check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio
(1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always
use the proper oil/gas mix. If you do not, your engine will suffer rapid,
permanent damage.
(1 gal.) Gas to 3.2 oz. Oil).Do not use old or stale oil/gas mixture. Always
permanent damage.
First check that your Mantis needs an oil/gas mixture, most of the newer Mantis tillers have four-stroke motors meaning they have oil in the crankcase and use straight gas. If your Mantis needs oil mixed in the gas use a 50:1 ratio. That's usually 2.6 ounces of two-cycle oil (it's sold in bottles that size) to one gallon of gas but read the oil bottle to get the proper mix ratio.
Generally speaking, if there is a place on a gas-powered device that is labeled "gas" & a separate location labeled "oil" than you will need to use a 4-cycle oil for that machine. If there is just a place to put gas, you would use a 2-cycle oil; however, you would need to read the directions/manual to find out the correct proportion of oil to use, because you will have to MIX the appropriate amount of oil with the correct amount of gas, making a oil/gas solution that you would use for that specific device.
The Left knob needs chain oil. Available in most hardware stores. The right is gas mixed with 2 stroke motor oil. Usually a 50:1 mix. Ie. 50 parts gas to 1 part oil. 2 stroke oil comes with a built in measuring tool and directions printed on the bottle.
