Question about HP PSC 2210 All-In-One InkJet Printer
Screeching noise from the carriage return after printing
To CompuG: I was wondering if you could tell me if this is something I can remedy, or will it require a professional repair? My all-in-one prints beautifully, but once it's done, it makes a loud screeching before stopping. Occasionally I get an error message to open the back and clear a jam, but there is no a jam. Hopefully this is not an expensive fix.
Thank you,
  • mothermoon Aug 21, 2008
    Yes, I still need advice. But if you can't help without charging me for it, then you really are no help. Thanks anyway.
Thanks for your response! I'll try your recommendation.
Posted on Aug 21, 2008
  • 4 Answers
Hi mothermoon,
This could be coming from dirty rollers. Raise the top of the unit and take some Q-tips dipped in isopropyl alcohol (rubbing alcohol) and start cleaning all the rubber rollers and especially all the steel rolling pins that are in front of those rubber rollers. Spin the rollers around, by hand, to make sure you clean all around them, not just one spot. You'll be surprised how much residue you'll get off these parts. Even if this doesn't help your particular problem it should be done as standard maintenance.
Kodak esp 2170 carriage jam problems
The carriage operation is not synchronized. It will have to be adjusted to normal
Aug 14, 2016 | Kodak ESP Office 2170 All-in-One Printer
Oven "screeching " noise .
Yes it wil continue to work on manual basis
Oct 18, 2017 | Neff B1432 Single circotherm plus Electric...
Car made high pitch squealing noise before it not being able to turn over
I wonder if you have a fan belt that is screeching? They get glazed over and eventually wear out and make a high whine and screeching noise. This what it is
Feb 05, 2013 | 2005 Honda Civic
Carriage jam error
A paper jam
If you've had a paper jam, normally after you clear it, a small amount of paper sometimes gets left behind and gets shunted onto the sidewall of the printer by the carriage, which stops the carriage reaching its full travel and throwing up an error, rendering the printer unable to print or carry out any other function. Simply remove the paper and switch printer off and on and it will reset.
If you have an error of any other kind, many remedies and fixes for these can be found on my website
Oct 25, 2012 | HP OfficeJet 6110 All-In-One InkJet...
When turn on typewriter there is an continuous beeping/screeching noise and will not operate.
Remove print wheel to ensure its not jamming, switch machine back on and see if carriage returns to the LHS home position. If it does not and the carriage is just shaking and the noise is still there, you may have a defective carriage motor or defective power supply.
May 27, 2010 | Nakajima AE-830 Typewriter
Printer made machine gun noise. will not print.
The print head is stuck - something has jammed it and the noise you are hearing is the carriage for the print head. Open the top and try moving the head by head sideways to see what has jammed it.
Aug 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Screeching sound when I hit the return
Remove the case by inserting a flat screw driver nito each of the slots on the four corners of the base spray some light iol on the carrier motor bearings (right rear corner of typewriter.
Also put some on the silver shaft that the carrier slides on.
May 11, 2009 | Lexmark Wheelwriter 15 Series II...
HP 7410 Poor printing, carriage jam message(fake), loud noise
Check the plastic strip that you'll see along the carriage track. Make sure it's clean. Take a soft cloth and dampen it. Run it up and down the strip and make sure it's clean. If there's any ink on it, it could cause carriage jams. The strip has tiny lines on it which tell the electronics where the carriage is. If the strip is dirty, you'll get jam messages and sometimes the carriage will slam against one end or the other.
Apr 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Carriage jammed
first open the door and ckeck out any optical in carrage moving area are not shigted if the carrage movoing area are free then ckeck in service station it is working properly or not if it is working properly then ckeck the endcoder strip and if it is also ok then reinstalled the mecanism your problem will be solved
Jul 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
The squeeling I think has to do with a small build up of ink on the carriage.
What I do is I open up the printer top so you can see the carriage as if you were putting in a printhead and then you unplug the power to the printer when teh carriage is in the unlocked position. Now you can freely move the carriage back and forth. If you notice there is a clearish long strip going from one side of the printer to the other that is placed flat ontop of the entire metal inside casing of the printer. Clean that entire strip with a cloth or something. Now take a piece of paper and fold it a few times so that it ends up looking like a ruler you can say. Put the paper flat on that clear strip and then take the carriage and move it over the paper. Basically your cleaning the underpart of the carriage that touches that clear strip that is attached to the metal body of the printer. Move it back and forth and you will see ink being put onto the paper thus cleaning it.
Just close the case up, plug in your printer and the squeaking should be solved till next time. As for that light problem, don't know what those lights mean. If there is a problem with teh printhead or ink though it will always tell you on the digital read out, or at least should.
Jan 19, 2008 | Computers & Internet
HP PSC 2210 All-In-One InkJet Printer Logo
100 people viewed this question
Ben Johnson
