Question about Nyko Charge Station for Nintendo Wii
Battery Not Charging
My wii Rechargeable batter isn't charging. When I put the wiimote on overnight, and turn it on the next day, there's only one bar of power.
Please help!
  • 6 more comments
  • stingjc Aug 27, 2008
    Same for me. After placing my Wii remote on the charge station stand, the blue LED light (which indicates the Wii remote is charging) stays lit for approximately five seconds before turning off and returning to green even though my remotes are nowhere near fully charged.
  • Anonymous Oct 10, 2008
    i have the exact same problem....the says it it fully charged in about 3 seconds even though the batteries were fully drained! It does not connect via USB so that can't be the problem and it is clearly touching the rods because the light is turning on. I really don't want to get a new one
  • 2GameDorks Nov 02, 2008
    My daughter has the same problem. After a few sec. it says that it's fully charged but it's not. I got it for her less than a year ago. Nintendo sucks! I should of just forked up the extra cash and got her a ps3.
  • Anonymous Nov 28, 2008
    what did you do to wipe the green substance off?
  • aheathco Jan 08, 2009
    I put the remotes on the charge station and it almost immetely turns green signalling a ful charge. If I take them off and check the batter power it is in the red. The remotes often won't turn on at all and I have to open them up and take the battery in and out to get them to respond.
  • Anonymous Apr 16, 2009
    The Light turns green after like 5 seconds, but the wii menu says it only has 1 bar of power
  • aheathco May 11, 2010
    I also notice the greenish build up on the contacts of the battery. Not sure how you were able to remove it though...
  • b_berkshire
    b_berkshire Jan 07, 2013
    This happenes when u dont drain the batteries..like...if u dont play enough, how a the baterie works is it charges 2 sides and one side drains overtime and the other side doesn't so to drain thwe other side keep p;aying. just plug it in and when it turns to green taske it off and put it back on the stand do this for 1 hour and check to see if its charged.
I had this same problem and searched on the web for answers.... I could not find an answer; just complaints. I tried something that solved the problem! I noticed a greenish buildup on one of the three metal contacts on the battery. I wiped the green stuff off then the battery charged as normal.
The problem I was having (to ensure we have the same problem) was that the wii indicated the battery was out of power. I would put the remote in the charger and the indicator light would turn blue to show it was charging. A few seconds later the light would turn green to indicate it was done charging and was full. However, the battery was still empty. This would occur even if I left the remote in the charge overnight.
With the fix I listed above, the batteries now work as normal!
Posted on Nov 28, 2008
I have the solution to this!!! It was driving me crazy. When the battery goes totally dead, it won't recharge. What you have to do is get a 9 volt battery and two wires. Hold the wires on the battery terminals and tape the other ends to the +- terminals on the battery for about a minute. When you are done...put the batter into the remote and it should be charged enough to be chargeable again., Put it on the charger until fully charged.
Posted on Feb 20, 2012
To get build up on any electronic device - especially batter contacts, gently take a pencil eraser to the contact. this will remove any oxidization on the contact and allow for a full contact. using liquid on electronics is always dangerous - and may or may not be effective.
Posted on Jan 06, 2010
    New Friend:
The same happens to me its from not playing enough so the batterie desn't drain. How a batterie works is that it charges 2 sides and one drains over time and the other only drains if u play...so...when u put it on and after 5 min it turns from blue to green, just take it off the charger and put it back on, do this untill its charged. then msake sure u drain the batterie and not just plsy it once then walk away and use it again a month later or u will have to do this all over again hope I helped :D
Posted on Jan 07, 2013
  • 43 Answers
There are a few possibilities
1. if ur charger is connected to the usb port on the back of your wii, you need the power to be on, or put your wii on standby, (green or yellow power button light) to give power.
2. if thats not the problem, then the wiimote may not be connecting to the chargers metal bars, (where the back of the wiimotes metal parts have to touch the chargers metal parts. To help, take off the wii wrist strap so it can sit easily on the charger.
3.It may just be dodgy, return it to nintendo or the game store where you got it from and get a new one.
Posted on Sep 14, 2008
If you have two remotes, switch the battery!
