Question about Danby DKC645BLS Compact Beverage Cooler
Touch pad I am looking for a touch pad for my kegerator. Danby said they are back ordered 3 weeks and I need one sooner. Can you help?
  • grumbag Apr 17, 2009
    cannot adjust temperature setting
  • 254 Answers
I have them in stock if your md# is DKC645BLS or DKC644BLS would be $22.75 after tax and get too you in 3 -5 days my number is 509-928-7176 can do visa or master over the phone.
Posted on Aug 20, 2008
I've owned it for about a year and have not had any trouble. But my Danby Kegerator just started beeping and flashing EE on the display one day and it won't cool. I had to unplug it. Any ideas
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
May 01, 2012 | Danby DKC646BLS Full Size / Pony Beer Keg...
Tip
Danby Kegerators
Just some general info on Danby Kegerators. The temp fluctuation is 32-42 degress thru out the day and for 1 hour a day you will get a temp of 46-48 degress during defrost. Unfortunatly there is no way to bring these coolers colder than 32 degrees.These Keg coolers need to be in a temp controled enviroment and if it is enclosed in a cabinet you need to have 3" opening on all sides for air to circulate. Some of the main fault codes are EE = open sensor and LE = which is a communication error between the display board and the main board. The LE error may be in the touch pad which gets moisture in the membrane and causes the pad to quit responded. A lot of the errors are caused by a loose connection. There are 3 screws that hold the table top down, once you get the table top up you'll see the connectors to the boards and sensor, just start removing the connectors, straighten the pins and reinsert them. Also if you ever have an issue with the fan motor, that part is no longer used on these keg coolers, the replacement board assm no longer has a connection area for the fan so the fan can be disconnected if it causes you issues. Another handy trick is to put turtle wax over the touch pad were you select the temperature, then that way the spilled beer will roll off the touch pad instead of ruining it :-)
on Jun 20, 2012 | Refrigerators
Bought a used danby DKC645BLS kegerator it is missing the co2 tank bracket that mounts on the back of the kegerator, where can I find one. Also the psi is set at 10 on the co2 tank and the beer comes out...
mark pasieka has an inventory of refridgeration, kegerator and bar related parts (as well as everything else)... he has this bracket in his warehouse right now... at least one... he also has tanks of CO2, oxygen acetalyne anything you may need... mark.pasieka@gmail.com
Oct 06, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Not cold enough
Just some general info on Danby Kegerators. The temp fluctuation is 32-42 degress thru out the day and for 1 hour a day you will get a temp of 46-48 degress during defrost. Unfortunatly there is no way to bring these coolers colder than 32 degrees.These Keg coolers need to be in a temp controled enviroment and if it is enclosed in a cabinet you need to have 3" opening on all sides for air to circulate. Some of the main fault codes are EE = open sensor and LE = which is a communication error between the display board and the main board. The LE error may be in the touch pad which gets moisture in the membrane and causes the pad to quit responded sometimes the error can be solved by simply disconnecting the molex plugs from the boards, straighting out the pins and reinstalling
Sep 17, 2010 | Danby DKC645BLS Compact Beverage Cooler
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
Danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Jul 28, 2009 | Danby DKC645BLS Compact Beverage Cooler
I have a danby kegerator that is spitting foam new keg settled for 3 hourd temp 38 3/16 line psi 9.5 help
Turn off the co2 for now. Turn it on when you need it, but start at a much lower pressure like 2-4 psi. Adjust pressure as needed.
Mar 22, 2009 | Danby DKC646BLS Full Size / Pony Beer Keg...
Temperatuer gauge says LE
If your gauge displays LE, it is below 15 degrees F. That means your beer will freeze. The same problem occured on mine. I called Danby and the rep was very helpful. She informed me it was definately a problem with the temperature pad on the front of kegerator. The part cost less than $3 and shipping was $7. It was an instant fix and it was easy to replace. Remove the four screws to the tower on top, the three screws to the rear, and pull the top off. Flip it over and remove the two screws to the computer. Unplug the old and replace with the new. Very simple job. Due to the low price of the pad, I would order two. The shipping price is the same and I don't have to worry about another keg being ruined because I now have a spare on hand. Hope this helps.
Jul 24, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby DKC645BLS Compact Beverage Cooler Logo
486 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
