Question about Philips 60PP9200D Television
ALOT OF BLUE ON THE SCREEN!!
I JUST BOUGHT THIS TV USED AND IT LOOKS LIKE THE BLUE COLOR IS TOO HIGH. EVERYTHING SEEMS TO HAVE A BLUE TINT TO IT..I TRIED ADJUSTING THE COLOR AND STUFF BUT THE BLUE STAYS EXCEPT FOR BLACK AND WHITE MODE. I DONT SEE ANY DOUBLE IMAGE OR ANYTHING..THE IMAGES ARE PRETTY CLEAR BUT JUST ALOT OF BLUE. ANY IDEA WHAT IT IS AND HOW MUCH WOULD IT BE TO FIX IT?
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
ALOT OF BLUE ON THE SCREEN!! - f0900cb.jpgttp://i.fixya.net/uploads/images/f0900cb.jpg" alt="f0900cb.jpg" class="h_mi" />
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This isALOT OF BLUE ON THE SCREEN!! - 2c07611.pngroblem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
ALOT OF BLUE ON THE SCREEN!! - 578ba6c.jpg of a set that needs the fluid changed.
TV set after fluALOT OF BLUE ON THE SCREEN!! - 2c07611.pngr />
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 07, 2009
  • 10,594 Answers
First try to adjust Hue or Tint control in menu to obtain correct color.
2nd, If you are tech-person, you can fix it at your own. TV needs adjustments of Red Green gain bit increased and Blue gain bit decreased. Another possiblity is Screen Volts adjustment. If you are non-tech, look arround qualified technical person to perform these actions. Hope this info will help you.
Posted on Aug 20, 2008
Panasonic pt43lc14 no red color. picture is good. cannot get anything to look normal color after trying to adjust color/tint/picture etc. Have alot of blues and yellow, and brown. seems like no red.
It appears that your light engine is broken, I have the same problem. Have you recently changed the bulb with a non-panasonic part bought on the internet. I did this and think thats what caused the problem. I believe the new bulb burn at a higher temp thus causing damage to the Light engine filters
Jan 04, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Color Tint on CRT Philips 9P60349103
Return it to the "friend" as defective.
Nov 26, 2017 | Philips Televison & Video
Panasonic 56" projection color problems
there are so many technologies for the projection tv's ever one has their own caracteristic faults with out you mention the technoligy used on your tv will be deficult to help you but assuming is a lcd projection you must have a problem with the optical block the repair will be expesive if you do not have a manufactuer warranty for it
Jan 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
No red tint on TV screen
check the CRT section if there are resistor open,transistor drive of red color is leak,resold the red section of the CRT.
Sep 06, 2008 | Televison & Video
Hannspree 37" with Xbox 360 HD
Try to use a HDMI cable, your component cables may not be usable with your TV.
Apr 20, 2008 | Hannspree (K206-10U1-005) Television
Monitor is blue-evrything has a blue tint-i can see colors,they just have a ble tint
I've found that strange color tints are usually the result of a loose cable connection, either at the computer end of the monitor end.
Try unplugging both ends, and then replugging both nice and securely (might even try reversing the direction of the cable, if it is a simple VGA-VGA cable).
Feb 27, 2008 | Computers & Internet
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Philips 60PP9200D Television Logo
181 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
