Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Washer wont spin
Mid 90's maytag top loader, darn thing wont spinn. seems to bind up?
any help is appreciated.
Its called the SUPPORT $150 is what they want for it
Posted on May 27, 2012
  • 639 Answers
Peace,
ngfam1 at your service,
1- maybe the belt is loose stretched or broken
2- may be the coupling from the trans to the agitator is broken
You seem to need hands on service!
A&E FACTORY Service is pretty good and nation wide
24/7 answering appointment setup for !
1-800-905-9505
Bless You,
ngfam1
Please give me the best rating here at fixya.com before you sign off!
Posted on Sep 03, 2008
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
My maytag hav2558aww wont turn on wash cycle
Possible that the grinding noise comes from the drum, irregular movement or broken paddles.
You can try and attempt only if equipped with a fundamental understanding of the working .
I shall give you some tips to this click 1..: Washing Machine
2. Replacing bearings
Jan 24, 2013 | Maytag HAV2558 Top Load Washer
I have a maytag alantis top load washer and it drains out put it seems it dosn 't spinn
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 20, 2010 | Maytag Washing Machines
Maytag neptune top load washer displaying letters "dc" and won't finish cycle
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&*@#$^
Mar 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water still in machine
Depending on how high your drain hose is some of the water after the final spin can drain back into the outer tube of the machine. This wont hurt anything but when not using the maching, not a bad idea to leave the door ajared to prevent the washer from giving off a bad odour,
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My kenmore elite three speed washer sounds like it is in a bind
I have seen clothes get between the inner and outer tub and restrict movement during spin and wash. This will require removing the outside case, call a service tech on this one.
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag top loader won't do the wash cycle
hate to be bearer of bad news, but the transmission is the culprit this time.
Jul 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
