Question about Jabra BT350 Bluetooth Headset Headset
Bluetooth 350 I have a bluetooth 350 which I successfully paired with my phone some months ago. Now everything seems set correctly, the verizon phone is "on" for bluetooth, the bluetooth is blinking blue every three seconds, but when I try to call from my landline the bluetooth answer button seems to do nothing. Have tried several times; no luck. Thanks much.
  • 38 Answers
It might be the pairing has drifted slightly. I would try repairing again. It certainly cant hurt anything.
Posted on Aug 20, 2008
6ya staff
SOURCE:
Bluetooth in car not recognizing Droid 2 any more - worked fine but now does not
your limit would have crossed
there are a particular no of devices that could be paired
Pair your Verizon Motorola Droid 2 smartphone with a Bluetooth device using these steps:
1. From the Home screen tap Menu > Settings app.
2. Tap Wireless & networks.
3. Tap Bluetooth settings.
4. Ensure that Bluetooth is checked.
5. Turn the Bluetooth device on and set it to discoverable if required.
6. Tap Scan for devices.
7. The Droid 2 should locate any devices in the area. You may need to enter a password. Most devices have a password of 0000 (four zeros).
The Bluetooth indicator should now show in the notification area. This indicates you are paired successfully.
Feb 24, 2012 | Motorola Mobility Droid (2 GB) Cell Phone
New motorola v3m razr phone will not find any bluetooth devices
Is this a repair store,some stores have a tec that can reload the firmware and any new updates for the phone. The warranty is probably over and moto would charge you to repair the phone. See how far away that there is a Verizon that can reload the firmware.
Also,thanks to verizon for being thieves that you can not transfer
anything with bluetooth, so if you want bluetooth for your pc, or to transfer anything your out of luck. verizon has disabled
Obex in the firmware of the phone. You can bluetooth a headset,but thats all.
  1. Press Start.
  2. Scroll to and Select Bluetooth.
  3. Scroll to and Select Bluetooth Manager.
  4. Scroll to and Select Hands-free.
  5. Press Add to configure a new Hands-free device.
  6. Press Search to search for devices. Your phone will begin to search for the device (consult your device user guide for instructions on placing your device in pairing mode).
  7. Select the device.
  8. When prompted, press Yes to pair with the device.
  9. Enter the device passkey (normally 0000).
  10. Press Done. When your phone is paired, the Bluetooth indicator will be displayed on the home screen.
Just checking to see if this is the way you connect,or tried to connect.
Apr 04, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Im trying to pair my verizon cell phone to my motoral headset
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Motorola Mobility Bluetooth Hands Free...
Can,t connect my Plantronics220 Earpiece to my phone
Begin with headset turned off. 1. Press and hold down the call control button
for 8 seconds until the headset status indicator begins to flash blue then red. The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing, use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
Oct 13, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Moto razr will not hold pairing to Bluetooth
ook .. man try to do this. but first back up u'r fone,. here it is! go to menu, settings, initial set up, master clear code ( 000000 ) fone boots just w8,, then go again to menu, settings, initial set up, master reset code ( 000000 ) fone boots and now do your things,.. let me know..
Apr 28, 2008 | Motorola Mobility RAZR V3
With use of Jawbone, recipients on enV get voice echo
About three months ago I bought the LG En V touch from a verizon store. I planned to use it with my old "New Jawbone" and my new "Jawbone Prime". The phone would nto pair at first then when they finally got it to pair I had a variety of problems. Verizon technicians performe a number of different steps trying to make it work as it was supposed to. They even reinstalled the software after about a week and a half I persuded the Verizon stor manager to replace the phone with a new LG EnVtouch and they exchanged my Jawbone Prime also. The new LG EnVtouch had the exact same set of problems. Neither of these phones worked any better with the bluetooth in my Garmin NUVI either. I loved the design and the features but if it doesn't work why bother. I returned the second LG EnVtouch after aabout five more days of frustration. And went back to my old phone. If you buy one of these and it doesn't work return it fast and let them know what you think!
Apr 20, 2008 | LG enV VX9900 Cellular Phone
Jabra BT 350
u gotta make ur jabra go to FIND ME Mode, u do this by turning it off, Turn it back on by pressing power for 6 to 8 seconds until the light is in flashing mode, and make Ur razor look for devices and pair it with the 0000 code. hope this works for you
Feb 11, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Nov 30, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 Bluetooth Headset Headset Logo
67 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
