Question about Technics Audio Players & Recorders
Stylus will not catch
I own a technics sl-dd33 turntable, and whenever i try to play a record, the stylus will not catch the grooves on the disc. it ends up sliding across toward the center and nearly scratches the record every time. i've adjusted the cueing bar to no effect, and there is no weight on the arm to be adjusted. is it just time to buy a new stylus? there doesnt seem to be anything visibly wrong with mine... any ideas?
  • jeremy0192 May 11, 2009
    I have the same problem. I tried Adjusting the arm, nothing worked, tried tilting the turntable while playing, and the stylus still listed up the angle towards the center. So I tried a different turntable with the same stylus cartridge, and the same thing happened, even after adjusting the counter weight from heavy to low...Determined I need a new cartridge.
    Problem Solver:
  • 7 Answers
'Skating' is usually due to very low stylus pressure, which can be adjusted using a counterweight.
Is this the picture of the turntable ?
http://www.vintagetechnics.stereomanuals.com/turntables/sldd33.htm
Isn't that a counterweight at the back-end of the arm ? Can't it be rotated ?
If the counter weight is fixed, check the pickup mounting. May be it needs to be adjusted a bit forward (to increasing the stylus pressure).
Posted on Aug 22, 2008
Technics sl dd33
The power supply of the turntable needs checking. It could be just a fuse or something more serious, such as a faulty transformer.
Mar 09, 2016 | Technics Audio Players & Recorders
How can I get a manual on how to fix this item? The arm needs adjusting. Thanks P.S. its a Technics sl-dd33 turntable
Technics website may have one. The counter weight has a setscrew on it. Loosen it ans move the weight slightly forward until the needle just rests completely in the groove and stays there. Too much will cause excessive wear to the needle and the record.
Aug 08, 2015 | Audio Players & Recorders
MY TONEARM ON MY TECHNICS 1200 SLIDES TO THE MIDDLE OF THE RECORD! DOES IT NEED TO BE REPLACED & HOW MUCH WILL IT COST?
No it's either the stylus or the pressure to the stylus is not enough. The weight at the end of the arm will increase the pressure on the stylus. Turn it up in slightly testing a record till the stylus tracks in the grooves. The trick is to get it so that it stays in the groove without creating a rumble sound. Remember though a worn stylus will not track at all.
Most cartridges track at 2 to 3 grams. If the Weight on the arm has numbers they will correspond to the weight in grams. If you have to raise it very high the stylus is too worn.
Jul 30, 2011 | Technics SL-1200MK2 Turntable
Needle skating badly; Can I adjust the stylus myself?
Too causes of this problem. One the stylus is worn out. Two not enough pressure to the stylus. At the end of the arm is a weight this should move up or down. If you can see numbers on it increase it slowly to the higher numbers, trying it as you go. The trick is to apply the correct weight to keep the stylus in the grooves and not here a rumbling sound from too much pressure.
Jul 02, 2011 | Technics SL-BD20D Turntable
When i play a record it skips and when i play it on another turntable the same record doesnt skip
Hi, most likely a worn stylus or the tracking weight is set too lightly. Adjust the balance weight at the back end of tonearm forward slightly. If no weight adjustment available put a very small coin on the end of tonearm above the stylus. styluscity@gmail.com
Jul 08, 2010 | Technics SL-1200 Turntable
My sl-5 skips on records often, Could it be the stylus pressure? how do i adjust the pressure? I've seen that this is a common problem with this turntable. Also could f*%#ed up records be the reason for...
What brand TT? Technics?
This from the manual:
"Place the unit in a stable and horizontal position where there is little or no vibration."
"Place the unit away from the speakers so that it will be subject to as little direct sound radiation as possible."
and
"Adjust stylus pressure in the following cases:
Stylus pressure is normally set to to 1.25 g but may be raised or lowered by +-.25 g.
It may be necessary to increase stylus pressure when playing records cut at high levels, or when room temperature is low, or when the unit easily picks up external vibrations.
This will prevent distortion and groove-skipping. In such cases, turn the stylus pressure adjustment screw clcokwise (+), as indicated. (Fig. 12)
Note:
Do not turn the adjustment screw further than the set limits (1.5 g ~ 1.0 g)"
Jan 22, 2010 | Audio Players & Recorders
My turntable is Technics model SL-DD33 and all of a sudden stop working I changed the power supply cord and it didn't fix the problem. Will you please advise or where I could take it for repair and if it...
Define what isn't working. Is it dead (no motor, lights, anything)?
Or is there just no sound. The output of the cartridge is independent of any power. A basic test to see if it's alive is to lift the tonearm, select the Phono on your electronics, TURN THE VOLUME WAY DOWN TO JUST A SKOOTCH OFF OF SILENCE, place the tonearm somewhere over the platter and lightly brush the stylus (BACK TO FRONT) with your finger tip. You'll hear objectionable noise from both channels if the conenctions are all intact.
Dec 12, 2009 | Technics SL-BD22 Turntable
Sl-dd33 turntable
If your needle just started to skip across the LP, then that means your stylus is damaged/worn and needs to be replaced. It's very hard to see the diamond tip on the stylus, and it might not even be there at all. So checking it might not yield any results. This is what happens when the needle is worn. It will skip across the record.
- OPTiC
Turntable Technician
www.1200s.com
Aug 27, 2008 | Audio Players & Recorders
Using Technics SL-B2
check the antiskating. then i don't know.. maybe the tonearm has to be calibrate
Feb 18, 2008 | Technics SL-1210 Turntable
265 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
