Question about Dometic Rooftop RV Air Conditioner
Ac problems posted by couuntrygirl on Aug 20, 2008 Report abuse The unit will not cut off when it reaches it temp. in camper. I have replaced the Thermostat, control board, and the compaster on the top. I still have the same problem. It will not cut off with the switch heat off cool you have to use the hi low switch and its all wired right. Very confusing. When you move the temp control handle on the top to a different degree it makes the fan go from high to low it will not cut off. when it reaches like 70 and its set on 70 the fan will go from high to low speed. Please help me.
  • Mike Butler
    Mike Butler May 11, 2010
    What make & model is the unit ? Did it work properly before?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Sounds like the switches are in the wrong locations , rotate! Thank- you- very-much!
Posted on Aug 28, 2008
We just had a dometic rooftop ac b59516.711co installed 2 weeks ago and today, when the desired temp is reached the unit will cut off but not come back on when temp goes above desired temp.
That is normal. Typically a unit doesn't maintain the exact Set point temp. If set for 75 it cools to 74 and doesn't restart until 76. Obviously if getting too much higher than that there is a problem. Units also are programmed with maximum and minimum run times as well as how many times it can cycle per hour. Hope this helps!
Jun 09, 2017 | Dometic Heating & Cooling
2000 grand prix, temperature won go from ac to heat, stuck on ac.
Pontiac Grand Prix Climate Control/AC - Car Forums at Edmunds.com
forums.edmunds.com > Pontiac > Pontiac Grand Prix
Dec 29, 2007 - 30 posts - ‎20 authors Hi Joe, I had the same problem with no heat on my 2000 grand prix. .... motor and the exterior temperature sensor have both been replaced ... Pontiac Grand Prix Electrical/Lighting
Aug 3, 2009
Pontiac Grand Prix Heater blower relay switch
May 13, 2009
Pontiac Grand Prix Starting / Stalling Issues
Feb 9, 2008
More results from forums.edmunds.com
Fixing AC Temperature Control on my 2002 Pontiac Grand ...
? 9:58
www.youtube.com/watch?v=2BOdhWMdxXc
Jul 13, 2014 - Uploaded by Turbo231
Fixing AC Temperature Control on my 2002 Pontiac Grand Prix... How To Install Replace AC Heater ...
Oct 15, 2015 | 2000 Pontiac Grand Prix SE
Fan runs but no cool air. I don't think compressor is kicking in. Thermostat is working because when I adjust temp to be below or equal to air temp, AC unit turns on. When air temp drops as trailer cools...
Have you cleaned the unit? The condenser coil? The filter? The evapartor coil? Sounds like an airflow problem. You need to clean these areas. You can clean the condensor coil with water hose and a coil brush you can get at the hardware store. Clean the evaparator with the same brush. YOU can use a hairbrush if you don't have anything else. But make sure you go up and down on the fins on the coils not sideways. You might check your blower fan for dirt also. Good luck I hope I helped you. Could also be low on charge but first try cleaning.
Jun 28, 2010 | Heating & Cooling
I want Office Porte 33.3 modem driver.
of reporting suspected abuse on FixYa.com. We do not accept problem posts through the "Report Abuse" form. Please post your technical problem on the appropriate product page, where Experts can view your post and s
Feb 19, 2009 | Microcom Computers & Internet
AC button blinking
hi mercedes,
here is another thread that is almost similar to your problem, i just paste it here with my reply...
posted by Ron0293 on Sep 27, 2008 Report abuse
1985 toyota Camery in hot weather the car AC quits and will not engage the pump. After it cools the pump will come on again. When this happens the AC button in the car blinks. i know this is a vacuum and/or temperature sensor but i don't know which one it is. The manual I have does not say anything about it. Other wise the AC works just fine. Ron Comment by Ron0293, posted on Sep 27, 2008When I first turn it on the AC is working fine, blowing cold air all the time, the clutch pump is in gauged...when the problem occurs the clutch disingauges and then no cold air.. Comment by Ron0293, posted on Sep 27, 2008When I first turn it on the AC is working fine, blowing cold air all the time, the clutch pump is in gauged...when the problem occurs the clutch disingauges and then no cold air.. It is a sensor somewhere telling the pump to turn off. Comment by Ron0293, posted on Sep 28, 2008there is nothing wrong with the whole AC system when the compressor is pumping! no holes, no leaks, no heater problems or fan problems. The compressor keeps cutting out when the temperature starts to climb. I believe the system has a motor vacuum load/temp. sensor that cuts the AC out when the motor temp. rises from extra load. IE: like going up a long hill. I just don';t know where the sensor is located and the clutch wiring from the compressor is impossible to follow, as it is buried in a wire harrness. Comment by Ron0293, posted on Sep 29, 2008 There are two fans located at the rear of the radiator. They don't seem to be running when the AC pump cuts out. There is a sensor switch on the dryer. when the pump is acting up if i disconnect the sensor wiring the fans start running on high. There is also another sensor on the pump and when i disconnect it the fans start running on high. replacing the wiring returns the fans to off.
There is also a sensor, seems to be internal on the pump and when I disconnect it nothing happens. if(typeof LIB_LOADED == 'undefined'){document.write(''); } Add a Comment
Oct 01, 2008 | 2002 Toyota Camry
A/C Problems
It's not wired right! bottom line!
Aug 20, 2008 | Dometic Rooftop RV Air Conditioner
Question.?
yes, you can erase the video in your sd card since you have already a backup file in your pc. but make sure you have copy all of your files in your SD card to your PC drive.
Aug 11, 2008 | Canon PowerShot A560 Digital Camera
Dometic Rooftop RV Air Conditioner Logo
57 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
