Question about Microsoft LifeCam VX-3000 Web Camera
When i plug my cam says usb drive not recognized help me
  • 38 Answers
You need to install the driver for it. If you dont have the CD you can get it from here
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=ICE&type=Webcams&name=NX3000&os=XP_SP2&lang=en <--XP 32bit
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=ICE&type=Webcams&name=NX3000&os=WVista_32&lang=en <--vista 32 bit
Posted on Aug 20, 2008
  • 876 Answers
Have you tried another USB drive? have you installed your camera software?
SOURCE:
When i plug in my usb web cam into my pc, nothing at all happens or pops up. what do i do?
the pc could not recognize your web cam, try to plug out your usb web cam and blow or wipe the usb of your usb webcam. also try to plug it in to other usb port of your pc. if nothing happens, maybe the web cam it is the problem. and just to make sure that the web cam your using is the problem, try other usb web cam to see if its working on your pc. if the other web cam works on your pc, the web cam your using is damage, and if the other webcam is also not working, the usb ports of your computer is the problem.
thank you for choosig fixya. if you have other question regarding to this problem, just post it.
Jan 14, 2012 | Logitech Computers & Internet
What is the driver for a sanyo s650? i connected the cam to my pc i have windows xp and the pc does not recognized it... it recognize a usb but does not open nothing i cant see my cam in my devices
Consider NOT connecting your camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 16, 2010 | Sanyo VPC-E760 Digital Camera
Usb flash memory not recognize and become hot temperature malfunctioned
At first attempt in plug in your usb flash memory didn't recognized you may plug out. And plug in again until it recognized you may see that theres an icon in the task bar at right below. Thanx
May 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My computer won't recognize my camera when I try to load photos
Two Possibilities:
1) There's no driver installed, or the installation failed. ( A notification will say so when you plug it in ). Be shure the driver is setup properly.
2) The setting on the camera is set to "WebCam" and not "USB Disk"
In the settings menu, (Not the photo menu) on the camera there will be a USB Function option; this sets the camera up to behave like a cardreader and set the plugged in camera as an aditoional disk drive.
The other setting for the USB Function is "Web Cam" or "Digital Camera"; this will set the plugged in camera to behave as a USB Web Camera accessable to tv tuners or other recording or chat software.
To test, open the "My Computer" display of available hard drives, Disc Drives, Floppy Drives, and Memory Card Drives, then plug in the camera into the USB connector. A USB signal sound will alert you and a new drive should appear on the My Computer list, that's the camera.
If you don't get a new drive, then unplug the USB connector and enter the Menu on the camera, look for a USB function menu and set it to Disk drive, or whatever is not Web Cam function.
Note: This is for PC, and not Apple type computers, but I'm shure an Apple computer would be similar.
Cheers.
Richard.
Oct 13, 2009 | Canon Cameras
Usb port2 in not recognizing by my obi cam or my
Try to update your usb drivers. Check if it is available on the manufacturers website.
Hope this helps!!
Please rate this!
Cheers
Sep 27, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
My computer won't recognize my flip cam on the front usb ports
plug in your flip. Click start, control panel, adminitstrative tools, computer management, storage, disk management. right click on flipvideo. Choose 'change drive letter and path' Pick a drive letter, any letter that is not currently being used on your comp (try U). Tada it should read your flip
Apr 29, 2009 | Pure Digital Flip Mino Digital Camera
Computer not recognizing web camera
The only other thing that I would suggest you try to do is (if possible) goto another PC or maybe a friends PC and plug the web cam in. If it does the same thing then the web cam no longer works. If it does work, then you may want to try another USB port on your PC.
Jan 23, 2009 | Logitech Webcam
My powerbook g4 won't recognize my external hd or my web cam but it recognizes my ipod.
I am not really sure but i think the Camara and the External Hard Drive have to be compatible with Apple I think so you can use it. An IPOD is made by Apple so thats why your G4 recognizes it. I would just buy like a USB Drive. And also try to download the Drivers also and you can do that by google-ing it that sort of think. Anyways just use a windows based computer Bro its much more efficient. Let me know how it goes alright.
Oct 02, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
CAMERA INSTALLATION
dont plug ur camera into the usb port while installing the software.after completing the installation it will ask u to plug in the cam by itself.hope it works all the best
Apr 10, 2008 | Logitech Webcam
Re: Hitachi DZ-MV550A, NTSC DVD Camcorder
The answer depends on a lot of things. If you plug your cam in and it doesn't make that happy plug and play sound, then it could possibly be your usb port. If your PC recognizes that a USB periphial has been connected but does not install the drivers correctly, then you should make sure that you have the right cam drivers for your operating system. If that has went correctly then there's one more test to see if your pc has recognized the camera. Go to my computer look at all of the drive letters for one that is not there whenever the camera is unpluggedc. If a drive shows up when the cam is plugged in, then it recognized your cam, especially if you can navigate to folders within that are labeled DCIM or RTAV.
Jun 30, 2007 | Hitachi DZ-MV550 DVD Camcorder
Microsoft LifeCam VX-3000 Web Camera Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
