Question about Panasonic Panafax DX-800 Plain Paper Laser Fax
Dx 800 fax machine
We can send faxes but cannot receive. The sending party says it just rings and rings and gives them an incomplete message.
    Genius:
  • 2,120 Answers
Only one sender, or all sender's?
Unplug the machine and replug. If it has an OUT button, make sure it's lit.
When all else fails...
Unplug machine
Hold down energy saver key
plug in
scroll down to SHIPMENT SET
press set
set
wait for reboot
Posted on Sep 01, 2008
    Sergeant:
  • 284 Answers
Dont shipment set the machine. all you need to do is an all job clear to fix the machine . memory could just be frozen and this way you dont clear all your data
Posted on Sep 11, 2008
Mesage displayed is "phone off hook"
  • You need 2 lines if you phone rings. You had to wait till it doesn't ring to send fax. To do both thing you need 2 phone lines.
May 14, 2014 | Panasonic Panafax DX-800 Plain Paper Laser...
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
DX-800 beeps with Incomplete Info Code = 720
Error Code 720: Cannot connect to the Pop Server. (Incorrect Pop Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the network Administrator
Regarding the beeping noises. The DX-800 has multiple settings for beeps, rings and the dialing monitor. If it is the latter, press MONITOR button once, then press the DOWN arrow, until silenced. Some ringer/beep settings are under Fax Parameters, some are in a special SERVICE MODE.
let us know if you can isolate which one and we can help turn it off. At least now you know what the 720 code means.
Good Luck!
Nov 10, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Will not receive faxes.can send but not receive
It sounds top me that the phone line has been put inot the wrong jack on the fax. There are generally two or three jacks to plug your phone line into. Look for the jack that has the letter L or the word "Line"
Any other jack will not allow reception but oddly enough allows transmission( outgoing)
Sep 22, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Jun 04, 2009 | HP 920 Plain Paper Fax
Not receiving any faxes but sending
Note: check your equipment for:
Fax machine must be connected to an answer machine
Receiving a fax automatically:
1 Make sure the Fax Auto Answer light is on.
2 To set the number of telephone rings before the printer automatically receives faxes,
Receiving a fax with an answering machine
When a telephone ring is detected, the answering machine picks up the call.
If the printer detects a fax, it receives the fax and disconnects the answering machine.
If the printer does not detect a fax, the answering machine receives the call.
2 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
3 To set the number of telephone rings before the printer automatically receives faxes.
Oct 31, 2008 | Lexmark X5470 All-In-One InkJet Printer
Receiving a fax from a certain number
Does the other party have a DSL phone line?
Aug 09, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Doesn't receive from two fax numbers outside the UK
I would suggest there is nothing actually wrong with your machine, as you can indeed receive faxes from other parties. The problem mostly likely lies with the equipment and/or lines of the sending party. One thing you might suggest to them is to turn off ECM (Error Correction Mode) and/or lowering the sending/receiving speed of the machine - preferably the sending speed of the sending party.
Nov 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Receiving a fax when using the phone
you can not use the phone simultaneously while sending or receiving a fax. You do not need a separate line. especially if you do not do a lot of faxing. You just can not do both at the same time. You can set your machine to automatically receive faxes when you are not present. The machine will detect the sending tones of the senders fax and automatically receive your fax. You may want to order a users manual from brother to help you set up your fax for your specific needs. Their number is 1-800-284-4357. Another option is you can order the distinctive ring option from your phone company. This will allow you to give out a seperate phone number for your fax while only having one line. The machine can be programed to distinguish the distinctive ring and automatically pick up with out you wondering if it is a fax or phone call. But again you can not talk and fax at the same time. Good luck and let me know if I can be of further help! John
Sep 07, 2007 | Brother FAX-1960C
Panasonic Panafax DX-800 Plain Paper Laser Fax Logo
100 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
