Adding a floppy drive
Added a floppy drive to an mpc new pc - checked bios to see if floppy drive controller is enabled, but getting nothing from the floppy drive - what am i missing?
  • 2 more comments
  • Anonymous Aug 25, 2008
    I added a Sony floppy drive, I have many Konica disks but am not able to view them o r to send them to my DVD/CD drive
  • ef_ektz05 Sep 28, 2008
    I have same problem. Installed the Floppy Disk Controller but can't install the device itself.
  • fgarcia561 Nov 10, 2008
    When I tried to add a new floppy driver to my gateway computer, the computer is telling me that I already have a 3 1/2 floppy drive. No matter what I do, I keep getting the same thing. Even when I uninstal the driver and I turn the computer off and on again, I get the message that a new hardware has been found, the 3 1/2 floppy that physically does not exist in my computer.
    Also the computer does recognize my new 3 1/2 driver.
    Can anybody help?
  • Anonymous May 11, 2010
    hi do you have the dirver for it??
  • 66 Answers
Downlaod a driver
Posted on Sep 04, 2008
6ya staff
SOURCE:
Driver for Teac FD-505 Combo Floppy Drive?
You may have to enable 'A' drive through the bios. Depending on the bios, you need to hit F1 or F2 or F10 at initial start up. You can hit all three at once and get into the bios. Then navigate your way through the bios to find where to enable and disable drives.
May 21, 2012 | Teac ZDS/ Combo FD-505-3XX Floppy Drive...
Hi i have connected a floppy disk drive to my Dell PowerEdge 1600SC Server but the pc cant find it. i know that the drive forks cos if i insert the ide cables the other way the disk drive led turns on but...
Not sure what "the drive forks" actually means.
The floppy drive usually connects via a dedicated connector on the motherboard by a ribbon cable similar to the IDE cables but physically smaller and of course to the power supply. If the drive, the cable and the motherboard is ok it should appear in the bios list ready to be enabled and added to the boot order.
If the floppy drive doesn't appear in the list you should refer to the motherboard manual as there might be some jumpers to reset or perhaps it is only suitable for a usb floppy drive.
Take the number from the motherboard and do an internet search which should direct you to a place where you can download a manual which will contain all the information you need.
Nov 11, 2017 | Dell PowerEdge 1600SC Server
My Dell desktop computer is plugged into a master switch. But I still have to turn on the computer to use it. Lately when I turn on the master switch, the computer turns on automatically. But the Windows...
The CMOS/BIOS battery has died and needs replacing.
The battery is located on the motherboard inside the case of the computer.
To replace the battery you'll have to open the case up and replace the battery. It looks like this >>>
Once you have replaced this battery and restarted your computer you will need to access the BIOS to set the date, time and also tell the computers BIOS that the floppy drive is not there and to set the boot order of the computer.
Once you have done all this you should not get that message again for a good few years.
Regards.
Jul 16, 2010 | Dell Dimension 3100 PC Desktop
Press F2 to enter the system setup. Someone or something (Bad Motherboard battery most likely) has reset the BIOS defaults, which includes the Floppy diskette drive controller to be ON. Set Diskette Drive to NONE, then under integrated Devices, set diskette controller to off, save settings and reboot
(ALT + B)
if issue re-occurs then the watch battery on motherboard is bad and needs to be replaced
Jul 16, 2010 | Dell Dimension 3000® Pentium® 4...
Regards.
Jul 16, 2010 | Dell Computers & Internet
I have installed a new floppy hard drive but my pc does not recognise it. how do i activate it? and why is the green light always on even without a floppy inside it?
Get into your bios and enable the "A" drive in the bios if you haven't already. It has to show up in the bios for it to show up in the device manager in windows. Start at the bios and work up to the device manager and reinstall floppy drivers if needed.
Oct 14, 2009 | Computers & Internet
Adding a hard drive to a PC
You need to set the little jumpers at the rear of the hard drive and the cd rom drive. Set the hard drive as Master and the cd rom as Slave. Both devices should then be recognized.
Dec 30, 2008 | Maxtor DiamondMax D540X (4D060H3) 60 GB...
A new hard drive
The sata connector was probably disabled in the BIOS to prevent you from getting a missing drive error on startup before this was installed. Press F2 at the Dell Splash screen to enter BIOS setup, come down to Drives and change the setting for the sata connector to ON. When you reboot go back into the BIOS setup and it should report the Drive ID and capacity.
Dec 28, 2008 | Dell XPS™ 600 PC Desktop
Computer won't come on
Does this computer have on board video? You mention that you added a new video card. Did you remove an old video card?
Do you see anything at all on the monitor at anytime while booting?
If it has onboard video have you checked the BIOS to insure that it is enabled?
Nov 20, 2007 | E-Machines eMachines Desktop PC
Open Questions:
I forgot my YAHOO password #{18OO~828O294} phone number usa Anita. There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. Please Read If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
Oct 23, 2019 | Yahoo Computers & Internet
CHANGE password on YAHOO email account #{18OO~828O294} phone number usa Anita. There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. Please Read If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
Computers & Internet Logo
601 people viewed this question
Ekse
Marvin
Marvin
