Turning off the touchpad Presario v4000
I have yet to find a solution to turning off the touch pad while a mouse is in use. When I go to the control panel and click the mouse icon, I am not presented with option to adjust or turn off the touch pad. Any ideas?
I have a Compaq Presario CQ62. When typing anywhere, the cursor randomly jumps to another spot in the text and continue inserting text there. How do I correct this?
This typically happens when the typist's palms touch the touchpad, which the pad treats as a mouse click. See if the cursor is jumping to where the pointer is.
Most touchpads have a control panel (usually part of the MOUSE Control Panel) where you can reduce the sensitivity (or disable) the left click function from tapping the touchpad.
Apr 20, 2011 | HEWLETT-PACKARD Compaq Presario CQ62210US...
Compaq Presario CQ50 + over sensitive touch pad CONTINUED
try SYNAPTICS pointing device in mouse settings
Please rate my help++++Thanks for using FIXYA
Jul 31, 2010 | Compaq Presario Notebook
Try the mouse settings in the control panel, also try uninstall any touchpad software and remove any touchpad software from running when the pc boots.
To do this either type msconfig into the run/search box or a program like cc cleaner under tools/startup
Jul 31, 2010 | Compaq (153515-001) Touch Pad
Compaq presario cq60 labtop- the touchpad mouse goes crazy!
os? vista, 7, x64??? ok lets get to a base point. you had a different mouse, is it still installed? Is the dongle still plugged in? are the drivers loaded? uninstall drivers in control panel. remove all traces of every other mouse, pad, pointers, etc from your cq60. in device manager you should show Synaptics PS/2 Port TouchPad under MICE AND OTHER POINTING DEVICES. if after reboot the touchpad is still not working then right clock the Synaptics PS/2 Port TouchPad in the device manager and select uninstall. reboot. let me know when you get to that point.
May 21, 2010 | Compaq Presario CQ60-212US Notebook
I am using my phone to ask this question.
the touch pad is usually controlled by synaptic.
To turn it on back, press start menu from your key board and scroll to control panel.
From control panel, use the tab button to select the icons on control panel and go to mouse.
From mouse, use your keyboard to control to device settings.
From device settings, you would see synaptics touch pad, then press enable and that's all.
You touch pad would then be enabled again.
All the best.
Jan 05, 2010 | HP Compaq Presario 2200 Notebook
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
Turned on my v2000 and the mouse pad is dead, wireless mouse works fine,
try reinstalling driver for touch pad. also do registry check sometime your registry gets scrambled and you lose devices as a result. run a registry program first. u can get one at www.majorgeeks.com for free. if that doesn't fix ya up reinstall the driver for the tft pad or mouse pad as u called it
Sep 21, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario CQ50 touchpad won't work.
Click on Start menu, click Control Panel, under Hardware and Sounds click Mouse. Once the mouse window is open click the last tab that says Device Settings. Make sure the Synaptics TouchPad V7.0 is Enabled. If it's not, then enable it by clicking at enable. Also double check your speed on the mouse pad to make sure it's not set to slow.
Mar 26, 2009 | HP Compaq Presario CQ50-210US Notebook
System freezing when touchpad not being used.
This will be one of three things; 1- a driver glitch with the touch pad. Uninstall the drivers for the touch pad from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. You might also look at Compaq's support site for any updated drivers or patches for the touch pad. 2- You may have a loose connection. Remove the keyboard, check and clean the touch pad connection/connector. 3- A faulty touch pad. If the other two don't work, then disconnect the touch pad and try using the machine with an external mouse. If this works, then the touch pad has malfunctioned and needs replacing. Ty these and let me know.
Aug 01, 2008 | Compaq Presario V4000 Notebook
TOUCHPAD
go to mouse setting under control panel.
You will find a place to turn it off.
Dec 01, 2007 | Compaq Presario M2000 Notebook
Open Questions:
Computers & Internet Logo
334 people viewed this question
Ekse
Alun Cox
