Question about GE JTP45 Electric Double Oven
Installing a GE Double Elec Oven (JTP45)
I have recently purchased a white GE Double Electric Oven from a church salvage sale. It was only used for 3 months, then sat at the church for a couple years. It has all the parts and pieces, except for a manual. I need to get this oven installed, but have no idea on the specs and measurements required. The space it will be going into currently holds a single oven with deep wood drawer cabinets underneath, that I have to gut and remove to make room for the taller unit. I am looking for an installation guide/manual, be it online or hardcopy. If you can help, I'd appreciate it!
Model # JTP45WOW1WW
SN: GS610015R
2 Suggested Answers
  • 5299 Answers
SOURCE: how to install GE JKP35DPBB 27" Double Electric
The specs for this double oven give a rating of 5.1kW at 208V so it needs a 30 Amp circuit breaker. This assumes that the oven is the only appliance on the circuit. So you should be able to use the same circuit breaker.
A bigger consideration is that the opening for the double oven needs to be larger than that of the single oven. If the opening does not have a solid bottom, it must be able to support a heavier load. The runners and braces under a single oven has to support 200 pounds (91 kg). A double oven must have braces and runners designed to hold 375 pounds (171 kg).
Also check if your household uses aluminum wiring. The new oven has copper and problems will occur at the interface if you do not use the appropriate precautions. (Products designed for mating copper and aluminum are available - follow the directions).
I hope this helps.
(btw: you can find the User's Guide and Installation manual for the double oven at GE's website: . See the section Literature and Manuals on the left hand side of the page below the picture of the oven.)
Posted on Oct 29, 2010
How to reset thermal fuse on jkp56 double oven
If it has a red button in the middle, push it until it clicks. If no red button, you have to replace the thermal fuse.
Jun 03, 2014 | GE JTP45 Electric Double Oven
Jtp45 lower oven hot heating on any cycle
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
May 12, 2014 | GE JTP45 Electric Double Oven
Ge jtp45 display is very dim
Cover over display has a film that darkens with age. you can cut the film off.
Dec 26, 2013 | GE JTP45 Electric Double Oven
Not heating
My oven lights but takes ages to cook food. Also flame goes off if oven door is closed at the beginning of lighting the oven
Dec 16, 2013 | GE JTP45 Electric Double Oven
Electrical panel goes out when top oven gets hot jtp45
Sorry dearest
We in the wilderness are not familiar with that brand, sorry
Apr 09, 2012 | GE JTP45 Electric Double Oven
I have just installed a new electronic control in my JTP45 Electric double oven. (part WB27K5273). I have a schematic, but so far have not figured out why that when I open the door the unit turns off and...
It does sound like a wiring mistake. Check all the connections and the wire colors against the colors on the Tech Sheet wiring diagram (which is normally taped on inside the control panel). Particularly look closely at how the door switch and lock connector is plugged in. You may have reversed the plug.
Best Regards,
Jun 18, 2010 | GE JTP45 Electric Double Oven
My oven gets a F2 code
F2 means usually, that the board detected that it's too hot.
You either need a new control board or a temp. sensor.
ge oven repair orange county, ca
Feb 06, 2010 | GE JTP45 Electric Double Oven
F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Jun 30, 2009 | GE JTP45 Electric Double Oven
I have a F0 on the display of my double oven JTP45 model
Giggles01: I wish I had an answer other than calling GE. We are about to install a used oven of the same model/same vintage. I've been unable to locate a manual and need some information from it. Would you be willing to tell me the cut-out size the manual calls for regarding the installation of the oven? Most 30" ovens require a 28.5" cut-out, and I need to confirm that for the JTP45. Thank you!
Mar 09, 2009 | GE JTP45 Electric Double Oven
GE JTP45 Electric Double Oven Logo
214 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
