Question about Garmin nuvi 350 GPS Receiver
Garmin 360 keypad stuck
Can't enter state when requesting address because "123" key is depressed and stuck. Need "ABC" key. Reset unit to no avail. Unit only three weeks old.
Operator error - search doens't work with Topo maps, only city navigator. changed map and worked.
Posted on Aug 21, 2008
Stuck key
Precor Error 05, Key Depressed at Power Up
Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
This link will take you to the parts available for these models. Because most machines are serial number specific, you will need to narrow your search based on your particular model and serial number.
Precor Repair Parts for 9 33 9 33i Treadmills Consumer SPORTSMITH net
Jul 15, 2014 | Precor 9.33 Treadmill
Precor gfx 9.33i displays "stuck key"
Corrective Action
Apr 20, 2014 | Precor Deck, Treadmill, OEM
How do I input names on address screen in all CAPS
When you are at the "Enter Name" screen while adding a contact to your Phone Book, press the "*" key to switch between modes. You can check which mode you are in by looking at the box in the upper-righthand corner.
"Abc-W" mode will capitalize the first letter of each word
"Abc-S" mode will capitalize the first letter of each sentence
"ABC" mode will enter in all capital letters
"abc" mode will enter in all lower case letters
"123" mode will enter only numbers
You may switch between modes while entering the name if , for instance, you need to switch between letters and numbers,
Nov 02, 2010 | One Touch Jitterbug One-Touch Cellular...
Can't type in an address. After typing first 2 letters it goes to different roads and won't allow me to type in the correct one.
I would first check what city or town your looking in....
go to Where To..... Address....on the addres screen does it say Select City in ( city the address is in ) ?
If not on bottom of screen it will have change State / Province
If you want you can send me the address or street name and i will check to see if the same happens here....
sometimes if you enter 123 N West St you will need to put 123 North West St or 123 St Anne would be
123 Saint Anne
Oct 30, 2010 | Garmin nuvi 255W GPS Receiver
Im sick wit my kf310,i hv a problm wit typing sms too,the alphbt doesnt change..keep aaaaa,dddd,ggg..i need to delete 1 file in phone memory,but day by day there is ZERO file in phone memory to delete..i...
Have you asked your service provider about this issue???
There are several methods used to entering letters and numbers in test messages or SMS. Generally speaking, there is "ABC" mode where you select each letter by pressing a key several times until you get the letter you want. There are several "ABC" modes ... there is "ABC". "Abc" and "abc" all related to capitalization rules you want to follow.
Another method is called in a lot of LG models, "T9" where the phone uses a built in dictionary to select the word you want with only one press on the key. The phone will try to select a word, but it may not be correct after you pressed all the letters. There is a "next" key, usually the "0" which will roll through the words available until you find what you want. I use a modified T9 method. Some times I want a word that is not in the dictionary so I enter part of the word, then space, then clear and enter the next part of the word to get what I want.
Other data entry methods are "123" and symbols. Use your telephone 'soft keys' to make these selections according to instructions on the screen.
You may need to visit your service provider store for additional assistance in operating your telephone.
Thank you for your interest in FixYa.com
Feb 20, 2010 | LG KF310 Cellular Phone
Tomtom xl340s address with characters
When you keypad appears you should have abc or 123 switch between the both as required
Dec 31, 2009 | Tomtom ONE XL GPS
Unable to enter new address
Please see this link to:
http://www.sharc.net/discus/messages/6/75.html?1235511886
If this resolves your issue, please rate me as Fixya.
Thanks,
- Jim
Mar 01, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi --Can't put state in for address
Turn on the unit and go to Settings
Then select Map
Then select Map Info
Verify that there is a check mark next to City Navigator North America NT
May 17, 2008 | Garmin nuvi 350 GPS Receiver
Samsung d900i
hello!
can you please try this if it will work on your phone
-- Go to a text field first, then press the RIGHT-soft key (not LEFT-soft key that the manual incorrectly states) to see a menu pop in the right bottom corner of the screen.
-- The menu shows Emoticons, abc, 123, Symb, etc
-- Select "Sym", and the popup dialog presents a full list of available symbols.
-- Use the Navigation button on the phone keyboard to go to the underscore symbol
-- press OK to input it into the text field.
or
-- hold down the # key for a few seconds and it will display the symbols
-- select the underscore
May 05, 2008 | Samsung SGH-D900 Cellular Phone
Keying in street addresses
To find streets that are numerical, not names, enter the address normally to start. Enter the State, City, and House Number. When it asks you to enter the street, look at the bottom of the keyboard. You will see a key marked 123. Press this key, and numbers will show up instead of letters. Type in just the numbers (25 for 25th Avenue, etc.) and hit Done. The street should show as (25th (St., Ave., etc)). Press the correct entry.
Dec 04, 2007 | Garmin StreetPilot c550 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
75 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
