Question about Compaq Presario Fan
Fan won't run
I just replaced RAM on a Compac Presario 3000, now the fan isn't running.
The fan probly git over heated and burned out. u need to get a new fan. dont get a cooling pad.
Posted on Jul 31, 2009
    Scholar:
  • 133 Answers
This is strange. It is very likely that since the ram went bad and you replaced it , and now the fan does not work it is a very good indication that you might be in need of a new computer. If you are able to , see if you can replace the fan yourself and go from there, otherwise your computer may have seen the light above :)
Posted on Aug 20, 2008
Why my A/C condenser fan won t stop running, dodge ram 2008
To clarify, the compressor and fan will run in defrost mode. The compressor and fan runs to dry out the air blowing onto the windshield.
Now if the condenser fan runs in "heat" you may have a problem with the fan relay or the main controller.
Sep 25, 2014 | 2008 Dodge Ram Pickup 1500
Compaq Presario SR1610NX won't turn off, and won't
The problem could be a hardware problem.
You can try removing the ram to see if it's faulty otherwise I am afraid you are unlucky because could be a motheroard problem so the only solution is to bring your laptop to repair service.
Feb 05, 2013 | Computers & Internet
I was changeing the memorey now went to turn back on and it is not comeing on power supply fan runs thats it
Hello Lisa,
Make sure that you are using a compatible RAM. Also make sure that you placed the RAM properly in place. You can try removing it and then replacing it back again, if possible on a different slot.
If it still won't work, tell me if do you hear any beeping sound?
Nov 05, 2011 | HP Compaq Presario SR1520NX (PX801AA) PC...
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
Compac Presario F700 makes constant humming noise
Sounds like its the fan . The more demand you place on the system makes it run hotter so the fan speed automatically increases to compensate
Jan 19, 2010 | Compaq Presario 700 470024-192 Notebook
I have a Compac Presario, running VISTA. When
simply disable the automatic update service by following these steps.....
start | run | services.msc | automatic update
stop ...and disable it...click ok
and close the service manager....
then try to shutdown the machine ....
Dec 30, 2009 | Computers & Internet
Compac laptop opens programs too slow.
It probably is due to Spyware, Malware or other infections.
Go to malwarebytes.org and download the free scanner.
Run it and see.
Nov 17, 2009 | Computers & Internet
I have a Compac Presario 5000 series computer which appears to be locked in safe mode. Doesn't recognize mouse so can't access anything. Running ME. Any suggestions?
I can help you recover files and recommend a place to purchase XP and upgrade the memory so it runs well, I had one like this and had the same problem, I recovered the necessary files, put XP Pro on it with more RAM and it it still running roday as a voip server in a lawyers office. Live chat or see my ad for help.
I CAN solve this problem.
Jim
Aug 14, 2009 | Compaq Presario 5000 PC Desktop
Compac presario v2000
try reseating the RAM,if that doesn't work replace the RAM
2 Beeps = bad RAM
Mar 24, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
237 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
