Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
Western Digital 500gig External Harddrive. Power up troubles.
The hard drive portion of this product stopped powering up. If i plug in the power it will cycle up and then after about 7 - 10 seconds it shuts itself back off. If I connect it through the USB cable to my laptop it will read it as being present but no power to the hard drive keeps me from opening it. Any help would be greatly appreciated.
  • 3 more comments
  • Digitahl Oct 27, 2008
    I have the same problem except that my power turns of almost immediately, I can see the light come on for a brief moment, thats it. Any help greatly appreciated.
  • ejtrinidad Nov 20, 2008
    i have the same problem now.
    I have winXP.
  • Anonymous Jan 13, 2009
    To Bad.. I've just had the same problem
  • Anonymous Jan 18, 2009
    Mine just shut off and wont turn on, my mac (OS X 10.5) seems fine otherwise. it just shut off moments ago, had it for a year with no probs
  • johndeere621 May 04, 2009
    Hi there this isnt the case as when the external hard drive isnt connected to the computer id does the very same thing just cuts it off after a few seconds any other thoughts??
    Sergeant:
  • 300 Answers
This is a bit tricky , you'll need to tell my what operating system you have ,
more than likely sounds like windows power management is turning the drive off
check your power management settings.
if thats not the case just let me know.
shalom
Posted on Sep 11, 2008
Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Regards
Aug 09, 2010 | Western Digital 250GB MyBook External USB...
Harddrive not being acknowledged by laptop
This is a hard one, as 7 is so new. But it sounds like the very next thing to do is to plug the drive into another computer to see if the drive is working properly. If it works well, make sure that your drive is not trying to grab a drive letter that is already being used by another device. Do a search on the MS website for known issues and instructions on how to check for drive letter management issues. Good luck.
Feb 26, 2010 | Western Digital My Passport Essential...
Power loss in external harddrive
Hi mjcole,
Couple things. What model WD drive do you have? Plugging the laptop adapter into the drive chassis may have fried the chassis. You can buy a new chassis and put your drive into it, or you can buy a new power supply in case the one you have has gone bad and you did not realize it. Not likely though.
The power requirements are very specific and the laptop power supply may have been to much for the WD drive.
Feb 12, 2010 | Western Digital Elements powered by WD 320...
Bought 320GB Scorpio Blue 2.5" and slipped it into my macbook. When questions came up I'm afraid I answered incorrectly. Screen turned to a single icon - circle with line through - and I can't do anything...
You will need to plug the harddrive into a windows based pc todo a format or run BOOTCAMp on your Mac to gain a windows portion. However the easiest way is using a low lever formating utility form western digital : http://support.wdc.com/product/download.asp?lang=en
Oct 21, 2009 | Western Digital Elements powered by WD 320...
Western digital 500GB harddrive not switching on
Did You Try Using The Included AC Adapter To Power It Up
Jul 18, 2009 | Western Digital 500GB My Book World...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
Jan 26, 2009 | Western Digital My Book Essential Edition...
Western Digital 500gig external drive
it sounds like hard drive data may be corrupted. This could be due to a number of things. A power failure, hardware failure etc.. If the drive will not even let you access it you'll probably have to just format it im afraid.
- John
Jun 23, 2008 | Western Digital 500GB My Book World...
HP Computers using XP will not show drive to which Western Digital 320GB external harddrive is connected
Your usb device could be finished or your USB ports may not be strong enough/ enough power to run the device.
Jan 13, 2008 | Western Digital 320GB MyBook External USB...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
981 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
