2004 Volvo S80 Logo
Anonymous Posted on Jun 16, 2011
How many bottles of refrigerant a volvo s80 takes?
Anonymous
Level 3:
  • Master 4,803 Answers
  • Posted on Jun 16, 2011
Anonymous
Master
Level 3:
Answers
4803
Questions
0
Helped
2962750
Points
18833
That's a REAL GOOD question! The factory refrigerant charge specifications for your vehicle is 2.20 Lbs. of R-134A. Freon R-134A comes in 12 oz, 14 oz, 16 oz, 19 oz, and 22 oz cans (as well as 30 Lb Cylinders) - it depends on which brand/size can you are buying, whether your system is COMPLETLY out of freon, or whether it still has some freon in it.
The best way to deal with the situation (in my opinion) if you are going to try and charge you own A/C system is to purchase a kit that comes with a gauge. A company called interdynamics has a real good kit available that comes with a reusable gauge. Once you have the gauge, all you have to purchase in the future is the freon itself. By using the gauge, you can more accurately charge your system without the worry of possibly overcharging. (Overcharging can cause extremely high pressures that can do serious damage to your vehicle or cause personal injury.)
Anyway, this kit is available at O'Reilly's as well as other auto parts retailers. Here is a direct link to see the kit at O'reill'ys web site.
There is also a whole bunch of instructional videos on how to charge your system at the interdynamics web site. CLICK HERE
  • Anonymous Jun 16, 2011
    Sorry I messed up the link to O'reilly's. Here it is again, just copy and paste this in your web browser. http://www.oreillyauto.com/site/c/detail...
1helpful
How do I replace the passenger side mirror on a 2005 Volvo S80
Take a look at the stuff on this page: https://www.google.com/search?q=replace+the+passenger+side+mirror+on+a+2005+Volvo+S80&ie=utf-8&oe=utf-8
2helpful
2answers
How many qt of transmission oil those a 99 volvo s80 need
parts tore can say for sure but its usually in pints..4 pints to a quart..so 16 pints is 4 qts most take 6 qts or 24 pints..just to give you an idea..put 2/3rd of it in and start the car fill to level according to the stick.
Volvo s80 1999 Fuse box diagram
On this website you find fuse box diagram and description for Volvo S80 (1999)
Volvo S80 1999 fuse box diagram Auto Genius
2000 Volvo S80 - How do i reset the
just put reset service light volvo s80 and lots of info there on resetting goodluck
Replacing front rotors of a 1999 Volvo S80
U MUST REMOVE THE BRAKE CALIPER ASSEMBLY THEN THE ROTRS COME OFF.
My volvo says to check coolant level and pull over ASAP but the coolant level is fine. How do you clear out the message?
might be a faulty sensor in the coolent bottle which is common. that light should go out auto when the fluid is at the right level.
1999 VOLVO S80 T6 OPERATORS MANUAL FREE'
my volvo s80 t6 air conditioning not working well and often cause over heating. why?
2helpful
Volvo
hi,
It's very easy. Just take off the back seat behind the driver. There is a cover , remove it and then you have it. Be carefull ther is a big plastic nut and all is under it - regular right hand thread. Change the o-ring before puting it back.
Good luck
Low beams and back door locks S80 2001
check the fuse,power might have lose wiring take it to a local volvo service center
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
