Question about Fisher Paykel EcoSmart GWL15
Fixed basket came loose...
I have an ecosmart Fisher & Paykel clothes washer.
There are two baskets, one is fixed (as in, doesn't move), and is outside of the inner basket that the clothes go in. The fixed basket detached and now my washer doesn't work. Is this an easy fix, or will I need a repair person to come out and fix it, or should I just scrap the machine? I am right at the two year mark, so I don't know if my warranty will still be good or not...
  • Anonymous Sep 12, 2008
    I had the same problem and followed the first poster's suggestions. It is working just fine. One suggestion, though, is to have another set of hands to help lift the basket when trying to reattach it or to hold up the lid so it doesn't fall on your head. Easy fix, though. Thanks!
  • Anonymous Nov 25, 2008
    The large fixed basked came off it's spindle (or whatever) during the rinse cucle and leans against the washer chassis.
    Genius:
  • 1,028 Answers
If less than 2 yrs warranty and washer has 2 yr warranty (ck owners manual) call service ..if not remove plugs on front sides of top remove phillip screws lift top outer tub is supported by 4 swing arms one or more is probably loose or broke but can be replaced also have known then to just pop out of position with really bad off balance load
Posted on Aug 21, 2008
Fisher and Paykel washer fault code 40. Is it possible to repair DIY. What to look for?
This is error code 40.
40. (00101000) Basket Dis-engage Fault
While carrying out a basket check, the Motor Control Module has found that the basket is
not engaged even though the pressure sensor indicates that the basket is empty. The
Motor Control Module continues to check for 2 minutes, after which time it displays this
fault. The first two areas to check are the clutch and the pressure tube. If these two
appear correct, then the fault could be in the pressure sensor in the Motor Control Module.
Primary Source: Mechanical.
Action: 1) Check that there are no clothes or other foreign objects preventing
the clutch from re-engaging. Excessive suds can stop the basket
rotating.
2) If the machine is empty of water, carry out a clutch disassembly
procedure and check the spline drive.
3) Next check that the pressure tube has not come off and that it is
not kinked.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
May 21, 2017 | Fisher and Paykel Washing Machines
Fisher paykelwasher basket removal
you need fill with hot water to soak it over night to loosen the basket so it can lift out.
Feb 08, 2013 | Fisher and Paykel GWL11 Top Load Washer
How to fix my fisher & paykel washer machine from shaking and knocking
Your 4 suspension rods will need replacing as they are loose & worn.
Or the bowl has lost its ballast water from the top & bottom balance rings of the bowl.
Jan 05, 2013 | Fisher Paykel WA42T26GW1 EcoSmart 25" Top...
711 Lid lock issues
see this causes:
t doesn't pump or spin
frozen puller, or broken belt, lid switch defective or open replace
It pumps, but doesn't spin
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, basket worn,
It spins only with the lid closed
for security reason, only spin with the lid closed
Jun 19, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykel smartload dryer degxius does not dry cloths. Drum is hot, and lint basket is empty. I have cleaned lint out behind lint basket.
Check and make sure that your exhaust tube and outside vent are not clogged. If they are clean them out and you may have to buy and new lint screen that come with a seal whcih will solve your problem. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum will further help you through your problem.
Sep 04, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My Fisher and Paykel Ecosmart topload washer is not emptying or spinning out. I have tried running it back through the whole cycle but it quits at the draining point and starts beeping. Thanks
There is a service summary with error codes under the control panel in a zip lock bag. My pump was being blocked by a bobby pin. removing the basket allowed access to the pump and I was able to clean out the suction. I was amazed by the scum build up under the basket. I will now remove the basket yearly to clean under it.
May 13, 2010 | Washing Machines
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
Sep 09, 2009 | Fisher Paykel EcoSmart GWL15
Bad order during final rinse
Hi Jeanette! Welcome to FixYA!
When you say "We took it apart" are you talking about removing the inner basket or just the agitator/rinse dispenser?
On the Fisher-Paykel washer I have worked on in the past where the customer complains of odors, I will remove the inner basket (Wash tub) and if possible take it outdoors and spray it down with a hose. The outside edges of the basket (the side that you cannot see from the clothes side) sometimes gets a murky buildup on it. Also the underside of the basket can get pretty grungy as well. There are some pockets underneath the tub that can hold scummy buildup and it will all wash off with a garden hose sprayer. Now up here in the Great White North, this is not an option (It's around 15 below zero here) but perhaps where you live it is not as cold. It is really not that difficult to pull the inner tub out of the washer. You pop the white plastic covers off the screws that secure the washer lid to the cabinet, remove the screws and the top of the washer lifts right up. You can un-snap the collar that runs around the top of the tub (no tools required, just pop the tans and pull the ring off to the side, just be careful of the little balance spring in the left-front corner) I usually just leave the spring attached and gently set the collar down the left side between the outer tub and the washer cabinet. Now take pop the rinse dispenser up and out of the center of the agitator and unscrew the plastic wing nut that secures the agitator in place ans pull the agitator out. Now that entire inner basket just lifts right up and out of the machine. It's a little on the heavy side, so you might need a helper. Once you lift it out, now you can not only rinse the basket off, you can also grab a rag and wipe down the outer tub, as it will probably have some deposits on it also. Since it is plastic, they will wipe right off.
This may sound complex but it really isn't. Fisher Paykels are very well designed as far as ease of service. That tun comes out basically with nothing more than a screwdriver.
I hope this helps you. If you need more info, please ask. If you feel that I have not been helpful, please allow me the chance to redeem myself before you rate my answer!
Thanks for the opportunity to help you and Happy Holidays!!!
Dec 21, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
191 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
