Washing machine water keeps draining when I fill it. I want to fix it myself. what do i do?
  • 5,911 Answers
It sound slike you may have a problem known as "siphoning". The following link explains it and how to correct it:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
I have experienced this issue on numerous occasions and it cost the customer a service call charge. I hope your problem is as simple as this. I hope this helps.
Posted on Aug 20, 2008
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
I have LG fyzzy logic 6.5 kg WFS65AO1DCT and it keeps loading and draining water even when in spin
see this causes and fix it. God bless you
This happens on new installations usually. The drain hose must be higher than the highest fill height of the washer. If the drain hose is to low it will create a siphon effect and drain the machine. Next is the drain hose is to tight in the standpipe. The standpipe is your homes plumbing. If the drain hose does not have an air gap aroung it, it can cause a siphon effect and start draining your machine as it fills. If none of these are the problem and your drain pump is running at the same time it is filling you will need to replace the control. For top load machines follow this video and for front load machines follow the tutorial.
Sep 30, 2012 | Washing Machines
Washing machine never fills. The water keeps flowing and goes right down the drain... So it just stays stuck on the fill cycle... what do I do to fix it?
Have you checked the locatio of the drain hose?
Sounds like the drain hose is lower than the top of the tub and the water is running thru the pump and out the drain hose (water seeking its own level).
Mar 24, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Washing machine filling with water when switched off
You need to replace the cold inlet valve as it is sticking.
Please rate my solution.
Thanks.
May 13, 2009 | Bosch Washing Machines
Washing machine overflowing
Sounds like the water level sensing sub-system is malfunctioning. If you want to pursue this further, let me know.
Apr 29, 2009 | Siemens WFXD8400UC Front Load Washer
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
My washing machine is stuck on filling up with water it wont wash
If it keeps filling and overflows you need to check the water level switch and hose. If it keeps filling but doesn't leak out the you drain hose is too low or too far down the drain.
Apr 24, 2008 | Washing Machines
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
