My printer keeps printing the same thing over and over, and also without even starting it.
    Champion:
    Scholar:
  • 209 Answers
Unplug both connections of your printer, the power and the cable connected to the computer. Wait a few minutes. Then, plug the cable to the computer, and after, the power.
Posted on Aug 20, 2008
Why is it printing only from both ink cartridges
Without knowing the printer's make or model, I'll take a quick guess. Most color printers will actually use a little color ink even when printing black-only. The color is used to keep the nozzles clear. You will not be able to print when either of the carts goes empty.
Jun 11, 2015 | Office Equipment & Supplies
Printer keeps jamming even after clearing jam
Hi, most paper jams like this are caused by something inside the printer called a "pickup roller" which is a series of rubber tube/grippy things that are responsible for moving the paper through the printer. If these rollers are dirty or worn down, they don't grip the paper properly and end up causing jams. In larger, more expensive printers, they have maintenance kits that you can buy to replace rollers, fusers, and other commonly replaced parts - but it's probably not practical for this model of printer. You may want to try opening the printer as much as you can (without removing screws) and using compressed air and a lightly-damp-with-alcohol cotton-swab to clean the rollers and other parts that touch the paper.
Jul 27, 2013 | Brother HL 2270DW Laser Printer
Paper jam error without a paper jam
sometimes the printer keeps telling you one thing first you have to read again your instruction carefully or sometimes its just the position of your printer where the paper was
Apr 17, 2012 | Office Equipment & Supplies
Print WITHOUT colour cartridge
If you right click the printer in the Printers section of the control panel and select printer preferences, there should be a tab called maintenance. In this tab, you should find a setting called Ink Cartridge Settings. Once you click on this setting, click black cartridge only. This should allow the printer to only use the black ink and therefore you won't need color.
If you have any other questions or this doesn't solve your issue, let me know.
Jan 10, 2009 | Canon MX300 Office All-In-One Printer
Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Dec 12, 2008 | HP PSC 2175 All-In-One InkJet Printer
THS Error on warrantee printer tally serial printer
The print head operating temperature may need to be calibrated for the operating environment of the printer.
The print head cable may be damaged or incorrectly plugged into the print head or logic board.
The print head may have a fault.
There may be a fault on the logic board or interconnect board
The first thing that I would recommend doing would be to calibrate the print head operating temperature, this can be done in the following way;
·Start with the printer powered OFF and at normal room temperature
·Hold down the ONLINE and SETUP button and power the printer back on
·Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
·Press the button under ‘TEMP CAL’ (button 3)
·Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
·Then press SET to save the settings.
Once the Temperature has been recalibrated power the printer OFF and back on again, this should resolve the problem.
If once the print head temperature has been calibrated the printer displays ‘Head Hot’ or alternatively displays a ‘THS’ error this indicates the printer has a hardware fault. The next step would be to identify which part may be causing the problem.
I would recommend first checking the carriage cable to ensure this is not damaged and makes good contact at each end. Then you would need to look at a logic board or print head failure.
Apr 09, 2008 | Tally Matrix T2280 Printer
Printing Envelopes
Be sure you have set the PRNIT PREFFERENCES on your program that you are using to print the envelope to accept a #10 envelope and not 8.5x11 paper, you ALSO must set the PRINTER PREFERNECE to MANUAL FEED and not automatic so it won't look to the paper tray.
//CowboysFanZ
Mar 28, 2008 | Dell 3100cn Laser Printer
Canon pixma ip6000d
First you need to check that the printer has the same problem with a new cartridge, otherwise may be a cartridge problem. After this try doing a nozzle cleanup. You will find the option on printer properties in control panel, or opening canon software from start menu. If after this you still have the problem then you should open the printer and clean the waste ink well and printer head.
Feb 15, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Keep Printed Documents
Deletes and reinstall print drivers, does'nt sound like a printer problem, more software issue, driver reinstall is my best bet
What are you printing from? ie program is?, and can you print windows test page OK?
Dec 19, 2007 | Brother HL 5140 Laser Printer
HP inkjet 1100 not printing yellow
Well if you want to damage your printer use alcohol. But if you want to make it work then pull the cartridge from the printer and run hot water on a couple of paper towels leaving alot of hot water in the towels. Put some thing under them to keep them from staining your counter top and then set the cartridge down onto the hotwater towel and let the hot water melt away the dry ink and in minutes you may be printing again if this is what it is. Be sure and use a dry paper towel to wipe off the ecess wet before you reinstall the cartridge.
Nov 15, 2006 | HP LaserJet 1100 Printer
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
