Question about Compaq Presario M2000 Notebook
Battery removal and replacement for a Compaq v1000
I am having a problem removing/replacing the battery on the above laptop.
I can only find one slider lock on the PC,but when pulled to rerlease the battery will not budge,how do I persuade it to disengage.
Thanks
Pete R
  • keencenturio Aug 29, 2008
    Great,thanks Robert.
    I now know this as I sorted it by myself.
    I have another prob with a Compaq presario, M2000.All the lights that should work when I turn on the PC do come on,but thats it,no further movement after that,lights stay on,hard drive light stays on,no flickering as usual,ant idea,could what it couid be.
    Cheers for your other solution.
    KC
    Brigadier General:
  • 5,158 Answers
Turn over the laptop. have the front facing to your right. the battery should slide out toward you.
The sliding lock is about 3 inches in from the side of the battery... it slides to the left (toward the back of the case)
Robert
Posted on Aug 28, 2008
  • Roberta Smith
    Roberta Smith Aug 29, 2008
    Does the computer finish booting normally ?
    Robert
How to reset bios on compaq v2000 laptop
Remove A Cmos Battery From A Compaq V2000 Laptop
The Complementary Metal-Oxide Semiconductor (CMOS) in a computer is responsible for storing hardware settings and time on your computer. The CMOS is powered by a small battery and is able to store information whether your computer is turned on or off. While the standard CMOS battery lasts for up to ten years, you may need to replace your CMOS sooner than that. If you password your BIOS and forget the password or need to reset your configuration back to the default, you can remove the CMOS and re-insert or replace it.
Instructions
1. Unplug the computer from the wall outlet and unplug the AC adapter from the computer.
2. Turn your Compaq Presario V2000 face down and slide the battery release latch to the left to disengage the battery from its position. Remove the battery.
3. Unscrew the screws over the hard drive cover, which is located in the lower right corner of the laptop if your laptop is placed with the battery away from you. Lift the hard drive tab, located on the left side of the hard drive, and slide the hard drive to the left to remove it from the computer.
4. Unscrew the single screw located directly under the optical CD/DVD drive. Insert a very thin item, such as a paper clip or pin, into the hole located on the optical drive to open it. Slide your optical drive out of its tray to remove it.
5. Remove the two screws located on the switch cover, which is directly under the battery. Turn the computer right-side up and open it as wide as it will go. Use a flat tipped screwdriver to lift up the switch cover that is directly above the "F1," "F5," "F11" and "Insert" keys.
6. Unscrew the four screws that hold the keyboard in place. These screws are are located in the upper right corner of the computer under the switch cover that you just removed. Lift the keyboard up and slide it forward until it rests on the palm rest. Unplug the zif connector, which is located directly above the palm rest, to disconnect the keyboard. Lift the keyboard up and out of the laptop.
7. Turn the computer upside down again and remove the memory modules by unscrewing the two screws over the memory compartment located directly below the battery slot. Unclip the two clips located on each side of the memory module to release it from its slot and slide it out of the computer.
8. Unscrew the two screws on the PCI cover directly beneath the memory module. Disconnect the two wireless antennas above the card. Spread the two clips securing the mini PCI card into place and lift the card up and out at a 45-degree angle away from you.
9. Flip the laptop back up on its right side and disconnect the display cable located in the upper left corner above the keyboard area underneath the switch cover you removed earlier. Then remove the two pieces of tape in the upper right corner that hold the wireless antenna in place. Remove the two clips located beneath the tape pieces. Unscrew the two screws on the upper left corner and the two in the upper right corner that hold the display into place. Remove the display assembly.
10. Turn the computer back upside down and remove the remaining 19 screws. Lift the base enclosure straight up out of its place.
11. Locate the CMOS battery, a small circular object, and lift it up out of its place. Leave it out for five minutes and reinsert it to reset your settings. Re-assemble the computer without the battery and plug it into the wall.
Remove Cmos Battery From Compaq V2000 Laptop
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
How do I remove/replace the hp compaq presario cq60-615DX internal battery. Not the CMOS one; the other large one at the back. There is no slider/lever. thanks
In order to remove the battery pack you should slide the Lock key to the Unlock position and keep it there until you have removed the battery. In the following video (at 00:08) you can see how to do it and replace the CMOS battery also. Hope that helps. How to replace the CMOS Battery in the Compaq Presario CQ60 Laptop
Here is the manual you can read more and see how to on page 46.
http://tim.id.au/laptops/hp/hp%20g60%20compaq%20presario%20cq60.pdf
Feb 18, 2014 | HP Compaq Presario V2000 Notebook
When I hit the power on button on my compaq nc6220 the yellow battery light flashes and nothing happens
Please try removing the battery, and then connect the power adaptor and try switching the laptop on see it if works if it works then the battery needs to be replaced. I would also recommend if you can check your power adaptor / swap your power adaptor with a know good adaptor (if you have one). The remaining steps will depend on the outcome of the steps above.
Oct 02, 2012 | HP Compaq nc6220 Notebook
Compaq Presario CQ50-215NR The computer has a beeping sound like a car alarm. while to Operrating system is running. It wont stop beeping
Hello.
The most common reason for this problem is memory. They could be slightly loose or faulty.
Disconnect all cables. Flip over the laptop and unlock and remove the battery.
Remove the memory cover. Remove and reinsert (on a slant) the memory module(s). Replace cover and battery.
Power on again.
If the problem persists, a memory module could be faulty. Follow the above instructions but test one module at a time.
Hope this helps.
Nov 08, 2011 | Compaq Presario CQ50-215NR Notebook
Hp compaq 6730b notebook, how can i take off bios administrator password
disconnect ac adaptor, remove battery, remove RTC battery (refer to photo) wait 5 minutes, replace RTC battery, replace battery, reconnect ac adapter, reboot computer, NOTE: you will have to enter into the bios and reset time date and any other options as you see fit.grrrrrrrr666_1.jpg
Jan 07, 2011 | HP Compaq 6730b Notebook
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Four keys as g,h, backspace and windows key is not working of my fujitsu siemens amilo pro v 1000 keyboard.
SOLUTION FOR Four keys as g,h, backspace and windows key...:-
I read this on a website and it worked wonders for me. TRY THIS:-
1. Just remove the adapter so that your laptop does not get any power.
2. Let the battery go completely empty and let the laptop get shut down with low battery automatically.
3. After laptop gets shut down, remove the battery and clean it with some cloth. Also clean the battery panel.
4. Press and hold the power button for kind of 30 seconds or so (laptop will not get ON).
5. Plug in the adapter to the laptop and start the laptop normally.
This process will fix it for you.
If the above does not work:-
1. Start the computer in safe mode with the last best configuration. It may also work for you.
Thanks,
- Naveen
Aug 24, 2010 | Fujitsu Siemens AMILO Pro V1000 Notebook
How do you reset the power on password on a Compaq 6720s laptop
Hi There,
If you're trying to describe the BIOS password, then this link is the best information website on the subject I've ever run across. Best of luck....
http://www.tech-faq.com/reset-bios-password.html
Aug 04, 2010 | Compaq Presario Notebook
How can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
how can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
May 04, 2009 | HP OmniBook 500 Notebook
HP Compac Presario V1000 battery problem
problem with the batteries I think my friend
Jul 28, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario M2000 Notebook Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
