Question about Metrologic Instruments Voyager MS9520 Handheld
Incorrect Reading We bought a new MS9520 scanner, using via Keyboard wedge control, Using EAN 8 Barcode on our products, The scanner is working properly. But only for some codes the reading is incorrect!!! For example if the Code is 29117 its reading will be 11729 or similar Sametime if we try 2 to 3 times, sometime it will read correctly. Anticipating your assistance immediately
    Problem Solver:
  • 18 Answers
Try experimenting with the different inter-scan code delays. You can find the programming barcodes in your manual.
Posted on Apr 02, 2009
SOURCE:
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
Problem with metrologic voyager on xp,
If your voyager has the new interface then you can, by reading a barcode, change the type of connection. You must also change the cable
Sep 04, 2009 | Microsoft Metrologic MS9520 Voyager...
Scanner ouput is missing data from the scanned barcode
yes i have the same problem, when i am using usb keyboard..
but if u use standard ps2 101-102 keyboard it is working properly
Aug 13, 2009 | Microsoft Metrologic MS9520 Voyager...
Scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Apr 02, 2009 | HHP IT3800 Handheld
No power to keyboard using Y cable to PC for LS2208wedge scanner
If you have not already done so, scan the IBM PC/AT barcode from the Quick Start Guide that accompanied the scanner. If you do not have the QSG you can print the barcode from the Product Reference Guide found at this link:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=118232754&stateId=0%200%2012083692
The barcode you need is on Adobe page 56 of 342.
Mar 20, 2009 | Symbol LS2208
Can't install Symbol LS2208 barcode scanner on a PC (Wedge cable)
You will need to scan the barcode that configures the LS scanner to use keyboard wedge or even the set all defaults barcode. You will be able to find both of this on the product reference guide that you can download from www.symbol.com in the support page.
Mar 14, 2009 | Symbol LS2208 Handheld
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Metrologic Keyboard Wedge Barcode Scanner (MS5145)
are you using usb keyboards if so set the scanners to stand alone keyboard wedge you will find this in the manual. if this is not the case it could be that the scanner is set for a different keyboard type just set the scanner for keyboard wedge emulation. hope this helps Pete
Aug 15, 2007 | Metrologic Instruments MS5145 Handheld
Metrologic Instruments Voyager MS9520 Handheld Logo
492 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
WatsHVAC
Level 1 Expert
George Etukudo
George Etukudo
Jason E
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
