seen people change the bulb without unplugging it and cook the computer board,on the bottom there's a motor that turns thee turn table,drop the bottom panel of the micro wave usually like 6 to 9 screws and on some there could be an access panel just for the motor,unplug the old motor and remove screw or screws,pop off the cover inside the microwave where the glass turn table sits on and,put the new motor in and put it back the same way you took it apart,it's pretty easy to do.go here put your model number in and find part number
https://www.searspartsdirect.com/part-number/241700104/0046/253.html?pathTaken=partSearch&q=241700104
Jan 13, 2018 | Microwave Ovens
Have ge model je1860 turns on but when you hit cook nothing happens is it the turn table motor. i don't want to do trial and error on parts.naturally the fuse is good
I'll presume you can program it ( set the length of time you want to cook)
Does the timer count down?
Does the turntable ( if you have one) turn?
If everything else seems to work properly and it just doesn't cook more then likely the magnetron is bad
$87 from Sears:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JE1860WH04/0432/0123245/G0590488/00005?blt=06&prst=&shdMod=
Jan 18, 2011 | GE JE1860 Microwave Oven
All the lights and buttons on the front of my Frigidaire PLMBZ209GC work but the turn table does not turn and the fan does not run and it does not heat. It counts down and the cook light beside the timer...
Hello :
That problem could happen because of a bad door switch .
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
That could happen because of slamming the door and not closing it gently .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 31, 2010 | Frigidaire Built-In Microwave
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
I have a Sharp microwave oven, model R-5303K. When it is turned on, the light comes on but the table does not turn and there is NO noise - nothing cooks.
Check your door safety interlock switches. Remove the cover and check the switches for proper operation.
If you need more help, let me know
Sep 29, 2009 | Microwave Ovens
My Frigidaire microwave stopped working while cooking food.
All lights are operational. Model number is FMV156DBC.
Aug 29, 2009 | Frigidaire FMV156DC Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Microwave Ovens Logo
194 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
