Question about Acer Aspire 5100 Notebook
Cannot connect to my wireless AP
Cannot connect to wireless
  • Acer Master
  • 3,051 Answers
If you have the wireless turned on move the computer closer to the signal sourse if there is one i am constantly moving mine around to see where the best signal is than i let the compouter recognise it and it will tell u what is in range
Posted on Aug 21, 2008
SOURCE:
Lg smart tv model 42LS5700 can I connect to WiFi if so how?
These extracts from the user guide should solve your problem:
To connect network through Set Expert
HOME ? Settings ? NETWORK ? Network Connection
Used in special circumstances such as in offices (For example, when a static IP is needed).
1 Select a network connection either through Wired or Wireless.
2 When connecting via Wi-Fi, use the one of the following network connection methods.
AP List Connects the network by selecting a network from the AP
(Access Point) List.
Enter the SSID Connects by typing in the name of wireless AP.
WPS-PBC Connects easily by pressing the button of the wireless AP supporting PBC.
WPS-PIN Connects easily by typing in the PIN on the web site of the desired wireless AP.
Ad-hoc Connects directly to via a wireless-enabled PC or mobile
phone.
For the full manual follow this link:
http://www.lg.com/us/support-product/lg-42LS5700
Jun 11, 2018 | LG Televison & Video
How to resolve wifi access mode not supported
an AP is used to extend you wireless range and will connect to your router to provide network and internet access. An AP by itself cannot connect to the ISP since it does not use a WAN port
a router is an AP that will allow you to connect to your ISP for internet connection. A router can be configured to work as an AP but a AP cannot function as a router.
Feb 19, 2014 | Linksys Business Series WAP4400N...
Engenius eap-3660 access points channels chashing.
This is a massive and expensive network, which appears to require a full signal and configuration audit. It's quite possible that many of your problems are stemming from the APs you have already deployed being situated in suboptimal and conflicting locations, which is an issue with three-dimensional wireless networks.
I really don't see your problems being debugged by anyone short of an experienced on-site wireless network technician. I'm saying this as a person who tuns a one-man company serving two rural communities with wireless internet service.
Sorry.
May 07, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
Connect belkin f5d7130 to homehub 1.5
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
Oct 19, 2009 | Belkin Wireless (F5D7130) 802.11g/b...
Adding a wireless connection to an existing wired network
Go out to you local electronics store and purchase a wireless router , or Wireless Access Point (AP) , this way you will create a wireless connection by following the instructions given when you purchase the Wireless AP .
Basically when you buy the Wireless router or AP you just need to plug your existing Modem/Router into the WAN port on the Wireless Router / AP and then some initial setup to configure the wireless settings and then the appropriate settings inputted on your PC.
Heres a short guide i wrote to setting up a Wireless Connections
::Click Here::
Goodluck
Apr 28, 2008 | Dynex DX-E401 Router
Wireless connection
There are a few requirements other than the laptop and the wireless card. You need to also have an Wireless AP/Router that must be connected to the modem that connects to your ISP. All your PCs must then connect to this router either using the wired/Ethernet ports or WiFi.
If such a device (WiFi AP/Router) already exists and is connected to your modem and your other PC(s) are tied up to it and can access the Internet, you need to install the drivers (in a CD that came with the wireless card) to your IBM ThinkPad. Thereafter, you need to configure your laptop's wireless networking to access the AP/router. Your AP/Router must also be configured to accept wireless clients.
Please post back with brand/model of your AP/Router.
Hope this be of initial help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | IBM ThinkPad T20 2647 Notebook
Wireless connection of 570s ap to zyxel wireless modem
did you get the cd with the router? I would run the cd. if not, what OS you use?
Nov 11, 2007 | Zyxel ZyAIR G-570S - Wireless access point...
What is WDS?
Wireless Distribution System (WDS) allows you to make a completely wireless infrastructure. Normally, the access points must be connected with a wire (LAN). These access points create cells allowing a wireless connection. The WDS feature allows the access points to be wirelessly connected. This feature is normally used in large, open areas where pulling a wire is restricted or not cost effective and in residential circumstances. If the structure utilizing an access point is too large to cover using one AP, a second AP would be used as a wireless repeater. The WDS has forwarding functionality for extending the range of an AP. By setting up an extended service set (ESS) between access points. Stations can intersect with any AP of this ESS and move between the coverage of both APs while the higher layer network connection remains intact.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
Acer Aspire 5100 Notebook Logo
29 people viewed this question
Ekse
Alun Cox
