I don't know how to use sanyo fax machine. It is SFX-107..I tried to put on paper and pressed button and pushed send button, but it was not working..
    Genius:
  • 2,120 Answers
Check for a dial tone with another phone plugged into the port on the fax.
Posted on Aug 31, 2008
SOURCE:
How to send fax
Put paper with text in the fax window. Fax machine must load paper. Dial number and if necessary push button 'Start' after you'll get specific sound from another fax machine.
Apr 05, 2016 | Office Equipment & Supplies
Fax Machines Ricoh Fax 4430NF error 0550H "call
Easy !
Press yellow button
Enter numbers: 107
Push red button for 5 seconds
Press number: 1
Enter: 5#810#
Press number: 1
Press (Half)tone and OK button at the same time for some seconds.
DONE ! Greet Barry
Feb 01, 2011 | Ricoh 4430NF Laser Fax
How do you send fax?
put document face down, press speaker button, listen for dial tone, enter fax number you would like to fax document to, press grren send button.
Jan 30, 2011 | Sharp UX-B20 Plain Paper Inkjet Fax
Fax machine will not send. Dial # Push Send and
If the fax is not set for tone dailing and it is set for pulse dialing the fax will not register the # button.
Dec 03, 2009 | Brother IntelliFax-2820 Laser Fax
Sleep mode will not disable, even when send button pushed, paper put in for fax or receiver taken off hook. Sleep mode set to default 5 minutes.
Press Menu 1,8
then set minutes to 00
press Stop/Exit
This should disable Sleep mode. Please post back with any questions or to rate this solution. Thank you very much.
Greg
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Manual for sanyo fax machine model sfx-111, mechanical error, not feeding paper...
(718)787-1301 call the above phone no and u ll get one i think its a authorised sanyo service centre
Jun 16, 2009 | Office Equipment & Supplies
Won't send faxes
did you put the originals page(s) in the machine FIRST to fax, then enter the number then press start?
If you enter the phone number 1st BEFORE putting your originals in the feeder, the machine thinks you want to make a copy.
The FAX Mode is the setting for incoming faxes.
Try that and let me know if it works.
There should also be a button called "Hook" or "speaker" or something that you hit and you will hear the dial tone.
Once you hear the dial tone, you can dial the number, (make sure the pages you want to fax is in the feeder.
Once you hear the fax high pitch noise, hit the start button.
Hope this helps.
Let me know if it does and also remember to leave a feedback and rating if I have helped you.
Thanks and good luck.
Mac =)
Feb 19, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Stuck in French
hold down the Code key(blue/green) and press Keyboard, You might have to do it once or twice, All brothers have international keyboards. good Luck! Don
Apr 30, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Self testing
Open toner door. Press function 7/ monitor key slowly 4 times/ press */ press 6/ scroll down to shipment set/ press set/ 2/ (fax will reboot)
Mar 07, 2007 | Panasonic Panafax UF-790 Plain Paper Laser...
Open Questions:
144 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
