Question about Brother MFC3820CN Print Server
No setup disk
Have printer and no disk to run first as it request.
How do I download and install the full driver and software package usinga local connection? USB (Windows 98, ME, 2000, XP)
Description of Solution 200000018870
To download and install the full driver and software
package
from the Internet, complete the following steps:
1. Make a temporary directory on your HDD to save the downloaded self-extracting file (e.g.. C:\bront). To make a temporary directory on your HDD, follow the steps below:
a. Click on START ->
MY COMPUTER or Double click on MY COMPUTER on yourdesktop.
b. Double click on your local disk drive (e.g. Local Disk (x:), where 'x' is the letter of your local hard drive)
c. Click FILE -> NEW -> FOLDER
d. Type BrotherXXXX to rename the folder
and press ENTER. (Where XXXX is the model of your Brother machine).
2. Open your Internet browser and type http://www.brother-usa.com/downloads on the address bar.
3. Choose your Product Group, Model, and click VIEW DOWNLOAD.
4. Click on the
link under YOUR RESULTS.
5. Under STEP 1: SELECT TYPE select DRIVERS.
6. Under STEP 2: SELECT OS, select your operating system.
7. Under STEP 3: SELECT LANGUAGE select ENGLISH.
8. A SEARCH button will appear after you select your language.
Click on the SEARCH button.
9. Locate FULL DRIVER AND SOFTWARE PACKAGE and click on MORE INFORMATION...
10. On the next page click on the DOWNLOAD button under FULL DRIVER AND SOFTWARE PACKAGE.
11. On the End-User License Agreement for Brother
Software page click onI ACCEPT.
12. Click SAVE.
13. You will be prompted again to save the file. In the Save In dropdown, choose the folder you created earlier BrotherXXXX, then click SAVE. The drivers will download.
To install the full
driver and software package, complete the following steps:
1. Unplug or turn off the power to the Brother machine. Make sure the cable is not connected to the Brother machine.
2. On the computer click on START -> MY COMPUTER or Double click on MY
COMPUTER on your desktop.
3. Double click on your local disk drive (e.g. Local Disk (x:), where 'x' is the letter of your local hard drive)
4. Locate the folder you created earlier labeled BrotherXXXX and doubleclick on it.
5. Locate the file
you downloaded and double click on it.
6. It will launch a ZIP SELF DECOMPRESSION window, click on DECOMPRESS(X).
7. You will get a message stating: The decompression process was successful. Click OK.
8. By doing so, the decompression window
placed another folder labeled SETUPXXXX (where xxxx = your model) in your folder. Double click on this folder.
9. While holding the SHIFT key, double click on SETUP.EXE. (.exe may not be displayed) The installation will begin.
10. Choose STANDARD
of LOCAL depending on your model, and then click NEXT. The installation continues.
11. When prompted with the Connect Cable screen, connect the cable into the Brother machine and your computer.
12. Turn on the Brother machine. The installation
should automatically continue.
13. When the On-Line Registration screen is displayed, click NEXT
14. Choose YES, I WANT TO RESTART MY COMPUTER and click FINISH to restart your computer. You will need to log back in with Administrator
rights.
After restarting the computer, the Installation will be complete.
Posted on Aug 21, 2008
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
Downloaded setup software. After the "unkown pulisher" message appears, application simply stops running
In this case i would request you to not to use the set up cd and insted download the utility and run the set up . The following link will guide you through the steps:-
http://kb.netgear.com/app/answers/detail/a_id/640
Dec 06, 2009 | NetGear PS121 Print Server
Netgear ps121 won't print
Possible reason why you cannot print with the print server is because the computer is not getting a valid IP from the router or a firewall is installed in the computer. You have to disable all firewalls installed in the computer.
For the print server setup, please follow the steps below:
Note: Before setting up the print server, make sure that you can print when printer is connected directly to the computer.
1. Wire the print server to router. Check the lights on it. It should have the ACT light on and the Error light off.
2. One way to test if the printer would work with the print server is to reset the print server for 3 to 5 seconds while it is powered on and after you release the button, the printer should automatically print the IP address of the print server.
Note: If the printer did not print, there is a possibility that they are not compatible. However, you may still continue to try to set up the print server.
