Question about Braun 9595CC Electric Shaver
TRIMMER STAYS IN OPEN POSITION
WHEN THE TRIMMER IS RETRACTED IT STAYS IN A PARTIALLY OPEN POSITION AND WON'T FULLY RETRACT. I RECEIVED THE SHAVER AS A GIFT ABOUT 6 MONTHS AGO. HELP !
  • 2 more comments
  • Anonymous Dec 07, 2008
    the trimmer on the 9595 does not fully retract.
  • nossaman Feb 02, 2009
    I checked the trimmer when I first got it and it closed fine. Never really use it. I used the trimmer last week and now it will not fully close and stays open. What can I do. It is very annoying.
  • Anonymous Feb 18, 2009
    I bought the shaver about a year ago and used the trimmer rather often - not each time I used the shaver but maybe every week at least once. The trimmer always retracted perfectly until I obviously managed to unhinge it. Now, it stays half-open -- well, you can push it closed but it usually retracted just fine and stayed closed.
  • PhilAtkin May 09, 2009
    Just as described
I had this problem, and it was due to the breakage of a plastic part.  If you slide the trimmer open you can see a piece of spring wire beyond the end of the word 'trimmer'.  The broken piece should locate the end of this spring; if it fails then the spring no longer forces the trimmer blade fully shut.  As the trimmer was opened and closed I could see that the spring did not stay symmetrically placed.  I could also see one end of the spring inside the mechanism, rubbing on the surface under the slider - but not the other.
To help with the instructions, let me identify some parts: "A" is the sliding part that your thumb pushes to open the trimmer; it carries the word 'trimmer'.  "B" is the hinged part that carries the trimmer blade itself and the word 'washable'.  "C" is the flexible piece of black plastic that connects A to B and on which the central section of the spring pushes.
To fix, first remove the sliding section A: slide the trimmer open and push a thin screwdriver down one edge of the slider.  Prise the lugs that hold A in place, away from their slots. Disconnect the connector C from the blade part B (gently push the lugs outwards, one at a time). Turn over the slider A and you should be able to see that one or both lugs that are intended to keep the ends of the spring in place, have broken.  (They are on a silver moulding fixed to the underside of slider A).  I fixed both ends in place with some two-part epoxy - be careful not to get glue on the other parts!  Allow to dry completely and reassemble.
Posted on May 09, 2009
  • pedisurf Sep 21, 2010
    I tried this and found that both lugs that keep the spring in place had lost their edges or shelves. I couldn't find the tiny missing tabs so I bought the replacemet trimmer unit as in solution 2 below, but only replaced the slider as above so I did not have to dissasemble the shaver head. It worked.Two comment.
    1- You need to hook the ends of the spring on part "C" above on the post ledge of part "A" so it will work properly.
    2. There is a seperate spring on part "A" that connect to a black arm. To engage the unit properly as you put it back in, the black arm must first be swung up into the position that place it pointing toward the end of part "A" that has the r from the word trimmer. That way when you slide "A" all the way down it will engage the proper slot in the base.
    Good luck
  • 4 Answers
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Posted on Aug 16, 2010
  • 05elise Aug 20, 2010
    I haven't tried this yet, but it appears you can remove the entire motor with the head assembly still attached from the top of the shaver while removing the broken trimmer which would be much easier. To do this, remove the black rubberized back by removing the single attachment T8 screw in the cord plug-in socket and then pry the back off of the silver plastic case. Remove the four T8 screws holding down the case cover and remove the case cover straight up off the case. The motor assembly should now be loose which will allow it to be extracted out the top of the case along with the broken timmer assembly as the trimmer is being removed. Reverse the above steps to install the new trimmer and you should be good to go. Again, I haven't tried this exact procedure, so I can't guarantee it will work.
4 Suggested Answers
  • 3 Answers
SOURCE: braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Posted on Jan 28, 2008
SOURCE: Braun Pulsonic Razor - Pop up trimmer will not retract entirely
I ran into this problem several months ago. I just shook it and forced it until it retracted and never thought anything of it. The trimmer recently broke (still functioned but extended beyond its normal point) and I took it apart. I realized that there were a few broken parts inside (possibly because of my earlier experience). So I removed the few parts and now it still extends to far, but otherwise functions ok if I'm careful.
I would recommend taking yours apart and seeing if you can find any parts floating around which may be causing it to not retract all the way. It may be broken beyond complete repair, but you may be able to get a little more use out of it.
