Question about Hitachi CP-S210 Multimedia Projector
HItachi cp x1250 blue tint area on black background
HI, I have a HItachi cp x1250 video projector wth a blue tint area on about 1/3 of the black background. the area is irregular in shape but is centered in the top left corner and fades to black toward the other 3 corners. this is visable clearly with a solid black image. but it also effects full color images. Pure white images are white with no problem visable. this shows up with either the RGBHV input or composite video inputs.
please let me know if it is adjustable or if it needs serious repair and the ballpark cost of such. thanks, Dave
  • njh1957 May 21, 2009
    My projector image looks as though it is bleeding. A blue tint is covering most of the screen. Is it worth getting fixed or would it be cheaper to buy a new projector?
Your LCD pannels need to be replaced, good luck.
Posted on Nov 10, 2008
The filter needs replacing. Do you sell replacement filters for model CP-X1250?
Take the filter to the local electronics repair shop and ask them for some filter material like the one in the unit. Then cut it to size to fit like the old one.
Mar 25, 2011 | Hitachi CP-X1250 Multimedia Projector
Hitachi CP-X1250 MULTIMEDIA PROJECTOR - MENU> MAIN> BRIGHT and CONTRAST are not active. BRIGHT and CONTRAST How to enable? I can not make adjustment.
hi,
Go to menu and then select main. then select reset and execute it.After that try to adjust the brightness and contrast.
Remember on thing, in some projectors the brightens and contrast will be active when there is video signal. also try that.
ok
Jan 26, 2011 | Hitachi CP-X1250 Multimedia Projector
Hitachi projector cp-s318 and the pictures give off a red tint.
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have). Go through the menu settings of your projector.
Hope this helps
Apr 01, 2010 | Hitachi CP-S318 Multimedia Projector
Color shift blue tint
This could also be a setting. If you are using component video as a connection, make sure that the unit is set for RGB if coming from a laptop or other computer system. If the projector is set to YPrPb, the picture will look purple or bluish as you describe. Change the setting to RGB and all should be well.
Dan
Oct 26, 2009 | Hitachi CP-X1250 Multimedia Projector
Projection has yellow tint
From your description, it sounds like a problem with the blue color. Green LCD=purple onscreen, Red=cyan(baby blue) onscreen, Blue LCD=yellow onscreen. It could be a lot of dust on the blue lcd panel, or worse, might be a burned polarizer filter behind the lcd panel due to excessive heat. If you can focus on the yellow and its tons of yellow specs, its dust. A burned filter however, must be replaced. A technician trained in projectors will have to do it. The filter material is glued to a thin glass panel and is replaced as a single filter. It's a very involved repair.
Sep 04, 2009 | Hitachi CP-X251 LCD Projector
Hitachi cp-s240 blue tint cloud problem
This might sound like a worn spot in the (blue) lens from heat, or a bad color driver on the mother board. It could possibly be dirt or condensation behine the lens(s)
Jun 19, 2009 | Hitachi CP-S240 Multimedia Projector
Greenish tint on my Hitachi x1250 Projector
the light polarizer on the blue lcd panel is fried due to excessive dust and heat. you'll have to replace the entire optical engine.
Dec 22, 2008 | Office Equipment & Supplies
Bulb
Instructions How to change Lamp in Hitach CP-X1250 are available on User Manual page-38
Please confirm do you have User Manual?
Oct 01, 2008 | Hitachi CP-X1250 Multimedia Projector
Hitachi CP-S210 Multimedia Projector Logo
1,010 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
