Question about Panasonic DMR-ES10 DVD Recorder
Tuning tv stations for panasonic dvd recorder DMR ES15
How do I tune in tv stations on the above dvd recorder.
  • Anonymous Dec 31, 2008
    setting cable box from above unit
  • 3 Answers
Set your TV to channel 3 or 4. Then press TV/VCR which is above the button on the bottom right of the remote. Then you can tune in TV stations from the unit.
Posted on Aug 24, 2008
How do you re-tune the panasonic DMR E85H DVD Recorder. I have done exactly as it says in the manual and still it does not find any channels? Is it digital?
The tuner in the DMR-58H is a NTSC tuner (analog). Unless you have a low power station in your area, you will need a digital-to-analog converter box to record OTA stations. It can record analog cable without a box as well. (Digital cable will require a box.)
The manual for the DMR-E85H is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/DMRE85H.pdf .
I hope this helps.
(at least in my area there is only one station broadcasting an analog signal; it is a low-power transmitter and thus wasn't required to upgrade to digital with the rest of the stations.)
Mar 27, 2012 | Panasonic DMR-E85H DVD Recorder
I have tried tuning in my dvd recorder in the reset menu, but after the scan process a message appears "Check aerial connection. Help, what am I doing wrong?
make sure aerial is in dvd recorder press functions move down to others press enter move down to setup and enter highlight tuning move right and down to auto setup reset and enter
tou will see a warning message move to yes and enter the dvd recorder will start tuning and a list of all the stations that been found will be displayed after that it will start to scan for analog stations( BEEN TURNED OFF) once finished
picture will be displayed
if no list was seen when tuning in digital stations then make sure dvd is digital
and to check aerial put direct in to didgtal tv and retune tv
Dec 16, 2009 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES15 DVD recorder startup failure
The unit failed during self check, probably the power regulation board. A check by a qualified TV/VCR repair person is in order.
Nov 20, 2009 | Panasonic DMR-E55 DVD Recorder
HOW TO INITIATE SET-UP PROCEDURE FOR 2ND HAND VIDEO/DVD PLAYER
You should have the main aerial going into the dvd and then a black flylead going back into the tv.If you go into the on screen menu you find a set section so you can re-tune the stations.
Aug 17, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
How can i connect the dmres15 to my cable box, dvd/vhs player
Yea I have the same set up and did the same thing as that your trying to do and what you have to do is run both the cable box and the VCR through your TV using the inputs. As well as a PS2 running through imput 3.
Hope I helped
Jan 30, 2009 | Panasonic DMRES15 DVD Recorder
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
DMR-E50 DVD recorder versus DMR-ES15 are these equivalent recorders
The DMR-ES15 is a later model (around 2006/07) than the DMR-E50 (2003/04), but essentially both should do the same job so technically - a good equivalent in terms of recording and same brand so yes. The connections on the rear (of the replacement recorder) should suit and work with your other devices just as the old one did.
According to some other online reviews, the DMR-E50 has had a few issues with recording, and finalizing certain discs.
I'd say go for it - accept the replacement - as long as it comes with some kind of guarantee, works fully and has all the accessories (including remote, instructions etc.) you should be good. Contact the store and seal the deal.
I hope you can get this in time for Christmas.
Dec 21, 2017 | Panasonic DMR-E50 DVD Recorder
Panasonic dvd recorder dmr ez47veb
If your cable is connected with just a scart lead (in AV2) you just put the recorder onto the AV2 channel. You need to connect the cable decoder to the recorder via an arial lead to be able to tune it in but there is no need just use the AV channel.
Dec 03, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-ES10 DVD Recorder Logo
289 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
