Printer Sharing I have my HP LaserJet 3055 connected to my desktop I have a laptop that connected through wireless internet. I have the loading disk for the printer but when I load the disk it asks how the printer is connected so I state network but I'm not sure that correct because I really dont have a network just a laptop that connected wireless. How do I make the printer work from my laptop...
  • 661 Answers
On PC.... go to printer settings and set printer sharing to on and give it a name.
in network settings on both machines ensure they both have the same "Workgroup" name
then go into Network neighbourhood and press button for computer in my workgroup. you should find the PC listed there, double click on it and you should then be able to see the printer listed there, right click on printer and select install.. if asked for driver disk use to install drivers..
job done.....just like making a shared folder.
Posted on Sep 28, 2008
How do I fix "Not
This error indicates that the scanner has not been linked to the desktop of the attached PC. Either launch the HP Toolbox and follow the scanner setup instructions, or if you do not have toolbox installed you will need to install the printer from the original disks that came with it.
Mar 29, 2011 | HP LaserJet 3055 All-In-One Printer
I can not connect my HP LaserJet 3055 wireless
That is correct. The HP LJ3055 is not wireless.
You need a RJ45 cable or a USB cable.
Jan 17, 2011 | HP LaserJet 3055 All-In-One Printer
We just bought a new HP laptop. We have an HP
yep the best way anymore is throught a usb port
Mar 03, 2010 | HP LaserJet 3055 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
How to connect the printer wireless
I don't think the HP 3055 has built in wireless capabilities. It does however have a built in 10/100 Base-T TCP/IP networking with 1 RJ-45 port, Hi-Speed USB 2.0 port, RJ-11 fax port, RJ-11 line-out telephone port. You should be able to connect directly into your hub or router and access the printer through a wireless router. You can get more information on set up at the link below.
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06a/18972-18972-3328064-12004-3328082-1161389.html
May 31, 2009 | HP LaserJet 3055 All-In-One Printer
Network Vista Wireless Laptop to XP Desktop & Print Documents
On the desktop machine - go to the printers folder, right click the icon for the Laserjet and choose sharing (enable print sharing). You should be able to name the printer and make it accessible to anyone within the workgroup. If needed you can run the network setup wizard to change the workgroup names on both machines.
On the laptop go to add new printer and choose network printer, you should be able to browse to the desktop machine by name and choose the Laserjet as a printer (whether you want it to be the default is up to you). The laptop will download and install the drivers from the desktop pc to the laptop and set the correct network path automatically.
It goes without saying that the desktop machine must be on in order to print from the laptop in this scenario.
Feb 21, 2009 | Dell Inspiron 1525 Notebook
HP 3055 model scaner problem
Document feeder error means that the printer is expecting you to have a document in the ADF "automatic Document Feeder" on top. If you are having this on the laptop, go into the scanner set up on your laptop, and change the device from document feeder to flatbed. It should work fine. You can also mimic the settings from your desktop to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 02, 2008 | HP LaserJet 3055 All-In-One Printer
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
HP laserJet 3055 network connection
HOW TO CONNECT HP 3055 TO ROUTER/WIRELESS NETWORK. WINDOWS XP/WINDOWS VISTA.
I have just finished successfully connecting my HP 3055 to my router and using it over wireless on 2 computers, one with windows XP SP2 and one with VISTA.
INSTRUCTIONS FOR CONNECTING HP 3055 ON XP:
FIRST CONNECT THE PRINTER TO THE ROUTER WITH A ETHERNET CABLE. FIND OUT THE IP ADDRESS OF YOUR PRINTER. By me it was 192.168.0.66
Go to CONTROL PANEL and open "PRINTERS AND FAXES". on the top left choose "ADD A PRINTER" click "NEXT".
In the "LOCAL OR NETWORK PRINTER" window, choose "LOCAL PRINTER ATTACHED TO THIS COMPUTER" and uncheck "AUTOMATICALLY DETECT"... click "NEXT".
In the "SELECT A PRINTER PORT" window click the radio button "CREATE A NEW PORT", click the down arrow and choose "STANDARD TCP/IP PORT".
In the window that pops up click "NEXT"
In the ADD PORT window, where it says "PRINTER NAME OR IP ADDRESS, type in your printers IP address, by me it was 192.168.0.66. The bottom line will fill in automatically. Click "NEXT".
In the "INSTALL PRINTER SOFTWARE" window, if you have the disk just choose "HAVE DISK" and install from there. If not, in the left column choose "HP" and in the right column choose "HP LASERJET 3050" (by me it showed up in the list, you can download the driver from here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
click "NEXT"
In the "NAME YOUR PRINTER" window, choose a name and also choose if you want to set it as the default printer (recommended) Click "NEXT"
In the next window choose whether or not you want to share the printer, and if you do assign a printer name. Click NEXT. The next window is optional if you want to make a name, you can just click NEXT and your done! Print a test page to make sure that all is fine.
Feb 11, 2008 | HP LaserJet 3055 All-In-One Printer
96 people viewed this question
k24674
jasbo
jasbo
