Question about Philips 50P8341 50" Rear Projection Television
Problem with tv 50p8341 might have found the solution
i say you response in tv-forums about the problem with the coolant in a 50p8341 and you mentioned that you had parts for all the phillips tv
i am having a problem with my tv when i turn it on the tv buttons on the front turn red but the screen does not get power all i get is a green line going across the tv no sound me and my dad opened the tv he has some experience with tvs as he studied for electrician but that was long time ago so he is not sure of the solution we think it might be the flyback because he says that when you turn on the tv and you put a screwdriver close to the flyback cables you are suposed to get a spark because of the high voltage going trough the cables but we get no spark so i will like to know if you could give us a hand with this by telling us if you think that might be the problem and if you have the flyback for this tv
Thanks you very much for your time
  • dtmsinc Aug 20, 2008
    HOO AND PLEASE I DONT WANT THAT GUY FROM MAGNAVOXHELP.COM TRYING TO SELL ME HIS PRODUCT AS IF I DIDNOT KNOW THAT THE IC COST $5.99 AND HE IS TRYING TO SELL THEM FOR $32
    THANKS
    PS
    IF THE IC IS THE PROBLEM PLEASE LET ME KNOW (NOT U MAGNAVOXHELP)
    THANKS
    SORRY SLINE THE LAST COMMENT WAS SUPPOSED TO GO TO THE FORUM NOT U
    tHANKS
  • Philips Master
  • 8,617 Answers
The green line across the TV if its in the middle is usually loss of vertical deflection so that can shut the tubes down for protective purposes. Check the vertical output IC thats what is most likely causing the problem. The flyback is working if theres a green line across the middle of the screen.
Posted on Aug 20, 2008
Tv has a red tint
the most common cause would be the CRT coolant need replacement in the green and blue CRTs which make the red dominate. Replacing the coolant is the number one cure for that problem. Do not try adjusting the screens as that will only lead to more problems with a phillips. CRT coolant is all thats required.
Nov 21, 2011 | Philips 50P8341 50" Rear Projection...
Almost 10 yrs old, kind of like a slight fog over the picture. what do i need to do?
Ur tv need coolant replacement.Tries websites Tv repair World.com,Tvrepairkits.com MCMElectronics.com to buy this coolant replacement.
Mar 10, 2010 | Philips 50P8341 50" Rear Projection...
Whites are glowing
Ur picture tube require coolant replacement.This website have the coolant.Tv repair World.com.
Dec 10, 2009 | Philips 50P8341 50" Rear Projection...
Picture is not clear. Has a green tint and glow.
Repalce the coolant in the CRTs. You can get the Phillips CRT coolant replacement kit at www.tvrepairworld.com the kit contains the coolant and the CD with instructions
Oct 13, 2009 | Philips 50P8341 50" Rear Projection...
The tv is mostly red
replace the CRT coolant, as the green and blue get congealed and that causes the red to become dominate. You can get the Phillips CRT coolant kit at the following link which contains the coolant and the instructions on CD.
http://www.tvrepairworld.com/
Jul 18, 2009 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 green light
I believe its the vertical output IC. Diodes would tend to blow fuses . I would replace the vertical output and see if that takes care of the problem.
Aug 20, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50 in. Rear... Problem:
you need to change the coolant in the CRTs ( picture Tubes) and the set will get its color and clarity back.
Jul 07, 2008 | Philips 50P8341 50" Rear Projection...
FLUID CHANGE
http://www.tv-forums.com/forum/TV_Equipment_C4/Projection_TV_Forum_F24/Changing_CRT_Coolant_P15302
May 04, 2008 | Philips 50P8341 50" Rear Projection...
Need to replace the glycol oil (coolant) in our rear projection tv
You can get The Picture Tube Coolant at the link here Matt electronis. they offer quick shipping, And if you need instructions on how to do the proceedure , please let me know
http://www.matelectronics.com/cgi-bin/ss000001.pl?SS=coolant&PR=-1&TB=A&SHOP=&ACTION.x=16&ACTION.y=9
Jan 12, 2008 | Televison & Video
Philips 50P8341 50" Rear Projection Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
