Question about Intel D850MV Motherboard
Processor upgrade from 1.6 to 2.4
I have a Intel D850MV and upgraded the CPU from 1.6ghz to 2.4ghz.
I got the latest bios installed P15.
The problem is, why does it only run at 1.8ghz??
Could it be that the voltage is to low, but how can I change that? Not in bios anyway =(.
Tried SoftFsb, getfsb and many other like it, but they don´t support my motherboard.
Is there any jumper that I can move to get the voltage higher?
Hope there is someone that can help me out..
  • Taz Aug 21, 2008
    The following board revisions (AA numbers) support these processors: A56423-300 or later
    My AA number is 56423-301, so I suppose it should support thoose processors.
    Yes I know that it cant be changed in bios as I wrote earlier.
  • 2,351 Answers
Hi zmoonz,
you must be missing something. Please go over this Intel link:
Double check your board revision. Instruction / location for this is on the site above. Even though you have the correct revision no# the Pent 4, 2.4GHz CPU can only run with the correct revision (AA numbers) listed.
There are no jumpers on the Intel D850MV MB to help increase the CPU speed nor bios menu to help. Enter the bios. Open Main. This bios does not allow any CPU options.
Posted on Aug 21, 2008
Intel Core 2 Quad 8200 with a 945GCT-M3? Will it work?
Hello here is the homepage:
Here you can see the supported cpu list.
The quad core cpu will not run on this mainboard.
Here is info about the quad cpu:
But you can add a Intel Core 2 Extreme LGA775
This should give a noteable difference compares to the old single core cpu.
Remember also to buy a bigger cpu cooling element.
Here is no upgrade for the bios.
Good luck
Nov 18, 2012 | Computers & Internet
I replaced a 1.6GHz processor with a 2.4 GHz processor & whenever i boot the PC it desplays the message "processor not installed please upgrade your system bios", it then goes on to boot normally but...
Go to and search for the newest BIOS upgrade for you motherboard. Full instructions will be available on the website.
It sounds as if your motherboard will support the CPU however the BIOS software you are running doenst know if the newer CPU. A BIOS flash upgrade should solve the problem.
Oct 11, 2010 | ASUS Computers & Internet
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Jan 09, 2010 | PC Chips (M925G) Motherboard
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
I can't boot with USB -
Have you set it to boot from USB otherwise it will boot from other first
Aug 24, 2008 | Intel D850MV Motherboard
Problem with upgrading processor
Sounds like the processor you're trying to upgrade to isn't the same frequency. The processor, motherboard, and memory have a matched frequency. For example; a motherboard with a frequency of say PC4200 will only accept a processor and memory of a PC4200 frequency. If you try to use PC5300 memory it basically won't do anything, blank screen, or maybe a beep. The same if you tried to use a processor with PC5300 on the PC4200 board. The best way to find the frequency rating is to look on the memory. They class the memory by frequency, but rarely ever list the frequency for the board or processor. Research the new processor to find out the memory class and then see if it matches the memory in your machine. If it doesn't then the processor won't work. If it does, then new processor may not be compatible, and that means more research.
Jul 18, 2008 | Shuttle AV42 Motherboard
Intel cpu ucode loading eroor
You can upgrade your bios, you just need to visit the motherboard manufacturer site where you can download the latest bios.
You can also try to reset the bios first, you can reset it to default settings and if that will not work then you can upgrade the bios.
and you can also check this site regarding bios upgrade
Mar 21, 2008 | ASUS P5PE-VM Motherboard
>Can I upgrade the processor as well? Pentium 3 is compatible and what is the maximum MHz? Maximum CPU for GA-6BXE is Celeron-1400 (Tualatin core, with PowerLeap Adapter: ...and patched bios by BIOS Patcher: (last official BIOS don`t support Tualatin CPU-s) >A bigger HD will be compatible? With last F3a-version or patched bios - upto 128Gb. >The BIOS can aslo be upgraded? For max CPU / HDD - must be upgraded.
Sep 23, 2006 | Gigabyte Slot 1 GA-6BXE Motherboard
Intel D850MV Motherboard Logo
170 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
