Question about Sharp AR-235 Copier
U2-40 What does error u2-40 mean on a sharp ar-235?
  • 1 more comment
  • sentinelbiz Aug 20, 2008
    How do i get it fixed? Can I do it or do I need to call a tech?
  • Anonymous Dec 01, 2008
    COD. ERROR U2-40 SHARP AR-235
  • Anonymous Jan 24, 2009
    how do I fix a U2-40 error code? In plain english please, I have no idea what to do.
  • 24 Answers
Try a reset with sim 16 first, it just may go away
Posted on Sep 12, 2008
  • 4 Answers
Crum chip communication error!
Posted on Aug 20, 2008
  • Leonidas Hidalgo Aug 21, 2008
    yes! you do have to call a technician
3 Suggested Answers
marsrover
  • 682 Answers
SOURCE: request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Posted on Apr 19, 2008
randula7
  • 78 Answers
SOURCE: What does error code L6-10 mean on a Sharp AR-235
L6-10 Content Polygon motor lock detection
Detail
It is judged that the polygon motor lock signal
is not outputted.
Lock signal is checked in the interval of
10sec after starting the polygon motor, and it
is judged that the polygon motor does not
rotate normally.
Cause
The LSU connector or harness in the LSU is
disconnected or broken.
Polygon motor trouble
Check and
remedy
Use DIAG (SIM61-1) to check the polygon
motor operation.
Check connector and harness connection.
Replace LSU.
Posted on Jan 24, 2010
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
The motor lock signal is detected for 6sec
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
Replace the polygon motor.
Replace the MCU PWB.
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
Call for service error code u2-40 on sharp copier AR-M236
That means there is a bad CRUM chip or the developer unit isn't connecting properly.
Aug 20, 2011 | Sharp AR-235 Copier
Sharp AR-235 shows error H4-00, would like to know how to fix without costing me.
Noy likely you can fix this without replacing the fuser lamp H4 means the fuser lamp is not getting to temp. It cold be a fuse on the fuser unit,too. Checking with an ohm meter is only way to know which,
Feb 07, 2011 | Sharp AR-235 Copier
SHARP-235, F5-02 CALL FOR SERVICE CODE
Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service u9-99 what dos it mean and how can i
Sep 04, 2010 | Sharp AR-235 Copier
Sharp AR 235 error code E1-11
Abnormality on the IMC board.
Try resetting by pressing # / interrupt / c / interrupt.
punch 14 and ok / enter.
restart your copier.
if it doesn't work you will need a tech.
Jun 17, 2009 | Sharp AR-235 Copier
Request service manual for sharp AR-5316
Apr 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-235 Copier Logo
448 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
