Question about Acer Aspire 5610-4648 Notebook
Wireless Adapter & Broadcom Network Adapter is not getting install
I have aspire 4710z , device manager is showing Network adapter error and wi-fi is not getting start i tried alot but failed to solve it. plz give the appropriate driver name and links from where i can get them.
  • Anonymous Aug 23, 2008
    yes
Hi, I have acer aspire 5738. I installed wi-fi
Just search and download cobra driver pack, it will scan and update your driver to a correct working one.
Aug 09, 2013 | Acer Aspire 5500 5570-2609 Laptop
Can't get my wireless to work
For that make sure wireless network adapter driver installed in laptop.
For that right click on my computer icon thne click on proeprty then hardware ->device manager.
It shows all driver in list.
Make sure wireless driver is there and Enable to.
Make sure WI-FI switch is turned on in laptop.
Then right click on my network places and then click on proeprty you can see your wireless network adapter there then right click on it then click on "view available networks".Then connect wi fi.
Nov 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
Hi experts! I recently purchased HP tx2-1025dx with Broadcom 4321AG 802.11a/b/g/draft-n Wi-Fi Adapter preinctalled. have no idea why my connection (I have cable) is so slow not only home, but at Wi-Fi...
Wireless N is not standardized yet. The design(features & functions) will depend on the manufacturers. It is not advisable to use wireless N products from different manufacturers since they have it designed differently.
To maximize the features & functions of wireless N you need to have compatible devices. Meaning, I you're using let's say Linksys N router you need to use Linksys wireless N adapter.
Jun 08, 2009 | Broadcom BCM5705 Network Adapter
Broadcom 4321AG 802.11a/b/g/draft-n Wi-Fi-Adapter datasheet
that depends on the network traffic to and from your computer..but it will never be 0 once connected..
Jan 14, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
My Wireless Broadcom Adapter is not properly running
here is the drivers and utilities page for your laptop.
http://support.acer-euro.com/drivers/notebook/as_4310.html
just download new drivers and restart.
go to your os then drivers and utilities tab then wireless broadcom and
lan broadcom.
Dec 26, 2008 | Computers & Internet
Wireless no longer works
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Nov 23, 2008 | Compaq Presario Notebook
Problems with wifi lan configurantion.
hmmm... is the wireless card listed in the device manager at all? even as a yellow question mark?
do you have a USB wifi adapter you can test on this computer?
Mar 29, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Acer Aspire 5610-4648 Notebook Logo
132 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