3. Install the PS121 software.
a. Power on your computer, let the operating system boot up completely, and log in as needed.
b. Insert the Resource CD for the PS121 into your CD-ROM drive. The CD main page shown at the right will load.
c. Click Install Software.
d. Click Next and follow the software installation utility prompts to complete the software installation.
e. When prompted, restart your computer to complete the installation.
f. When your computer restarts, click Finish to run the Print Server Setup Wizard.
4. Run the Print Server Setup Wizard to Set Up a Fixed IP Address for the PS121.
a. The Print Server Setup Wizard screen should be displayed.
b. Click Next to proceed. The Print Server Wizard will now search your network for the PS121. If the Print Server Setup Wizard cannot find your PS121, check the network connections and status lights on the PS121.
c. The “Server Name” and the “IP Address” your network assigned to the PS121 are displayed. Click Next to proceed to the device name screen.
d. You can enter a descriptive Device Name and Domain Name or accept the defaults. Click Next to proceed to the IP Address configuration screen. The Print Server Wizard displays a recommended static IP address setting for the PS121. This is usually fine.
e. Click Next to proceed.
f. Click Finish to exit the Print Server Setup Wizard. This completes the configuration of the PS121 for operation on your network.
g. Click Yes to run the Add Printer Port Wizard. Follow the instructions in the next section for using the this wizard to set up each computer to use the PS121.
To set up each computer to use the PS121, please follow the instructions below:
1. Use the NETGEAR Add Printer Wizard to set up each PC to use the PS121.
a. When the Print Server Setup Wizard finishes, you are prompted to run the Add Printer Port Wizard. Click Yes to proceed. Alternatively, from the Windows Start menu NETGEAR Print Server program group, you can run the NETGEAR Add Printer Wizard.
b. After a short delay while the software searches the network for your PS121, the Printer Select window opens and displays the PS121 you have set up.
c. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
2. Set up the correct printer driver for the printer port.
a. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
b. Click Next to proceed to the Select Printer screen. If you see the exact printer model number listed as the printer model number from in the previous screen, click it to select it from the list.
c. If prompted, print a test page to verify operation of the printer and the PS121. Then, close any remaining Add Printer Port Wizard or Windows Add Printer Wizard windows.
Use the NETGEAR PS121 Mini Print Server Resource CD to run the Add Printer Port Wizard to set up each PC on you network that you want to use with the PS121. Select the port you added
You may also use the links below as your guide to troubleshoot the print server:
http://kbserver.netgear.com/kb_web_files/n101269.asp
http://kbserver.netgear.com/kb_web_files/n100033.asp
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Model number of router
2. Model of printer
3. Operating system of computer/s
May 01, 2009 | NetGear PS121 Print Server
I am trying to install a Lexmark, 3in1 p6210
Before plugging in the USB cable you need to install printer software.
If you have the original printer disk install software from disk.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Mar 01, 2009 | Lexmark Computers & Internet
Can't find HP Photosmart 7150 driver during setup
check here.
Answer number 7 helped me when i had the same issues with the samsung ML-2010.
I installed the printer localy and then followed the sugestions at this link.
changed the server to a static ip
activated the required windows uttilities
changed the printer settings
http://www.fixya.com/support/t299506-issues_printing_dpr_1260
hope this helps.
Jan 13, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Printer lexmark z43
Lexmark does not distribute replacement install disk for all models.
Contact Lexmark here, to see if the disk for your printer is available.
Afterdownloading,findthefile,doubleclickonthe file, then if you get introubles,follow theinstructionsbelowtoreset and reinstall drivers:
  • Download driver from website and run the file.
Note:someprinterdoes not work on Vista, if you do not find any driver downloadfor Vistaon your model page, that means your model is not Vista compatible.
Oct 18, 2008 | Computers & Internet
D-Link DP-301U Print Server
try to do a normal install first. once that works you'll be able to use the driver that is installed to install via the print server.
Jul 30, 2008 | D-Link DP-301U (790069251979) Print Server
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
To install hP psc 1315 on the D-link dp-300u
You might try to browse to that disk and see if there are any setup files (usually named setup.exe or install.exe). I've seen some drivers don't need to be installed by an installation program not by the new hardware wizard.
Feb 08, 2008 | D-Link DP 300U (DP-300U) Print Server
Brother MFC3820CN Print Server Logo
342 people viewed this question
Top Brother Computers & Internet Experts
ka4iup
ka4iup
Are you a Brother Computer and Internet Expert? Answer questions, earn points and help others