Posted on Jul 05, 2012
    Problem Solver:
  • 3 Answers
(comment to solution 2): What did you use to wipe it off? I treid a paper towel, but that didn't do anything. Should I use a WET paper towel?
Posted on Nov 30, 2008
My wii remote would not work so i bought a new wii wireless sensor and it still does not work can you help please
Have you checked the battery in your Wiimote? It seems like a very basic thing to do, but sometimes the wiimote might not hold a charge if you placed the batteries in incorrectly. If your Wiimote is showing a charge, then you may have forgotten to sync up your wiimote with your sensor bar.
  1. Open the battery door to your Wiimote
  2. You'll see a red button on the bottom of the opened hatch, it says SYNC.
  3. Press that and the sync button on your Wii.
If that still doesn't work, check the connection of your wii sensor cable to your wii. Try pushing the cable in securely.
Mar 08, 2011 | Nintendo Wii Console
Tip
Broken or lost Wii sensor bar? No problem!
So for whatever reason, you have lost the use of your Wii sensor bar. Maybe the cat chewed it or you just moved and the kids are complaining they want to play a game and you have no idea what box it was put in. Either way, the sensor bar isn't as complicated as one might think. The bar is nothing more that a light of reference point. Simple. It has ordinary LED bulbs that emit a small light. The Wiimote's cameras pick up the light and with that, the Wii can figure out how the Wiimote is being held and how far you are ect. It's more than that but we're only talking about the sensor's job. With all that being said, you simply need a light reference point placed in the required position as the sensor bar. A number of things can be used from tiny lights or what I found was best, candles. Two tea light candles in place of the sensor bar 5-8 inches apart will work just fine. TRY IT FOR YOURSELF. Unlit, the Wiimote will not show on the tv screen. Light the candles and you now can enjoy your Wii again!! <br /> Hope this helps :D
on Sep 23, 2011 | Video Game Consoles & Games
Tip
Wii remotes no long respond (one or more remotes) - sync lost
Lately after firmware updates or power loss the Wii will un-pair from the Wiimotes. Some players don't know how to solve this problem. They assume it is the Wii or the batteries in the Wiimote but when they switch them or power off the unit, this doesn't fix it. Reason is that the Wiimotes need to be re-paired (re-synced). This Tip will explain how to do this.
1) In the front of the Wii there is a door. Inside this door you will find the SD card slot. next to the SD card slot there is a RED button with the word "Sync" on it. This is used to put the Wii in bluetooth discovery mode.
2) Take the first remote and remove the battery cover. Below the batteries is a small Red dot button. This is the Wiimote's connection button. First turn on the Wii then press and hold the Wii's Sync button for a few seconds to initiate Discovery Mode. Press and hold the Wiimote's button for a few seconds until the "Player Number" lights on the bottom of the front of the remote blink. The connection is complete when the Wiimote's "Player 1" light goes solid and the Wii will advance to the menu.
3) To re-sync (re-pair) the additional Wiimote's. Repeat the process but this time leave the Wii turned on. With each remote the next player light should turn on. Do this until each remote is synced.
on Feb 23, 2010 | Video Game Consoles & Games
My wii mote isnt working, I press the power button and the little squares at the bottom start flashing, then after a couple seconds it stops. It wont respond to the console.It has fresh batteries, so I...
I am sure the wii manual have this info to read but just in case you dont have the manual:
First you need to sync the Wiimote to the Wii, in the batteries slot is a red button, and in the wii's SD slot is another red button, touch both buttons (dont need to touch both at the same time but dont wait too much between each one) and try again moving the wiimote to the screen and testing it.
If all the blue lights turn off maybe your batteries are dead.
Sometimes old batteries drop acid into your wiimote circuit and might damage the wiimote, that happens frequently with alkaline or carbon batteries so is good to buy the rechargeable ones.
Nov 26, 2010 | Nintendo Wii Console
Wii remote is not charging. I have 2 remotes, one of them does not charge. Basically, when I charge it, it charges for a few seconds then it turns to the green light (meaning it's done charging) so it...
