Question about HP Color LaserJet 2600n Printer
Supply Memory - Error on Black
My HP LJ 2600n printer keeps jamming after it only prints 1/2 and only 1 or 2 colors print. When I pull out the paper, I see a message on my computer screen that says: Supply Memory Error on Black. Unable to Read System Data. Reinstall Supply. If error reappears contact support.
Is there anything I can do before contacting support?? Thank you
  • DBQRose Sep 03, 2008
    I did have original HP cartridges in it and tried replacing it with the same. I still got the same results.
    I compared my printer with others in the building and realized that the roller inside the door is not moving at all (which also explains the new squeaking noise when it tries to pull up a page).
    Thank you for your help!! rk
  • 138 Answers
A supply memory error is the smart chip on the cartridge. It can also be a physically damaged or locked / froze catridge. In this case the machine is identifying the black cartridge. The first thing to do is replace the cartridge (black).
If it's missing or has a corrupted smart chip lots of weird errors can result but they will usually still direct you to the specific cartridge to replace. If it's a refilled or remanufactured cartridge I would HIGHLY suspect that is the issue.
To locate the smart chip to see if it has come loose, see the picture below:
It's the green little computer board in the picture. Make sure it hasn't come loose. Below is a close-up of the chip. If it is a remanufacture or refill it should look slightly different than shown in the picture as the picture shows an original HP chip. If it's the exact same and a refill, return the cartridge to your supplier.
Hope this helps you. If so hit it with a FIXYA. If not, try to get the printer to print a configuration page or error report and let me know the last couple errors shown by numbers. (Full numbers, like 10.10.1000 or 13.02.05.)
Cheers
Posted on Sep 03, 2008
  • parkerguy Sep 03, 2008
    Wow that was a tremendous amount of work for a two diamond rating - guess I should have just kept surfing on to the next questions. Didn't even hear anything of unusual noises. That one even pushed my rating down. Sorry I thried to help.
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
How do one correct print quality in hp color laser jet 2600n
Hi Good day!!
Follow this method hope it helps you!!
During the printing process, paper, toner and dust particles can accumulate inside the printer. Over time, this buildup can cause print-quality problems such as toner specks or smearing. This printer has a cleaning mode that can correct and prevent these types of problems.
This printer has two processes for generating cleaning pages: one is automatically generated and one is manually generated. When a new black print cartridge is installed, a cleaning page will be automatically generated prior to calibration.
Clean the fuser using HP Toolbox
NOTE: Use the following procedure to clean the fuser using the HP Toolbox. To clean the engine when the computer is running an operating system that does not support HP Toolbox, see the late-breaking Readme on the root of the CD-ROM, or visit http://www.hp.com/support/clj2600n .
1 Make sure that the printer is turned on and in the Ready state.
2 Open the HP Toolbox using one of the following methods.
On the Windows desktop, double-click the HP Toolbox icon.
* On the Windows Start menu, click Programs (All Programs in Windows XP), click HP , click HP Color LaserJet 2600n, and then click HP Color LaserJet 2600n Toolbox .
3 Click the Troubleshooting tab, and then Troubleshooting Tools .
4 Click the Print button next to step 1, "Click the "Print" button to print out the Cleaning Page."
5 Remove the Cleaning Page from the output bin, and load it printed side down in Tray 1.
6 Click the Clean button to complete the cleaning process. Press the GO button on the printer control panel. The Cleaning page will print, with a second page adhered to the first page. This is normal behavior during the cleaning process.
Cleaning spilled toner
Defective print cartridges can develop leaks. Also, after a paper jam has occurred, some toner might remain on the rollers and guides inside the printer. The pages that print immediately after the jam can pick up this toner.
CAUTION: When cleaning the printer, do not touch the ETB with a damp cloth or with fingers.
Cleaning the paper path
The device features a special cleaning mode to clean the paper path.
NOTE: If there is access to HP Toolbox, HP recommends cleaning the paper path by using HP Toolbox.
Clean the paper path
1. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press (SELECT).
2. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Cleaning Mode, and then press (SELECT).
A page feeds through the printer slowly. Discard the page when the process is completed.
3. Load plain letter or A4 paper when prompted.
4. Press (SELECT) again to confirm and begin the cleaning process.
Calibrating the printer
Calibrations are performed at regular intervals. For best print quality, a calibration can be performed from the control panel using the following steps:
NOTE: This will calibrate the color and clean the black electrostatic transfer belt (ETB).
1 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select System setup and then press (SELECT).
2 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Print quality and then press (SELECT). Calibrate color will display on the control panel.
Press (SELECT).
3 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Calibrate now and then press (SELECT).
4 Press (SELECT) to start the calibration.
Other options for print quality defects that still persist
Oct 26, 2010 | HP Color LaserJet 2600n Printer
Printer print only black while all cartridges are
Check your printer configuration and make sure you haven't mistakenly set it to monochrome (black and white).
Nov 27, 2009 | HP Color LaserJet 2600n Printer
Hello, I have HP lj 2600n. It does not
the problem is due to scanner mirror dust.you have to clean the scanner mirror.
Oct 26, 2009 | HP Color LaserJet 2600n Printer
Supply Memory Error
It sounds like you are having two diffrent problems. I don't think they are associated with each other.
First, the memory supply error. The cartridges on this machine have a chip. The chip could very well be faulty causing this supply error message. Change the black cartridge and see if the message clears. if it dosen't then the antena that reads that chip needs to be replaced. I suspect the cartridge is the problem.
Second, the paper jams. This can be caused by a worn p/u roller as you mentioned. Sounds like the jam happens first then the error, based on your description.
The black thing you refer to on the door is called the "transfer belt assembly".
Aug 21, 2008 | HP Color LaserJet 2600n Printer
2600N: glossy paper
Is this HP glossy paper? I would think that laser printers have a hard enough time handling any glossy paper as it is because you run the risk of the gloss burning as the paper goes through the printer so you might have to use the paper recommended by HP.
Here are the specs of the accepted paper.
http://shopping.yahoo.com/p:HP%20Color%20LaserJet%202600n%20Laser%20Printer:1991823169:page=details
Good Luck!
Hope this helps!
Mar 07, 2008 | HP Color LaserJet 2600n Printer
HP Color Laser Jet 1600 Problem
Hey I have 1 problem I have the printer of 2600n when i give print Command of RED Colour its come orange and right side i get light print and left side i get little dark print , what is the problem i don't understand any can help me . Thank u Morgan.M
Dec 12, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
654 people viewed this question
Ben Johnson
