Question about Lucent PARTNER18 Corded Phone
Unprogrammingf a number from a phone
Two lines
    Champion:
  • 211 Answers
Press Feature 00
Select the button
Press second row last button to reset
Feature 00
Posted on Jun 17, 2009
Why does only one line work if we have two lines for the same contact number?
Sorry but any phone company I know of there is only 1 line per number . the second line must have it's own number to work . CALL your phone company
Oct 11, 2016 | NEC 1100009 6 Handset Landline Telephone
I have tried every configuration of the wiring I can think of. I have 2 jacks and a Ring Selector for the fax machine.
What is the make or brand/model of the phone you are referring to? Does it has a line 1/2 selector or a ringer selector on the panel?
Maybe the phone you have has a selector on its side.
I need more info.
Best regards.
Sep 01, 2015 | Lands Phones
How do I find out a direct phone number on a phone extention
Using the Feature *0 check the buttons on your phone. All trunks or lines will show a line number at the beginning of the display. This will tell you which buttons are trunks or lines on your phone. If you're not using a PRI with DID numbers, you can press the line or trunk button and call your cell phone for the caller ID. If you are using a PRI with DID numbers, you will need to contact your phone system administrator to get this information. A line or trunk can be programmed to only ring on one phone and not be in a pool for out going calls making it a private line.
Dec 02, 2013 | NorStar Meridian M7310 Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    We have a Norstar M7310 phone system. I had to replace one of the phones and the lines ring in on different line numbers than the other phone did. ex.. on original phone line 1 was 555-555-555 and line 2...
    Although I can't walk you through it step by step here, basically heres what you need to do. (if you're somewhat familiar with system programming you might be able to do this)
    Put the original phone back.
    Login to your system programming and turn the SET RELOCATION feature to NO.
    Then swap the phone with the new one.
    May 10, 2011 | NorStar M7310 Corded Phone
    I have 3 lines they will not ring up when you are on the line no one can call they get a busy singal but the other line work when you dial that number
    Hunt groups are set up by the service provider and not related to the phone system. In a 3 or 4 line hunt group, you're given a pilot number and 2 or 3 other lines. In some exchanges, you can dial any of the numbers and they will hunt to the rest of the numbers in the group....it's very rare. Instead, you must always dial the pilot number and each line is tested, with the first idle line being rung.
    If your callers are getting a busy when the first line is busy and the other lines are idle, call the phone company and discuss your telephone plan. Tell them your lines won't hunt and they'll tell you why or fix it.
    Carl
    Nov 14, 2009 | AT&T Lucent MLS-12D Phone
    I need an extra line to ring on my phone
    First, you'll have to know what the line number is in the system for the new line.
    To get the line port number, on the set/s that the new line appears on press feature *0 and the the new line.
    The display should say for example L025:LINE 05.
    The port number of the example is port 025.
    write the port number of the new line down for future reference.
    Programming2.gif is done on M7310, M7324 and T7316 sets.
    To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
    The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
    At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
    The display should sat LINE ACCESS
    Press the show key (top right arrow) .
    The display should say LINE ASSIGNMENT.
    The display ask for a line number. press list
    The display should say line 001: appear& ring
    press next key (lower right arrow)til you see the line port number you wish to program
    The display should say line 0xx: appear only
    press the Chng key till it says appear & ring
    press the release key when finished
    Sep 29, 2009 | Nortel Meridian M7208 Corded Phone
    Need to change the phone number assigned to a line
    Hi Amy,
    Ok ~ first to change the incoming line to a phone, goto the phone and do a:
    -> FEATURE * 0,
    -> Press the line that rings on that phone... (this will be the target line number ~ maybe somewhere in the 145-256 range)
    -> now get into the system programming
    -> go to LINE and type in the number you've seen on the display
    -> enter and find TRUNK/LINE DATA
    -> enter and hit next till you see PRIMESET and change that number to where you want that number to ring to. Hit next, after changing number and hit REL to get out of programming.
    Now call the number to ensure it is calling to the correct extension.
    Mar 17, 2009 | NorStar Meridian M7310 Phone
    Nortel nt8b telephone
    Get on the line and dial 1800 444-4444 and when it answers it will tell you the number then hang up.
    Nov 07, 2008 | Nortel T7316E 2-Line Corded Phone
    Can't send texts
    The problem seems with the line in use. Please chek whehter any phone numbers are entered in the line 1 and line 2 by going to the phone status listed in the setting options then select  the active line and enter the phone number in the line you are using.Delete any other number from the active line if you are not usuing any other SIM with your phone. I am sure your problem will be solved.
    Aug 09, 2007 | Motorola Mobility RAZR V3i Cellular Phone
    Lucent PARTNER18 Corded Phone Logo
    23 people viewed this question
    Top Lucent Lands Phones Experts
    Paul C.
    Computer Repairing
    Computer Repairing
    Michael Galve
    Michael Galve
    Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
