Question about Car Audio & Video
Have just installed sony cd radio in puegeot 206.All works great, but when ignition turned off,unit looses its memory,looks like its not getting constant 12v.how do i overcome this.Somebody suggested that check position of fuse 24,and move it to second position.Tried with exactly same result.Removing fuse 24 stops power to unit when ignition is turned on,so seems that fuse 24 is linked to audio wiring.Any Help?
  • 10,594 Answers
Sony cd radio player has Yellow wire in rear connctor. This wire supply volts to keep memory alive. Check is it hooked with Battery volts ( 12 volt )
Posted on Aug 20, 2008
Can't enter radio code in puegeot 206 as the numbers 7 and 8 are not on the radio
If you need the code check gumtree.com and search peugeot clarion radio code, they email code from your serial number! Quicker and cheaper than main dealer, I have used them!
Dec 28, 2013 | 1991 Peugeot 405
Wiring diagram for cdx-gt450u
You may download the instruction and installation manuals from here. The wiring diagrams are on the first page of the installation manual.
Nov 29, 2012 | Sony CDXGT450U Car CDMP3 Player
Hi, there are a couple of problems which I am having. 1) When I turn off the ignition the radio looses its memory. 2) I have a control by the steering wheel to control volume etc, but this does not work. I...
There are two battery feeds to the radio
1...The main one that connects the battery supply via the Ignition Switch
2...A permanently connected battery that maintains the Code Memory and Tuning Settings Memory.
It looks as though the (2 ) is missing
Usual problem is a blown fuse or loose connector at rear of radio.
Can be tested using a Multi-Meter or Test Lamp
CLICK HERE for useful website with the connector pin diagrams
Jan 31, 2011 | Car Audio & Video
Hi All, I have a peugeot 206 and when I enter my four digit code into radio everything OK until I turn off ignition,then I have to input number again.Is there something else I have to do to stop this...
It looks as though the "permanent battery" feed to your radio is missing.
There are 2 battery supplies to your radio ; the main one via the ignition switch that switches the radio on/off and the permanent battery feed that supplies battery to the radio memory.
Check your fuses and connections at the rear of the radio
Apr 03, 2010 | Car Audio & Video
Loosing all ive saved when i turn the engine off
Easy fix, There are two 12+ volt feeds that should be connected to your unit.
1. Constant feed = 12+ volts that supplies power to the units memory all the time.This wire can be connected from the original radio connector wiring so long as it supplies constant 12+ volts, or be pulled from the battery, with an in-line fuse.
2. Switched feed = 12+ volts that only supplies power when the ignition switch is turned on,This wire can also be connected from the original radio connector wiring so long as it is a switched feed, also with an in-line fuse.
During installation ether these wires were swapped or the constant feed (memory wire) was not connected.
Good luck...
Feb 24, 2009 | JVC KDAVX44 Car DVD Player
Illumination?
you need to splice the + wire into the Acc wire. the with power only when you turn the key. and the - wire into the black ground wire. hope this helps
Jan 29, 2009 | iLO XM-MP3-CD Car Stereo
Sony car radio/CR/cassette doesn't hold pre recorded radio stations once ignition is turned off
run the yellow wire to the battery as its the memory wire and that will work if it is installed correctly and still does the same it can be the battery even if the battery still works.
May 25, 2008 | Car Audio & Video
Memory loss
you need to remove the radio and swap the red wire for the yellow wire and vice versa, they have bullet connectors to allow you to do this, basically the permanent live and the ignition live are the wrong way round.
Nov 27, 2007 | Sony CDX-GT300 CD Player
SONY EXCD-206 December 1996
I have the same radio, the radio's harrness has a red wire ignition 12 volt,yellow battery 12 volt, black ground, and a blue Iam not positive it can be the amp, or illumination.
Nov 18, 2007 | Sony CDX-CA400 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
