Question about Hotpoint Aquarius WMA42 Front Load Washer
Aquarius 1000 rpm WMA30
What is the "one" button for and how do I use it as I have no manual
  • 139 Answers
One... use this option for...
Washing a single item of clothing, for example, one pair of jeans.
This option will reduce water consumption and washing time.
Note:You can reduce the amount of detergent you use with this wash.
Do not use the ‘One’ option with a full or a half load.
http://www.hotpointservice.co.uk/hs/pages/manual/
try this link for a manual
Posted on Aug 20, 2008
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius Wma30, leaking water...filter?
There should be a plastic filter fitted in the hose, if there is not, then it should not stop the pump working, unless ther is a blockage in the hose from the drum to the pump, or a blockage in the hose from the outlet of the pump.Try removing the hose from the pump outlet, and blowing down it to see if is clear.
Also the pump itself could be faulty.
Apr 05, 2010 | Washing Machines
Hotpoint wma 30 on the letter coded dial what is the letter L used for
The letter L on a Hotpoint WMA30 is for hand wash items. If you need a user hand book for this model use this link and go to 'user manuals' or if you need a worksop manual for the WMA or WM range use these links
Mar 22, 2010 | Hotpoint WMA30 Front Load Washer
I HAVE A CREDA WASHING MACHINE WMA30 IT DOES
There is a thermistor in between the heater terminals .. unplug the block from it and check to see that the thermister has not gone open circuit
Oct 07, 2009 | Hotpoint WMA30 Front Load Washer
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Aug 19, 2009 | Washing Machines
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint aquarius wma30 drum wont turn
If it has filled with water, and no lights flashing, and then no motor action I would check the brushes in the motor for wear.
Remove rear panel , remove belt, undo 2 screws securing motor,
and lever motor back, disconnect motor plug, noting which way it goes in, and check brushes for wear
Plz rate my solutioin.
Thanks.
Dec 28, 2008 | Hotpoint WMA30 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
183 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
