Question about Sony Playstation 3 (PS3) Console
Ps 3 av multi out connector position
The above on my sons ps3 is on the left hand side of the console, it would seem that on the majority of consoles it is positioned on the righthand side next to the on / off switch. It means that he is unable to 'add on' the recently purchased led light, as it requires the outlet to be on the right.
Has anyone else got a console such as this. The shop we purchased from are unwilling to swop it even though they've checked their stock and all others have the connector on the right.
I realise it's not a true 'tecky' problem but any advice from anyone who obviously knows more than me would be appreciated.
  • 344 Answers
Hello.
Most likely you have a 40GB version. The easiest way to check is look at the serial number in the back. If it has CECHH01 then it is definatly the 40 GB version. This version was overhauled by Sony to save a ton of money. Practically everything inside is different from the 20GB, 60GB, and 80GB models. I hope this helps.
Good luck and happy gaming!!
Posted on Aug 20, 2008
Ps3 audio
Can you provide some details of your setup? How are you connected -- HDMI, optical or using the provided multi-AV connector? What are you connecting your audio to -- TV, stereo receiver, etc.?
Apr 05, 2014 | Sony Playstation 3 (PS3) Console
It is sync and i can see the status on the upper left corner of tv but cant get it to function?
Please follow these same steps for your SP3 The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well. Connecting to a Television Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom. Look for inputs marked Audio and Video IN. Do NOT connect your system to anything marked OUT. Don't see these inputs on your TV? Click here. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console. Insert the AC plug into a 120V AC wall outlet CAUTION: To prevent electric shock, match the wide blade of the plug to the wide slot and insert fully into the outlet. Plug the transformer into the wall outlet. The Sensor Bar can be placed either above or below your TV screen. Decide which option best fits you and click the image below for additional set up help, including mounting the Sensor Bar and proper alignment.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Intermittent Sounds Problem on PS3
If you have verified the AV cable is not the issue, it's likely the AV port on the PS3 is the culprit.
Try your cable on another PS3 to be sure. Then try your PS3 and cable on another TV.
If it still misbehaving, send it back to Sony for repair.
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
Do we need a hdmi adaptor?
you need to go to walmart and buy the av cord for the ps3
its expensive but the ps2 cable wont work
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
PS3 doesn't connect to tv
Try holding down the power button for 3-4 seconds when you turn it on.
This should allow you to reset the AV inputs on the ps3
Aug 23, 2009 | Sony Playstation 3 (PS3) Console
PS 3 Hookup to Sony Grand Wega
this is a very simple fix leave cords in your sony with ps3 on standby hold the power button on ps3 itself down for 10sec your ps3 will switch back to av cables
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
I need to know how to run my ps3 thru the optical wire to my hdtv
Before you start ensure that you read the TV instruction manual to know which resolution supports it. Do not switch on the TV and your console
You can connect your Playstation 3 to your TV in three different methods:
  1. Connecting with an AV cable
  2. Connecting with an HDMI cable
  3. Connecting with an Optical Cable
Connecting with an AV Cable:
  1. You are supplied with a Composite AV cable which would typically look like the below image
  2. Connect the AV Multi Out Connector to the socket on the back of your PS3 Console.
  3. Match the colors of the Jacks with the connectors on the TV which says "Video in".
Connecting with an HDMI Cable:
HDMI cable is not supplied with the PS3. You need to purchase it seperately. This cable would enhance the audio-video quality of your TV.
  1. Just connect one end of the connector to the HDMI OUT connector socket on the back of the console
  2. Connect the other end to the socket on the back of your TV which says HDMI IN.
Connecting with an Optical cable:
You need to purchase an Optical cable if you wish to connect your PS3 console through a digital audio device (Home theater, AV receiver etc.,). You need to connect Video ouput seperately with a help of Video output cable (HDMI, AV Cable etc.,)
  1. Connect one end of the optical cable to "Audio Out" socket on the console
  2. Connect the other end to the audio receiver.
Note: You can also connect your console to the Internet to use the Playstation 3 internet capabilities. Here's how you do it:
The Playstation 3 only supports 10BASE-T, 100BASE-TX and 1000BASE-T type networks. It needs a High speed internet connection. Do not connect it to a standard telephone connection or cables that are not supported. It might cause a malfunction or damage to the system.
Dec 11, 2008 | Computers & Internet
CAN'T CONNECT PS3 TO AN LG FLATRON L172WT
yes it is the ps3 is not reading the change tho so its an easy fix you just need to reset the connections i have done this alot on the front of your ps3 the power button press and hold it for 20 to 30 sec. it will beep a bunch then the connection is reset then try your new connections , the ps is suapose to read that but sometimes it don't it happens.
Nov 18, 2008 | Sony Playstation 3 (PS3) Console
New HDMI problem
my brother had this issue with his PS3, he simply went into the settings with the av cable and hooked the hdmi up at the same time and changed the settings from auto to manual.
Mar 12, 2008 | Sony Playstation 3 (PS3) Console
40gb hdmi
I had the same problem at first. I did the following:
1. Connect both cables: Multi-AV and HDMI.
2. Go to the TV's channel for SCART.
3. You now can see the PS3. Go to Display Settings, under
Settings menu. Select HDMI and the desired resolution.
4. Change to the HDMI channel.
5. You should now also see the PS3's XMB on the HDMI channel.
6. You can now disconnect the Multi-AV.
I hope this information can help you and your customer.
Please rate.
P.S. I figured you were Dutch since you used Neophyte as a name for your previous question. Are you Dutch, and in that case: what videogames store you work at?
Greetings,
DarkNeogen.
Jan 30, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
94 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
