Question about Dometic Rooftop RV Air Conditioner
A/C Problems The unit will not cut off when it reaches it temp. in camper. I have replaced the Thermostat, control board, and the compaster on the top. I still have the same problem. It will not cut off with the switch heat off cool you have to use the hi low switch and its all wired right. Very confusing. When you move the temp control handle on the top to a different degree it makes the fan go from high to low it will not cut off. when it reaches like 70 and its set on 70 the fan will go from high to low speed. Please help me.
  • GTENERY Sep 16, 2008
    THE A/C UNIT IN MY CHAPARRAL DOES THIS YOU SET THE THERMOSTAT TO 70 DEGREES AND IF THE TEMPERATURE OUT SIDE IS 68-80 DEGREES THE UNIT DOES NOT CYCLE AS IT SHOULD YOU MOVE THE THERMOSTAT TO 80 DEGREES STILL NO CYCLE IT WILL GET TO 60 DEGREES IN SIDE AND STILL NOT CUT OFF. THE UNIT WILL ALSO COME ON AND OFF SEVERAL TIMES IN A FIVE MINUIT PERIOD THEN COME ON AND NOT CYCLE.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
It's not wired right! bottom line!
Posted on Aug 28, 2008
SOURCE:
I have a 2016 coachman A-Frame camper My Dometic LCD thermostat the screen is blank,I have power at the circuit board do I need a new thermostat? if so can I buy any three wire thermostat?
Most of these camper units I've worked on have only 1 style of t-stat to use. Replace it with the same as what you have if possible. And check all connections to and from the t-stat. A blank screen doesn't mean the t-stat is at fault. Should have power at the stat as well as the control board.
Aug 21, 2017 | Dometic Heating & Cooling
Fyer will not shut off after reaching temp reset button comes on
Hi there.
Your thermostat may be bad, it does not cut-off on temperature setting that's why temperature continues to rise tripping the hi limit switch.Try replacing the thermostat.
Visit http://www.pitco.com for parts inquiries and owner's manual download.
Regards.
Jun 06, 2011 | Pitco Frialator SG18S Deep Fryer
Programmable thermostat intermittent problems...
Some tstats control humidity as well. Temp will over shoot set point in order to reach humidity s
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 24, 2017 | Honeywell Programmable Thermostat Heater
Replaced Fuse on Board. Unit keeps running
Sounds like crossed or shorted wire going to the thermostat. Disconnect the wire from the thermostat and see if it shuts off. If it does, it is the thermostat. Then disconnect either the white wire or red wire at the control board and see if the furnace shuts off. If it does, its the wiring. If it continues on, it is the control board. Remember you will need to tape the access panel door switch to the on position to be able to run the furnace with the panel off.
Nov 22, 2008 | Goodman GMS90703BXA Heater
Ac problems
Sounds like the switches are in the wrong locations , rotate! Thank- you- very-much!
Aug 20, 2008 | Dometic Rooftop RV Air Conditioner
Problem with RSKP 0006 control board
If the unit has an outdoor thermostat, this turns the aux. heat on very cold days. It may need to be replaced, or removed completely, if its kicking over to soon before it gets that cold. If its set to turn on the electric at 30 degrees, then its working the right way. Also, look for different temp. setting on the board you lust installed, there should be some sort of adjustment options on it. Especially if there is no thermostat outside.
Feb 28, 2008 | Amana PTH123B25AJ Heat Pump Air...
Dometic Rooftop RV Air Conditioner Logo
103 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Thomas F. Schneider
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
