Question about Dell 3100cn Laser Printer
No printing on right side, I replaced the imaging drum but that did not solve the problem.
No printing on right side, fades and dissapears about 1-2 inches
  • edfromut Aug 21, 2008
    I have the same problem. The right side is gradually getting more and more chopped off. I have replaced the drum and cartridges but the problem is still there. Does anyone know what's wrong?
  • 185 Answers
U hav to check the drum and adjust its position,u also check the position of the tray in the printer.
Posted on Aug 26, 2008
My HP3505 we just installed a ne black toner, now when we print it leaves a small line about 3 inches in from right side of paper every 1 inch. all the way down. Is this becasue or drum is dirty
hi
if you have not replaced the image drum (fuser) after three or four toner replacement changes, you will need to replace the fuser assembly to avoid unwanted lines and grainy or faded prints.
it is also a good idea to replace the rollers as well, if they have not been replaced either
RM1-2763-020CN fuser assembly worth about $200 with exchange of your old fuser
RM1-2727-000CN, worth about $10-$15
please send me 4 thumbs up
Aug 15, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Only prints on one side of paper. print starts to fade to nothing from right to left
Print the "supplies status" page.
Replace any cartridges that are low, Replace the imaging drum if it is low or empty.
Mar 22, 2011 | HP LaserJet 2550L Printer
OUR CM1017 MFP IS HAVING AN ISSUE WITH TONER ON THE PRINTED PAGE: THE LEFT AND RIGHT MARGINS, MAYBE 1 INCH INTO EITHER SIDE IS PRINTING BUT IN A FADED SHADE OF WHAT THE REST IS. CARTRIDGES ARE FINE BUT...
sounds like a imaging drum is getting old. they have a finite lifespan. Especially if the machine is used frequently. Look for an imaging drum replacement. Cheers.
Aug 25, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
Problem with Dell 1720 printer
Hello
You have to check couple things in this case.
Ensure that the printer cover is closed.
  1. Remove the toner cartridge.
  2. Firmly shake it side-to-side and front-to-back several times to redistribute the toner.
  3. Reinsert the toner cartridge, and continue printing.
Repeat this procedure multiple times until the print remains faded. When the print remains faded, replace the toner cartridge.
or
The imaging drum is approaching full and needs to be replaced. Order a new imaging drum.
Apr 30, 2010 | Dell 1720dn Laser Printer
I have two lines about a 1/8in on each side of the paper that are smudged or faded on a HP Laserjet 2600n Printer how can I solve this??
Usually that means you need to replace either the image drum or some of the smaller parts to fix this. If it seems to fade out more as you print more pages but comes back the next day when its cold then you may need to price out a drum or corona wire. The fix is just replacing the part which is about the same as replacing an toner drum BUT you need to make sure the parts cost isn't more than the printer is worth.
Oct 22, 2009 | HP Color LaserJet 2600n Printer
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
There are two possible solutions to this common problem.
1) The Cyan cartridge may not be in 100% of the way. If the handle of the Cyan cartridge prutrudes even slightly, it can obstruct the printhead for the black developer. Remove and reinstall the Cyan cartridge and test.
2) The printhead is dirty, with some toner spillage on the printhead. All new imaging drums also include a new cleaning pad for the cleaning wand.
The cleaning wand is designed to clean toner off of the printhead. you can see this in your printer manual, but basically, just open the front cover, pull the the blue handle on the right side forward ( this opens the access cover for the cleaning wand on the right side of the printer ).
gently pull the cleaning wand out ALL THE WAY, then slide it back in ALL THE WAY. do this several times.
The cleaning wand is intended to travel across the print head in only one direction, which is why you should make sure that it is pulled all the way out.
One of these two solutions should fix your problem. If the problem is resolved, but then reappears after a short time, then you have a defective developer that is leaking toner on the print head. The color of the defective developer can be determined by the color of the cleaning pad after cleaning the printhead as discribed above.
Sep 07, 2008 | Dell 3100cn Laser Printer
Black line on right side of prints
the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Jun 06, 2008 | Konica Minolta magicolor 2400 Laser...
Dell 3100cn Laser Printer Logo
89 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