If you have had the "battery" for a long time, it could be that it can no longer carry a charge. Rechargeable batteries' charge grow shorter over time. If you still use the Wii/Wii U regularly, I suggest rechargeable AA batteries+charger (If you don't have them already). AA batteries work in other devices so even if you stop using the Wii, the batteries will still work in remote controls, clocks, flashlights etc unlike a WiiMote Battery pack.
Sep 10, 2017 | Nintendo Wii Remote Controller
I bought my son a Wii this past Christmas so it's not that old. The Wii remote finger pointer isn't working; however, I can power the remote on and off, use the "A" button, the home button, and use the "+"...
First you need to determine if the problem is your Wiimote, or your Wii's sensor bar.
You can check to see if your Wiimote is transmitting to the bar by looking at it through a digital camera (this allows you to see the infrared light). Turn everything on and view the tip of the remote through the camera, if it lights up: it's working, if it doesn't: you may need a new wiimote.
If it turns out your wiimote is working, then it probably means your sensor bar needs replacement. I think that is more likely (and less expensive)
Mar 29, 2010 | Nintendo Wii Console
Bought new wii remote and wont power up
The wii remote won't power up the Wii itself, or you can't get the wiimote to come on?
If it won't turn on the Wii, it may have to be synced with the system. Not really sure, though. But to sync it, take of the back of the wiimote(the battery cover) and open the little flap on the Wii. There should be red buttons in each. With both on(turn the wii on manually with the power button on the system), press both red buttons at the same time. Alternatively, you can go to the menu and sync wiimotes from there.
If the wiimote won't come on, make sure the batteries are new/charged.
Nov 26, 2009 | Nintendo Wii Console
REMOTES AREN'T CONNECTING TO WII CONSOLE
Try this:
Turn off your wii and unplug it.
Wait a few seconds and plug it and turn it on.
Open the cover in fron of the wii and push the red button for a few seconds.
Now take the lid off the back of your wiimote and below the batteries there is a red button, press it and the leds that indicate what number player you are should start blnking.
Press the red button on the wii again and now the light in the wiimote should stay on.
Test your wiimote.
Mar 17, 2009 | Nintendo Wii Console
Cannot get the gun sights to move in wii play
Ensure that your not too close and not too far from your TV, and make sure that your sensor bar is properly set atop (or below) the screen.
Aiming takes a minimal amount of movement once you get your cursor on the screen. Big motions are not necessary to move your sights around the screen - just little movements with the wrist. Once you find that sweet spot, you should get good experience with the Wiimote.
Finally, make sure the batteries in your sensor bar (if you are NOT using the one that came with your Wii) and the batteries in your remote are fully charged. To know if the batteries in your Wiimote are charged, the first time you press a button on the Wiimote after turning on your Wii, you'll notice that 1 to 4 of the blue LEDs will be blinking. If all four are blinking, the batteries are good. If only one blinks, time to replace them.
**NOTE: If you don't like my advise, that's fine. But please don't rate me a '1' just because my answer doesn't help. That's what 2 diamonds are for. Thanks!
Feb 04, 2009 | Nintendo Wii Play for Wii
I have the rechargeable battery pack on in my wii fit balance board. I the power keeps cutting out and it is saying communication is lost on the balance board, and to push the power button again. This...
If you remove the rechargable battery pack and put regular batteries back in, are you still having the same problem? If so, I would recommend returning the rechargable unit and replacing it.
For what it is worth, I've been using my Wii Fit board for nearly a month on 4 alkaline batteries and have not had any problems.
I recommend rechargeable NiMH batteries with a 15-minute quick charger. Always have four more batteries than you need in your machine, ie: if you have a Wii Fit, a Nyko Wireless Sensor Bar, and two Wiimotes, then you should have 16 batteries total (4 + 4 + 2 + 2 + 4 spare).
Jan 27, 2009 | Nintendo Wii Fit for Wii
Nyko Charge Station  for Nintendo Wii Logo
12,958 people viewed this question
Top Nyko Video Game Consoles & Games Experts
Douglie007
Bill Boyd
Kevin Liu
Kevin Liu
Level 1 Expert
Are you a Nyko Video Game Console and Game Expert? Answer questions, earn points and help others
