Question about Kenwood KVT-715DVD Car DVD Player
KVT-715DVD displays call
My kvt-715dvd player plays fine for awhile then stops and displays call in the upper left corner where the source is usually located. I have to turn the unit off and back on to fix then a few seconds later the call comes back up. Any suggestions?
  • falejandros Jan 11, 2009
    quiero ayuda para encender el estereo
  • 60 Answers
Hi. The unit is overheating, and in most cases, depending on the car model, you will be able to fit a computer-like cooling fan underneath the receiver pointing outwards in order to help the unit cool down a little better, and prolonging the unit's operation. Usually a double-din aperture is just perfect for these improvements. If your radio mount is a single-din opening, then is gonna be a pain in the back to do something about it. Narrow spacing means overheating, especially when heat doesn't have anywhere to go, packing in the system, ergo, shutting it down for conservational reasons. Go to you nearest car audio store. They'll be able to help you out.
Posted on Aug 23, 2008
SOURCE:
I bought a car with a kenwood kvt 715dvd the battery went dead an now its asking for a password but i dont kno it how would i reset my kenwood kvt 715dvd/cd player
Did you look online or do you have a owners manuel? There is usually a factory set password such as 1-2-3-4 etc, unless you purchased it second hand and the previous owner custom set - then you have to contact the previous owner or Kenwood. Most people dont change the factory passwords. TRY KCAR (5227 ON A KEYPAD) uf that doesnt work read the forum post on: ecoustic.com. Good Luck
Apr 15, 2011 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt 715dvd wont turn on
check all your fuses. check power for the battery(yellow) wire and red wire(ignition- key must be on), and if all of those are good then check the fuse on the back of the stereo itself, i think it has a 15amp mini fuse in it.
Aug 05, 2010 | Kenwood KVT-715DVD Car DVD Player
Wires came out of my pin block on the back of my Kenwood kvt-715dvd. would like a digram to put them back in.
hi,
although this is not wiring diagram of your gadget but still this will help you little bit. or atleast you will get some idea about wiring so by further thinking you can solve your problem...
http://www.the12volt.com/installbay/forum_posts.asp~TID~74637~PN~1 .... http://www.the12volt.com/caraudio/caraudio.asp
Hope this has helped you... Thanks...
Jul 21, 2010 | Kenwood KVT-715DVD Car DVD Player
I need a brain unit
try e-bay or your local pawn shops. it's the only way you are going to find it.
Jul 21, 2009 | Kenwood KVT-715DVD Car DVD Player
Password for my kvt-715dvd
see what u can do is...... buy a remote!
Aug 29, 2008 | Kenwood KVT-715DVD Car DVD Player
Kenwood kvt 715dvd
I have seen problems in the hideaway (brain) where 8v reg circuit fails causing higher voltage(12v to 14v) to be on that 8v line. First component to fail is the Tuner followed by electronic volume ic. I have probably seen 6-8 failures where tuner fails. Fix is to replace tuner and replace open chip resistor in Hideaway box to restore 8v regulator to proper voltage. [email protected]
Feb 24, 2008 | Kenwood KVT-715DVD Car DVD Player
THE UNLOCK CODE
1)TURN ON YOUR UNIT 2)DISPLAY WILL REQUEST TO ENTER THE SECURITY CODE 3)USING THE REMOTE CONTROL POIN IT TO THE UNIT AND PRESS 55222277 THAT WILL CLEAR THE CODE. NOTE:"YOU WILL NOT SEE ANY NUMBER ON THE DISPLY WHILE YOU PRESSIN THE NUMBER ON THE REMOTE CONTROL
Aug 18, 2007 | Kenwood KVT-715DVD Car DVD Player
My KVT-715DVD can´t eject discs
turn off the unit wait 30 seconds and turn back on it happens to me once in a wile.
Nov 16, 2006 | Kenwood KVT-715DVD Car DVD Player
Kenwood KVT-715DVD Car DVD Player Logo
91 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
