Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Problems to SEND a fax
Hi, I can't SEND a fax with my Kodak EasyShare 5500 :-(
It seems, that it would not START dialling, because it is waiting for the normal dial tone. (the fax is in our company's office, with a different dial tone in the telephone network).
unfortunately I don't find the right solution in the menu or in the manual.
Maybe you know that problem and could give me a hint....
Thx !
  • Anonymous Mar 19, 2014
    Have a connector board with 4 twisted pair running into each room with a jack. Phone rings connected through the fax port. Fax does not send or receive. No dial tone at fax. Dial tone at phone.
    Scholar:
  • 96 Answers
I'm not sure what you mean entirely but this could help.
Usually sending faxes are only a problem if:
You have the printer set up correctly. (Phone line must be in line 1) or your phone line digital, which the product does not support unless you have a filter.
Also, if by different dial tone you mean "distinctive ring," that also is not supported by the product.
Posted on Aug 21, 2008
SOURCE:
Kodak 5500 aio will recieve faxes but won't send faxes
Make sure that the settings is properly set especially for the region settings. If problem persist please upgrade the firmware of your pinter.
Jan 07, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
My kodak 5500 all in one inkjet printer will send fax, but comes thru blank at the other end. Yes I have the document with lettering up like it says.
The problem, more than likely, is the quality of the scan. The 5500 sometimes overexposes the original. Test the scanner by scanning the document tou want to fax using HomeCenter software and looking at the screen preview. You can make some pre scan image density adjustments by changing the fax settings brightness setting to low (1 or 2) and changing the color setting.
Apr 30, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I just received kodak 5500 printer and error message paper jam
I cannot send a fax, it goes & then on the confirmation page I get an error under results. please HELP.
Dec 25, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Having troubles with fax not dialing out
Disable call waiting is only set to "yes" if you have call waiting, press "menu" then scroll down to "reset all setting" make sure to backup phone entries before doing this . Follow the "fax settings" below:
FAX SETTING FOR 5500 (VOICE MAIL)
- ANS. MODE TO "YES"
- ANS. MACHINE RINGS "3"
- FAX RINGS TO ANS. "4"
FAX SETTING FOR 5500 (ANSWERING MACHINE)
- ANS. MACHINE RINGS "4"
- FAX RINGS TO ANS. "3"
Nov 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Fax machine settings for distinctive ring line setup. Kodak 5500
This 5500s don't receive faxes if you have voicemail. You can still send faxes. Just make sure Disable call waiting is set up correctly in Fax Settings
Jul 29, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
How to fax when ink cartridge is empty
I talked to Kodak and you can't. You have to have all ink cartridges filled and ready in order to perform any operation! I know, it sucks!
Jun 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak All In One Printer Series 5500
Ok. call 1.800.421.6699 for the print quality prob. With the fax, they might be able to help you too.
Jun 17, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Fax machine
what do you mean? you cant send? or you cant receive fax?
first know if you are using a digital or analog line. if youre using digital line you need to have a micro filter and it must be connected to the fax line. if you have an answering machine it must be connected at the back of the printer(EXT-2) to make it work. then on your printer press menu and then choose fax settings
answering mode must be YES(if you have an answering machine)
rings to answer is 1 ring less than your answering machine
disable call waiting must be set to NO.
let me know what happen
May 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
My model Kodak 5500 printer/fax
Just found your post and I'm having the same problem. Everything else seems to be working correctly. I can copy, scan, print and I THINK I can send a fax correctly, I should have called the person and made sure it arrived. However, I cannot receive faxes. I have an answering machine on the line, but it is not plugged into the Kodak Pinter, it is in another room. The answering machine answered the call, the FAX noise came across, but the Kodak Printer never picked it up and printed out the fax. I think I have all the settings correct, but the instructions are not very clear. Do you think I HAVE to have the answering machine plugged into the Kodak Printer? That doesn't make sense, but I might try it.
Feb 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Fax machine
I have the opposite problem, I can send but not receive! For sending, make sure your phone line is plugged into the "1-LINE" in the back of the machine, put your pages face up on the top of the machine, press the "FAX" button, type in the phone number and hit start. Maybe you've done this exactly and you have some sort of error?
Jan 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
252 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
