Question about Nikon D40x Digital Camera
Shutter problem my d40x shows an nformation,"press the shuter release button again", what can i do that my camera works again.
  • babuprashant Sep 04, 2008
  • austinmike44 Sep 06, 2008
    I have exactly the same problem
The memory card may be corrupt.  Try using another memory card.
If this doesn't work, try using the camera's reset function.
I think this is done by holding down two buttons, which should be marked with green dots. If not, check the manual.
If this doesn't work then it may be a repair job...
Posted on Sep 09, 2008
Error. Press shutter release button again
Press the shutter release again what is the solution
Sep 11, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
What do I do when my camera says,
If resetting the camera with the reset-button won't help, you have to take it to the authorized dealership for repairs.
Jun 03, 2010 | Nikon D40x Digital Camera
My Nikon D40X shows an Error for the shutter release. It says "Error. Press shutter release button again." When I push it again, it keeps giving me the same error. Is there a way to fix it without sending...
Hello. I have the D40X myself and I have had success by going into the menu and locating the reset button. What this does is return the camera to the settings that it had the day it came out of the box. Joe
Feb 14, 2010 | Nikon D40x Digital Camera
Nikon d60 shutter release error
press shuter release button again
Jun 22, 2009 | Nikon D40x Digital Camera
My the shutter release button isn't working
I'll give you a couple: 1. Is your mode in shutter priority or focus priority? Check your menus and go into the AF area to see which one it is. If it's in focus priority you will have to be focused on a subject before the shutter releases. The other setting is 'release priority' which will enable you to snap the shutter regardless if you're focused or not. If you tried to re-compose the picture you were trying to take, you may have locked in focus and then when you re-composed it was not in the same area thus not releasing the shutter.
2. 2 button re-set.
Jim Silva
Jun 19, 2009 | Nikon D40x Digital Camera
Nikon d40x camera not working
The camera has a bad shutter or a bad sequence plate motor .
If you need help further contact
Berrie Smith Camera Repair
Apr 04, 2009 | Nikon D40x Digital Camera
Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
Dec 28, 2008 | Nikon D40x Digital Camera
Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
Sep 08, 2008 | Nikon D40x Digital Camera
Nikon d40x shutter problem
May be a weak subject to focus or the flash is not ready when you press the button.
Set the camera to auto(green) mode.Try it with a contrast bright subject for as many time as possible.
If the problem persists turn off the camera and reset the camera using the button near usb connection.
Then go to seller for replacement.
Mar 17, 2008 | Nikon D40x Digital Camera
Faulty nikon d40
I had the same error message, the camera is less then a year old, however, I was taking up to 800 pictires every weekend of my kids soccer games, then a 6 month trip to the Pursian Gulf, that is when it started, I got back home, took it right in, and one year later after a few visits and calls trying to find out where my camera was, I finally got an answer back, they said I needed a new shutter which will cost $300, They said I should just by a new body for $400. What Nikon does is set that error message to pop up at about 35000 shutter releases, and you can't do a thing about it, once they hooked my camera up to thier system the said I had over 36000 shutter releases, where the average person takes 10000 a year and they want you to replace the body every 3 years....so before buying any camera, always check out how many shutter releases you can get when you buy a camera
Rob Smith
Victoria, BC
Nov 01, 2007 | Nikon D40x Digital Camera
Nikon D40x Digital Camera Logo
60 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