If nothing else, you can order a new casing for it from here
Here are the instructions for taking it apart:
The shaver itself is easy to take apart. The part on the bottom(opposite from the shaver mechanism) pops off with just a slight bit ofprying. Be careful not to break the pins though. Once you have thatoff, the narrow sides pop off pretty easily. Then you can remove the 4screws opening up the interior.
Be careful at this pointbecause there are a lot of parts that may fall out. (Perhaps take apicture as soon as you open it so you know where everything was whenyou opened it). At this point you can try your hand at fixing it (minehad 3 parts broken and loose inside), or you can simply switch it withthe new casing (Which i'm going to do when I get it). Good Luck!
Posted on Mar 31, 2009
SOURCE: Trimmer not retracting back into shaver all the way
Hi Sorry I don't have the answer but this must be a common problem as my braun has the trimmer sticking out at 45 degrees when closed. The head lock went 2 weeks before the trimmer wouldn't retract so it looks like a design problem
Posted on Mar 27, 2010
Max harvest retrying
Likely cause,
1. Ice bridge thickness too small, not enough ice to open curtain.
Solution, Check and adjust if needed.
2.Ice bridge thickness too large, ice frozen to evaporator frame.
3. Purge valve dose not open, water melts ice bridge, not enough ice to open curtain.
Solution, Check purge valve.
4. Incomplete ice formation.
Solution, check water distribution for partially plugged holes.
5. Curtain out of position.
Solution, check curtain for swing restriction.
6. Curtain switch dose not open when curtain does.
Solution, Check switch with ohmmeter.
7. Machine in very cold ambient area.
Solution, Move machine to warmer location.
8. Hot gas valve dose not open.
Solution, Check hot gas valve, check controller using test mode.
9. Harvest assist probe out of position - ejector pin not retracted.
Solution, check harvest assist mechanism-spring should retract pin.
10. Damaged evaporator.
Solution, Check evaporator surface now would be a good time to make sure evaporator plate is not dirty this will cause ice to hang up on evaporator plate also check plate to make sure all cross points are not loose.
11. Fan motor stays on during harvest.
Solution, check controller using test mode.
Jul 18, 2013 | Scotsman HD22B-C0322MA-1B Hotel / Motel...
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Brector3 provided a highly informative procedure for replacing R9500 shaver batteries. Can you please provide more detail on how to "disjoint" the trimmer to gain access to the third screw? ...
To access one of the screws on the back or the unit, the trimmer must be partially removed. When you pop up the trimmer for normal use, it pivots near the top of the shaver. At this pivot point, each side of the trimmer has a tiny plastic pin that inserts into a socket of the shaver body. You can insert smaill flat screwdriver between the side of the trimmer and the shaver body and gently pry the pins out of their sockets
May 07, 2011 | Health & Beauty
Installing the big shaver back into trimmer
I have the same problem happen after about 15 months. The trimmer stays after being closed projecting approx. 1/4" from the face of the shaver and will not retract flush to the body. It also appears to be the spring. Does anyone know if there are there disassembly instructions for this and how it might be fixed? Sending it in for warranty can take up to two weeks. If I send it out for warranty my beard will get out of control and I don't have the hockey playoffs excuse anymore!
Feb 15, 2011 | Conair HCT420CS
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
Mar 29, 2010 | Braun Health & Beauty
Is the side blade working? if yes how?
push in the shaver on/off switch and push the trimmer all the way up until it is fully extended. the trimmer should work in this position
Jan 18, 2010 | Braun 8975 360 Complete Men's Shaver...
Jun 15, 2009 | Braun Pulsonic Rechargeable Cordless Men's...
Jan 25, 2009 | Braun Activator 8595 Electric Shaver
Dropped Sony Ciber-shot when lense was extended. Will not fully extend or retract now. How do I remove lense assembly to reset position.
sir,
open your camera,beside the cam part u can see the small gearbox, un screw this part and disconnect it from the base, then slowly turn the lense assy to both side carefully, dont give force. if the lense assy becom loose, fix the gear unit give a 3volt to the motor bring the cam to retracted position,then fix whole unit, it will work properly
thanx,
gulshanclt
Sep 03, 2008 | Cameras
Lens barrell doesn't retract for zooming out, only for shutting off.
Hello, Sounds like you have a drive motor/gear assembly malfunction,this type of failure is costly to repair.
Best Regards, Russell
Oct 29, 2007 | Kodak EasyShare DX6490 Digital Camera
Braun 9595CC Electric Shaver Logo
880 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
